Question about Kodak EasyShare Z612 Digital Camera
I have Z612 Kodak Easyshare Digital Camera and I got a SanDisk SDHC Card 4GB* multi-use memory card and put it in it and It says - Memory Card Required Formatting.. How do I do this?? Is this the wrong memory card??? I need step by step information Please.
  • 1 more comment
  • Anonymous Apr 06, 2009
     I just got an 8 gb sandisk card for my z612 kodak camera. So i stuck it in and it said it needed to be formated, so I said sure. Then it said "formatting..." then told me again it needed to be formated? I'm kinda disapointed, I really need a card!! Is there any way I can make this one work? Or do I need to go get a new one?
  • Anonymous Mar 18, 2014
    what disks does it use? According to your lit. mine should work.
    according to your lit. it should work.
I had the same problem when I bought a 4GB card to replace the original 2GB. When I took it back to BestBuy where I bought the camera, I was told that this camera could only use a 2GB card. So, I bought a 2GB card, installed it, and everything was fine.
Posted on May 23, 2009
  • 126 Answers
Power on camera press menu button scroll to setup menu push ok scroll down to format press ok scroll to memory card press ok and you done.
Posted on Apr 16, 2009
Just bought a Kodak 4gb memory card, and camera says it needs to be formated, and I stick the card in and it says it can't be formatted
The Z612 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to use cards 2GB and smaller.
Jun 02, 2011 | Kodak EasyShare Z612 Digital Camera
I have not been able to format a scandisk memory card into my Easyshare kodak camera z612
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card can't be formatted, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Feb 23, 2011 | Kodak EasyShare Z612 Digital Camera
When i install team micro sdhc 4gb memory card in kodak easyshare z612 it says format .i select format but it keeps asking to format or cancell
First check make sure the SDHC card is unlocked I'll provide a diagram for that also I just checked your camera's memory capacity and it's only good for a 1 gig SD card which if using an SDHC memory card might go to 1.5 stretch to 2gig maybe but not a 4gig. My first impression is you got to much memory card for the camera. You might be able to go to the Kodak site and download updated firmware to allow the camera to function with the larger card but that's a maybe as well.
Here are the diagrams
And the memory capacity chart for your camera
Feb 02, 2011 | Kodak EasyShare Z612 Digital Camera
I bought a new 8GB memory card for my kodak easyshare Z612. However it's not formatting. Help!!
The Z612 works with SD cards, which max out at 2GB. It will not work with larger SDHC cards.
May 20, 2010 | Kodak EasyShare Z612 Digital Camera
EasyShare Z612 Digital Camera: I bought a new 8GB memory card for my kodak easysh...
May 18, 2010 | Kodak EasyShare Z612 Digital Camera
Kodak EasyShare Z612 will not format SDHC 4.0 GB card.
Z612 is not compatible with SDHC card., the compatible and recommended Memory card you can only used is 1GB SD card or 2GB SD card. Gudluck!
Nov 03, 2009 | Kodak EasyShare Z612 Digital Camera
4gb sandisk sdhc card
I think the C330 is not compatible with the SDHC cards.
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
May 08, 2009 | Kodak EasyShare C330 Digital Camera
Will a HP 4GB SD memory card work in Kodak
No. The Z612 works with SD cards, which max out at 2GB. The Z612 will not work with 4GB SDHC cards.
Mar 17, 2009 | Kodak EasyShare Z612 Digital Camera
Memory Card required formatting
Hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Dec 26, 2008 | Kodak EasyShare Z612 Digital Camera
    Kodak EasyShare Z612 Digital Camera Logo
    688 people viewed this question
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Parshiv Luthra
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
