Question about HP Photosmart C5180 All-In-One InkJet Printer
Cannot print in black because yellow cartridge is empty ?
So i wanted to print in black color only and i've set in color tab > print in greyscale: Black print cartridge only options but everytime i try to print this message on the printer lcd screen come up: " Replace the following empty cartridge(s) (yellow one) to resume printing
more info: The printer does not have enough ink to ensure printer health. The empty ink must be replaced to resume.
question is, do i really need to replace the empty "yellow" cartridge just to print in black only because it won't let me? can you help me please . thanks
Quang from montreal quebec canada
  • kathryn2009 Jan 19, 2009
    My hp printer has the same problem, and I banged my head against the wall trying to figure out why I couldn't just print in black... and what happened to all my yellow ink considering I wasn't printing anything in colour. Then I came across this website:
    http://www.ripoffreport.com/reports/0/27...
    If this is your problem too, then unfortunately the only solution is to spend more money on hp yellow ink in order to continue printing in black.
    Kathryn, Toronto, Canada
Take the "empty" cartridge out and shake it, and then reinsert it. I did that on my HP 8500 and it worked. The indicator light showed it was full.
Posted on Nov 01, 2010
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
Ok, let's start from square 1 to assess your printer system....
In most cases when the HP02 cartridge is not recognized, or has poor connectivity, you will normally receive an "Unrecognized Cartridge" or "Cartridge Problem" error message with a big RED X; in most cases (like 99.3%) the smart chip needs to be replaced with a new one - please note the chip life has 25 month expiration window from the time the HP02 (or 363 in the UK) cartridge is initially installed into the printer. Costco USA/Canada and Fry's Electronic's (along with some Best Buy stores in Canada) provide a top-notch refilling/chip re-programming service today...check it out:
http://www.costcoinkjetrefill.com/pricing
I suggest you activate a CLEAN PRINTHEAD routine from the TOOLS/MAINTENANCE menu to see if you can blow/**** ink down and thru the PRINTHEAD nozzle plate. You may also need to place a damp cloth under the printhead to help 'wet' the nozzle plate in an effort to remove residual black ink buildup...you can find some youtube videos on how to do this. For additional HP02 support information, please visit our HP02 system support page which includes videos of procedures below: http://inkjet411.com/?page_id=1372
The permanent PRINTHEAD may be electrically damaged (unfortunately it is not replaceable; you can verify this by performing the following):
To bypass INK SYSTEM FAILURE message please see the HP Printer Diagnostics Tests file (pdf) for instructions: http://inkjet411.com/?page_id=1813
Verify the permanent built-in PRINTHEADs electrical performance inside this legacy printer model by running the TAP 43 diagnostic test (either one of the procedures below applies to all printers which use HP02 or HP363 ink cartridges): For additional HP02 support information, please visit our HP02 system support page which includes videos of everything mentioned below: http://inkjet411.com/?page_id=1372
A. HP02 ink-series printers with KEYPAD (i.e. keypad numbers 1-9)
Tap 43 PRINTHEAD Health Diagnostics:
Video Procedure: http://inkjet411.com/?page_id=2391
1. Press * and # keys simultaneously.
2. "Enter Special Key Combo" will be displayed.
3. Press 123 to display the 'Support/Service' menu.
4. At 'Support/Service' menu, click the Right Arrow 3 times until Special Reports menu is displayed.
5. Select Ok, then click Right Arrow 2 times until the 'print-mech button tap' menu is displayed.
6. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed. Use the Left Arrow if you need to decrease numerical count.
7. Select Ok. The test page prints.
8. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced (if part is still available). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
B. HP02 ink-series printer models that DO NOT HAVE a KEYPAD:
Internal Test Print:
1. Press the Menu button, press the Right Arrow button to select 'Tools', and then press 'OK'.
2. Press the Right Arrow button several times to select 'Print Test Page', and then press 'OK'. The test page prints.
Tap 43 PRINTHEAD Health Diagnostics - See Video Procedure: http://inkjet411.com/?page_id=2377
1. Turn ON the printer.
2. Press and Hold the "Print Photos" & "Red Eye Removal" buttons.
3. Release both buttons.
4. You will see a new screen that says, "Enter Special Key Combo"... The Key combo is: press and release in sequence the "Red Eye Removal", "Print Photos", and then "Red Eye Removal"
5. Scroll through the menu by pressing the right arrow button until the display says 'Special Reports'.
6. Select Ok, then press the arrow button until the 'print-mech button tap' menu is displayed.
7. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed.
8. Select Ok. The test page prints.
9. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed (unfortunately the PRINTHEAD is not replaceable). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
For additional and advanced HP printer diagnostics, please visit: http://inkjet411.com/?page_id=1813
To help solve other HP02 ink-series printer/printing related issues please visit http://www.inkjet411.com
Posted on Jul 26, 2013
Canon Printer MP250 doesn't want to keep the grayscale ONLY setting.many attempts to use only black ink but it keeps on setting color ink by default. SB001
If you are changing to greyscale before you print, it will only stay there for that print job. You need to go to the printer through the control panel - devices - printer and change it to greyscale. It should stay that way then.
Jul 03, 2015 | Canon Pixma MP250 All-in-One Color InkJet...
Can I print in greyscale when the color cartridges are empty?
For the sake of the printer, they are set up in that way that when you print black it uses a little bit of the other cartridges as well so that the print heads do not clog up, so no, you cannot print greyscale with empty color cartridges.
Jan 13, 2011 | Canon PIXMA iP4700 InkJet Photo Printer
Canon ip4300 color ink empty but I only want black
No, Canon does not have this facility. Also mostly greyscale is not light black but rather a mixcture of the 3 primary colours. You should have a reset/resume button on the printer - hold this in for a slow 5 seconds to de-activate ink warnings per cartridge that is giving alarms. Proceed carefully and only print text that is black so that the colour printheads do not burn out.
Feb 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I do not want to buy color inks. greyscale printing is all i need
Hello Lisa; Your machine can't satisfy what you want, because this machine make for color purpose, therefor, if they run out any cartridge they don't work, same reason if you don't want color printer why don't buy black and white ?
Nov 22, 2009 | Brother Office Equipment & Supplies
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Cannot find how to set so my Brother MFC-4900C will print using only black inc
in control panel, choose printers and faxes. Select your printer and right click. Choose properties. Choose the option 'greyscale'. Then save.
If any of the color cartridges are empty, the printer will not work, even if only black is required.
Aug 01, 2009 | Office Equipment & Supplies
Color ink cartridge out. Won't let me print in black only?
Do this, press and hold the "Stop" button on the printer for 10 seconds that should clear the fault set by the empty ink cartridge.
Jul 21, 2017 | Canon PIXMA iP1800 InkJet Photo Printer
Hi there, I have an Epson DX8450 and would like to know if i can print black without the other colour cartridges. It keeps telling me to insert colour cartriges before i can print. i only have black ink...
Hello weejohnnymc
The printer is likely going to want cartridges inserted (even if they're empty).
Install the used or empty color cartridges. Then go to your printer settings and choose to print by default in "Grey Scale". This will force it to use only the black ink.
If you get low ink notifications from your print monitor, you can either disable the print monitor or disable the notifications. Please, let us know if you need assistance w/ this.
To Set your printer to use Greyscale (black ink only) by default:
START
CONTROL PANEL
PRINTERS AND FAXES
Right Click on the printer In question
Choose PROPERTIES
You should now be at the GENERAL tab
Click on the PRINTING PREFERENCES button at the bottom
Click on the COLOR tab
Place a check mark in the box to the left of PRINT IN GREYSCALE
Click the OK button
Click the OK button again
Please, let us know if this response was helpful for your or, of course, if you have more questions, etc on this topic.
Thank you
BJ
Apr 04, 2008 | Office Equipment & Supplies
Help
Go to START SETTINGS PRINTERS.
right click on the officejet 5600 icon and then click on preferences. On the color tab indicate, print in greyscale & black print cartridge only .Apply , then OK. Reverse process to use color again.
Jan 15, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
1,971 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
