I have read that the "searching for satellite signal" in this model is caused by a defective zener diode. common problem with this model . Does anybody know where this defective diode is locate on the circuit board and its value . The only thing I know about it is SMT.
Quote "I have the RCA DRD430RA Receiver which is putting out 21 volts to the LNB, instead of the proper 13/18 volts. This is causing the receiver not to receive signals from the odd numbered transponders... now...
I am no genius when it comes to fixing electronics, but I know some basics. I have traced the center pin on the coax connector back to the power supply board, and found that it goes to an LM358 Op-amp. I figure this is controlling the voltage to the LNB, and I believe it is bad (BAD LM358, BAD!) :-)
But before I start soldering, I would like you experts 2nd opinion. Here's the voltages at each pin relative to GND:
It looks to me that the "A" side of the Op-Amp isn't functioning, hence the nearly 0 volts on Pin 1. Do I have this right?
I guess I don't understand exactly WHAT the op-amp should output based on the inputs, but I would think zero isn't right!?!?! larrybud2 @yahoo.com" Un-Quote
The "cure" below..
Also from "Larry" Looks like I'm talking to myself again :-), but the fix worked!
The transistor is an NTE55 type, and is the one on the heatsink in approximately in the middle of the power supply board.
Enjoy!
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on RCA DRD430RG:
Solution #2
posted on Aug 08, 2005
Janice - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
"David W. McGaffney" <k @neo.rr.com> wrote in message
The 358 may be bad. The best way to tell for sure is to replace it with a new one. Problems relating to op-amp IC's can be difficult to resolve. Often the IC itself is OK but influenced by other factors (bad resistors, capacitors, circuit board problems, etc).
Since pin 4 is GND, I would expect either a HIGH (source voltage) a LOW (millivolts) or about mid-voltage from the outputs, pins 1 and 7, depending on what the device is being "fed". In this case there are significant differences at the inputs, so the high and low outputs may be correct.
Based on the voltages you give, I'm not convinced the IC is bad, but the proof is in the pudding, so to speak. Replace it, they're cheap.
Mark Z.
