Question about Visioneer OneTouch 9120 Flatbed Scanner
Where can I get transparency masks for my visioneer scanner?
I can't find the ones that came with my scanner, and I need to replace them.
Go to www.visioneer.com
Try Support for your model
They do sell the masks
Posted on Jan 11, 2009
I have upgraded to Windows 7. Where can I get drivers for Visioneer One Touch 8920 Scanner?
You can't. This is an older model, "end of life" per Visioneer, and they never released drivers for any system later than XP. If the XP drivers don't work, you'll need to replace the scanner with a newer model.
Jan 17, 2011 | Visioneer OneTouch 8920 Flatbed Scanner
I need driver for visioneer one touch 5800
Hi
Thanks for using FixYa. Please check the links to download the drivers for Scanner Visioneer OneTouch ---
Drivers for Scanner Visioneer OneTouch
Scanner Visioneer OneTouch Drivers Download
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 03, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
How to scan slides with Visioneer 9520 USB Scanner - it scans who
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
Jul 26, 2009 | Visioneer OneTouch 9520 Flatbed Scanner
Lide 600 film scanner. How does one secure the transparency in the scanner? I can find no slots, grooves, channels in which to slide them.
The scanner comes with a film adapter unit that holds the 35mm film strip. It compensates for the fhinness of the film strip.
You'll have to contact Canon support if you need to purchase one or make a mask using thick paper or a tranparency sheet and attach your film strip with drafting tape (it does not stick aggressively and removes easily.
You might also check with a local scanner repair shop for a used adapter.
Wish the solution was easier.
Apr 27, 2009 | Canon CanoScan LiDE 60 Flatbed Scanner
Need replacement lamp for visioneer 4400
Appears it is not replaceable:
Symptom:
The light has burned out and you want a replacement bulb.
Solution:
Visioneer does not provide internal part replacements.
Contact Support to troubleshoot issues where the light is no longer turning on, and if necessary, Technical Support will provide an RMA number for an exchange while the scanner is within the warranty period.
Need a Replacement Bulb because the Lamp Has Burned Out
Apr 04, 2009 | Visioneer 4400 Flatbed Scanner
How to scan slides with HP 1610
Will you help me help you with a little more information please?
Thanks. When you attempt a scan with your backlight setup are you able to instruct the scanner through its settings and options that you are using a transparency backlight at 6300K? If these options are there, what light temperature options do you have besides 6300 or is that the only one. And are your slides in standard tray or in a plastic jacket? A standard tray is a clamshell device where you lay your slides in frames and when done close and snap the clamshell closed.
Thanks,
Worldvet
Jan 04, 2009 | HP PSC 1610 All-In-One InkJet Printer
How to change lamp in AGFA Arcus 2 flatbed scanner?
http://www.uktsupport.co.uk/scanner/agfa/arcus.htm#a2lamp
  • Turn off the scanner power switch and disconnect the power plug. Wait at least 15 minutes to allow the unit to cool down.
  • Unscrew the two screws at the back of the base.
  • Pull the SCSI board out enough to disconnect the ribbon cable that threads through the opening in the base (on the right).
  • Remove the two screws from the upper portion of the back of the base.
  • Remove the Transparency Option (TPO) from the base.
  • Remove the two screws from the top back of the base. These screws will be visible when the Transparency option is removed.
  • Remove the two screws from the top front of the base and lift the plastic housing off the scanner.
  • Move the carriage optical assembly backward until you can reach the lamp.
  • Remove the two screws from the top of the optical assembly that covers the bulb and remove the black cover.
  • Lift the lamp from the socket, working one end, then the other.
  • Replace the lamp with a replacement lamp. One replacement lamp is provided with the scanner and others are available through Agfa Parts Order.
  • Return the lamp cover the original position and replace the two screws.
  • Replace the plastic housing and replace the four screws holding the housing.
  • Thread the ribbon cable of the Transparency Option through the base and plug back into the SCSI board.
  • Return the board to the base and tighten the two screws. This insures a slack cable that won't be punctured when screws are put in to attach the transparency module to the base unit.
  • Replace the two screws in the back of the base to secure the Transparency Option to the base.
  • Nov 16, 2007 | Agfa Arcus II Flatbed Scanner
    Epson Perfection 1200 Photo Flatbed Scanner Transparency Adapter
    it could be a couple things without looking at it. one, the one you got also is bad.
    two, the bent prints from the first one, may have ruined the interface boared on the scanner.
    three, are you sure you have it setup for the transparency.
    four, the bulb could bad on the transparancy adapter.
    Sep 19, 2007 | Epson Perfection 1200 Photo Flatbed...
    Visioneer OneTouch 9120 Flatbed Scanner Logo
    105 people viewed this question
    Top Visioneer Office Equipment & Supplies Experts
    TomHighRidge
    Alun Cox
    Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
