JVC dr-m10s loading problem
I see that you have addressed this problem previously. My JVC shows the blinking loading. My problem is not solved with unplugging the unit (it has been unplugged about a year!) I have removed the cover and have found 5 "tubular/round" brown objects (CapXon) on the left side (look a little like batteries) that I am guessing are the capacitors. Three are 10v, one 16v, one 6.3v. Two of the 10v are bulged on the top (silver). If these are the blown capacitors, how do I remove the old ones and then replace them with 16v? Do I have to remove the board and solder new ones in?
  • 2,192 Answers
Yes you need to remove the board to change the blown capacitors
Posted on Apr 19, 2017
SOURCE: jvc dvd/hdd recorder model dr-mh20sek
Replace D5103 and D5105 ( Under Heatsink! ). As a precaution replace C5103 and check R6108 and R5109. Any electrolytic capacitors with domed tops should be replaced. This fix also cured machine that flashed the DVD and HDD lamps but had no other functions.
Posted on Jan 28, 2009
  • 374 Answers
SOURCE: My Vip 612, when recording more than one channel
I would call for a technician to come out as it appears the receiver may have been incorrectly set up or is malfunctioning. I suspect that you have a Dish Pro LNB and are using one line into the 612 which uses DPP technology. The short of it is the two are only compatible if two lines are ran to the receiver and the seperator is eliminated. Without being there to test the system end to end it is all speculation. Thanks for using Fix Ya.
Posted on Sep 28, 2009
  • 732 Answers
SOURCE: Intex 1996 LCD monitor with Sanse Power Supply
f htn01, May need aid of 10x inspection microscope to find pesky "thermal-cycle-fractured" solder joint connections. I use an old wwII B&L to do my hunting. Also check the board-side of the electrolytic filter capacitors to see if rubber seal has been forced out of the bottom of capacitors. How old is monitor? Have you taken any close-up (3 inch) digital pic's to document your work? I would not trust ANY CapXon brand capacitors. I use an old Stanford Research Systems SR720 LCR meter to measure and GRADE capacitors. What do you mean by "stays on for a few seconds"?? Is it on for 1 to 3 seconds or 45 to 295 seconds? Will you remove capacitors and have them measured at local repair shop? 12fixlouie
Posted on Sep 09, 2010
  • 19 Answers
SOURCE: Apex dt250, capacitor blown. I would like to know
The DT250 has one or more bad 470uf 25v capacitors. You should replace all four. Look at some of these youtube videos for how do do the replacement.
http://www.youtube.com/watch?v=on_2CP52cW4
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Order 4 new 470uf 25v capacitors from digikey.com P/N P10274-ND
Use first class mail as your shipping method. Will be under 10 dollars total.
Posted on Oct 08, 2010
  • 8457 Answers
SOURCE: I have a problem with the power supply board with
Power supply board have power surge parts,but not totally dead,it just giving to much power some where,that why it keep killing ur fuse.This problems,u must have great electronic skills to track it down.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Power surges are rarely happen,but the surge protector will stop massive power will go the protector when it happen instead all the power will go to the tv itself.
Posted on Mar 16, 2011
Watch tv properly with JVC DVD off
Some philips tv's have a built in aerial amplifier, perhaps if you bought a digital aerial booster it will improve the picture quality.
Apr 05, 2010 | JVC DR-MV1S DVD Recorder/VCR
The display flashes 'LOADING' when finalising after 20 seconds.
How old is your unit ?
After Loading message what are you getting ? any error message .
Try this unplug the unit for 20 minutes and plug the unit after that time this will remove the error .
Oct 19, 2008 | JVC DRMH20 DVD Recorder
Loading keeps blinking Nothing works anymore. even power of no longer works
Check for dried up electrolytic capacitors on the DC-DC converter C5318, C5340, etc.
Nov 13, 2009 | JVC DR-MH30S DVD Recorder
Firmware crashed, unable to get repair in UK
I also have a faulty unit with discs that hadn't yet been finalised. You can access the discs via your PC. I used a program called IsoBuster by Smart Projects. There is a free demo which you can download. Just google it.
As for the faulty power supply, just scrap the unit and DON'T buy JVC again. Eventually, they will have to listen to the economies of scale.........
Sep 18, 2009 | JVC DR-MX1S DVD Recorder/VCR
Jvc dr-mv78
The laserunits in some JVC sets are verry bad,for some sets there are updated units available incl software.
Aug 27, 2009 | JVC DR-MV7 DVD Recorder/VCR
I need a user manual for JVC DVD RECORD/VCR COMBO Model DR-MV1S
I got mine on-line, though I've forgotten where. Do a search using "JVC DR-MV1 manual". If all else fails, I could send you a copy, The pdf size is 8196 kb.
Feb 03, 2009 | JVC DR-MV1S DVD Recorder/VCR
JVC DR-MH30S DVD Recorder Image file
ciao! tutti vittime del dvd rec [jvc dr mh20-]..jvc dr mh 30...jvc dr mh 50..e un risolvere dell problema di LOADING...il mio jvc dr mh30..di 6 mese e roto ..ma trovo risolvere..difetto e nel hdd,160gb..e in corrozione..e roto hardisk,solo sistema operativo.......con softer COPY CLONE PRO..free da iternet.scarica nell cd room..nel avvio dell pc,che sono due hdd,uno rotto ,e uno buono..guarda instruzione dell cd..e tutto ok,per copy di hdd..e tutto ok per legare poi nell dvd rec jvc dr mh 30..ho provato io e tutto ok...ma io ho trovato hdd dell dvd rec jvc dr mh20..e io ho un dvd rec jvc dr30..ce un problema picollo dopo copy cloner,,mio dvd rec mi conosci solo 80gb..ma perche e in origine da dvd rec jvc dr mh20[80gb]..cercho un hdd di dvd rec drm h30..opure jvc dr mh50..per copy cloner,mio hdd,per conosciere 160gb..opure 250gb..atentti problema di LOADING..e nell due alimenti di hdd..e suporte di dvd..sono quattro line..12v..terra..terra..5v....sono simille anche perhdd..anche per suporte dvd..controla nel condizione di LOADING..se non sono precise..voltaggio..persempio..12v=10v..opure 5v....4.2v..e perdita..da un contesatore electrolitica.e asciugato da lavoro fastidiosa.......se aiuto da poco..non lo so aspettiamo nell mio e-mail....arivederci[ agimqosesda@yahoo.com ]
Apr 14, 2008 | JVC DR-MH30S DVD Recorder
Loading
ok, this same problem happened to many other jvc dr-xxxx s, i think the only answer to this would be to get it serviced or just chuck it out. the cause for the annoying "loading" blinking light is a blown out capacitator, inside the machine itself i recomend u to not try to fix it d.i.y.
Mar 13, 2008 | JVC DR-MV1S DVD Recorder/VCR
JVC DRMH20 "Loading problem"
voltages on CN5303 should be 12V and 5V. I found 5V to be2,5....3V.Check input of regulator MM1665A(should be 6V). If 6V ok,remove connector CN5303 and check if 5V ok.If so,here is my way to fix this "loading" problem.(create a new regulated 5V circuit)
Replace C5206 with 1000uF/25V,C5306 with 100uF/25V,isolate anode of D5213 from transformer,
wire one and an half turn around transformer,connect one end to ground and the other to the anode of D5213,remove MM1665A and replace with 7805 on appropriated radiator.
Input on 7805 is around 11,8V reason why you need to install it on a radiator.
Triphasé
Nov 15, 2007 | JVC DRMH20 DVD Recorder
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
