Svchost exe application location error instruction at 0x00d896bc
Referenced memory at 0x00000000. The memory could not be written.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Most memory errors are due to bad programmers who write programs that may try and grab two memory addresses at the same time, if you got this during an application running. Normally just re-booting will clear the program from RAM and should run ok.
    Scholar:
  • 67 Answers
This error is generally caused due to conflict between windows updates and svchost.exe. For resolving this problem you have to download a hotfix from microsoft.com. There are some workaround as well to resolve this issue:
Method 1 loadTOCNode(2, 'workaround'); Leave the svchost.exe - Application Error dialog box open, and then follow these steps. Step1: Check whether settings for the Automatic Updates service and for the Background Intelligent Transfer Service (BITS) are correct loadTOCNode(3, 'workaround'); To do this, follow these steps:
  1. Click Start, point to Run, type services.msc, and then click OK.
  2. In the details pane, locate and double-click Automatic Updates.
  3. Click the Log On tab.
  4. Make sure that the Local System account option is selected and that the Allow service to interact with desktop check box is cleared.
  5. Make sure that this service has been enabled in the Hardware Profile list. If this service has not been enabled, click Enable to enable the service.
  6. Click the General tab, and make sure that the Automatic option is selected in the Startup Type list. Under Service status, click Start to start the service if it is not already running.
  7. Repeat steps 2 through 6 for Background Intelligent Transfer Service (BITS).
Step 2: Reregister Windows Update components loadTOCNode(3, 'workaround'); To do this, follow these steps:
  1. Click Start, click Run, type REGSVR32 WUAPI.DLL, and then press ENTER.
  2. When you receive the "DllRegisterServer in WUAPI.DLL succeeded" message, click OK.
  3. Type the following commands in the Open box, one after the other, and then press ENTER after each command:
    REGSVR32 WUAUENG.DLL
    REGSVR32 WUAUENG1.DLL
    REGSVR32 ATL.DLL
    REGSVR32 WUCLTUI.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Step 3: Rename the Windows Update temporary folder loadTOCNode(3, 'workaround'); The temporary folder of Windows Update may be corrupted. In this case, you can rename the temporary folder of Windows Update. To do this, follow these steps:
  1. Click Start, click Run, type cmd, and then press ENTER.
  2. At the command prompt, type net stop Wuauserv, and then press ENTER.
  3. Click Start, click Run, type %windir%, and then press ENTER.
  4. In the folder that opens, locate and rename the SoftwareDistribution folder to SDold.
  5. At the command prompt, type net start Wuauserv, and then press ENTER to start the Automatic Updates service.
svchost exe application location error instruction - uparrow.gifBack to the top Method 2 loadTOCNode(2, 'workaround'); Follow these steps:
  1. Click Start, right-click My Computer, and then click Properties.
  2. In the System Properties dialog box, click the Automatic Updates tab.
  3. Click Turn off Automatic Updates, and then click OK.
  4. Restart the computer.
  5. Use the Windows Update Web site to install updates manually.
  6. After you install the updates manually, turn on Automatic Updates.
Link for downloading Hotfix :
http://support.microsoft.com/kb/927891/
Download the one which is for your Operating system.
Posted on Dec 27, 2008
Svchost.exe application error
There is a very good chance that you are seeing the affects of a virus
infection,Please scan your system for infection with a good antivirus software (I recommend Quick Heal Total Security you can use a full featured 30 days trial version).
Hope this solves the issue
Jun 24, 2009 | Microsoft Windows XP Professional SP2 for...
How to fix rundll32.exe-Application Error The instruction at "0x009a068f" referenced memory at ''0x009a068f''.The memory could not be ''written''.Click on OK to terminate the program Click on...
It all depends on where the file is located.
The rundll32.exe file is located in the folder C:\Windows\System32 is a system file . In other cases, rundll32.exe is a virus, spyware, trojan or worm! .
Jun 04, 2009 | Computers & Internet
Problem at start-up
Sounds like you have a bad memory module. Test them one by one to discover the faulty one.
May 03, 2009 | Computers & Internet
Application Error
How to Repair this SVCHOST.EXE error
After some investigating into the 0X745f2780 SVCHOST error, it became apparent the problem is a corrupted Windows Update in Windows XP. Follow the steps below to fix this error.
Verify Windows Update Service Settings
  • Click on Start, Run and type the following command in the open box and click OK
    services.msc
  • Find the Automatic Updates service and double-click on it.
  • Click on the Log On Tab and make sure the "Local System Account" is selected as the logon account and the box for "allow service to interact with desktop" is UNCHECKED.
  • Under the Hardware Profile section in the Log On Tab, make sure the service is enabled.
  • On the General Tab, the Startup Type should be Automatic, if not, drop the box down and select Automatic.
  • Under "Service Status" on the General tab, the service should be Started, click the Start button enable it.
  • Repeat the steps above for the service "Background Intelligent Transfer Service (BITS)"
Re-Register Windows Update DLLs
  • Click on Start, Run, and type CMD and click ok
  • In the black command window type the following command and press Enter
    REGSVR32 WUAPI.DLL
  • Wait until you receive the "DllRegisterServer in WUAPI.DLL succeeded" message and click OK
  • Repeat the last two steps above for each of the following commands:
    REGSVR32 ATL.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Mar 30, 2009 | Microsoft Windows XP Professional
SVCHOST.EXE-Application Error
Check this too:
http://social.msdn.microsoft.com/Forums/en-US/vsdebug/thread/287d95a2-8f64-437b-9d76-912febee58fd/
Mar 21, 2009 | Dell Dimension E510 PC Desktop
Svchost.exe Application Error The instruction at ''0x7ffa4512'' referenced memory at 0x81f48b90'', The memory could not be ''written''.
1. Login to macine in Safe Mode. "when you restart your machine press F8 before windows logo appear" and you will see a menu... choose safe mode with networking...
2. Go to control panel and uninstall the programs you recently installed or uninstall the recently install device driver from the device manager.
3. You could do a system restore to a previously known point, it would only exist if you have created it ...go to Accessories-System Tools-System Restore and chose a previous date.
Mar 09, 2009 | Microsoft Computers & Internet
I am unable to do anything on my computer
you got virus, and Trojan on your laptop.
need to go buy a good antivirus software. i.e. symantec, McAfee, etc..........
ask the sales person in the store.
scan the laptop.
Nov 14, 2008 | Toshiba Computers & Internet
Windows Error Code
The instruction at "0x77c2a573" referenced memory at "0x00000003".the memory could not be "written".
Oct 20, 2008 | Microsoft Windows XP Media Center Edition...
Computers & Internet Logo
510 people viewed this question
Alun Cox
David Payne
David Payne
