Is the whirlpool top load washer model LXR6232EQO belt driven or a drive block. I'm overseas right now and my wife said that it fills up with water but doesn't do anything else....Please help
Washer will not drain the water
Posted on Mar 17, 2009
  • 640 Answers
No belt ,,coupling between the gearcase and the motor,,,directdrive..replace coupling
Posted on Dec 26, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
My 5-year old Whirlpool LSB6300PW Top Load Washer will fill with water but will not agitate or spin. There is no sound of the motor even trying to do anything. My husband thinks the motor would be making...
Bonnie,
I was able to fix a similar problem with the same model washer today so see if any of the following helps you.
First, this model is not belt driven; it has what's called a "direct drive" which could be the source of your problem, as it was for me.
Unlike in your case, our washer made a horrific spinning/clicking sound when it was supposed to be agitating or spinning but it filled and drained like normal, and the horrific noise stopped when the lid was lifted.
Because of those two facts, I discovered it was likely the direct drive coupling, which connects the washer's motor to the transmission.
Turns out, that horrific sound was the sound of one of the couplings spinning uselessly after it broke.
After some internet research, I discovered it was a simple matter of getting and installing the new coupling, which was very easy to do with a little professional help via YouTube.
Here is the website of a parts supplier with great schematics and great prices that I bought the part from.
Dan
Jan 09, 2011 | Whirlpool LSB6300PW Top Load Washer
Empty turn on side can be a couplke of things. Check drive transmission and water pump for obstruction/binding and for slippage replace parts as needed.
Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My washing machine has a broken drive belt!
Not a good model number, so I can't be positive on this. All whirlpool top load washers built in the last 25 years are no longer belt driven, they are direct drive, Broken drive coupling is a very common problem. If you have a wp washer older than 25 years with a drive belt, I don't recommend you repair it as there are a number of major repairs at the same time. Outer tub major corrosion, leaks small amounts of water onto the base plate and then into the wig-wag assembly(electrical shock hazard), main bearing-basket drive assembly, water pump bearings and seal fail(this is usually what burns out the belt. Ect, ect. For Repair manuals try Reliable Parts Co. at 1800-666-0313 Good Luck, Appliance Specialists
Dec 17, 2009 | Whirlpool Washing Machines
Kenmore washer (model # 110 24872300) won't agitate.
Your machine has no belt. It has a direct drive coupling. The direct drive coupling between the motor and transmission must be replaced.
May 20, 2009 | Kenmore 24902 Top Load Washer
The washer will not agitate or spin. It does drain the water
Hi, this can be two issues here. Number one would be a busted belt. The next issue would be a drive assembly failure. this consist of the clutch and gear case(transmission) assembly. I would check these areas out. you will find the problem here.
Mar 22, 2009 | Whirlpool Washing Machines
Machine fills up with water
Dear Customer
Please perform the following checks
Please rate this,Thank u
Dec 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
218 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
