Question about ASUS Eee 4G Notebook
Re; card im assuming it has, its a new notebook and everyone said they have them built in. is there anyway i could find out if it has or not? thanks
  • andrea waugh Dec 26, 2008
    yeah it is built in. Any other suggestions to why i cant connect? i have been trying for hours.
  • andrea waugh Dec 27, 2008
    thanx verymuch i will try this x
    President:
  • 1,179 Answers
If it is built in you should see a plug in the back/side that looks like a telephone jack except bigger. If you have this then it's the wired/ ethernet type & you would plug a ethernet cable there going to the router. For wireless there should be a button or option on the laptop that says wireless options. Hope this helps.
Posted on Dec 26, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 26, 2008
    If it is wireless then the possibility could be that the wireless format on the computer is not compatible with the format on the router. Some of the newer formats are not backwards compatible. Check to see what formats your router is running & check the computer to see if it transmits for that format. Other option would be if it is ethernet wired then run a cat5 or cat6 ethernet cable between the router and computer. Another suggestion. Has these computers been networked? If not I would run the Windows network setup wizard on both computers to see if that fixes the problem. Hope this helps.
Hi I have an HP ECS Motherboard. It has a pci exp.1.0 I tried to install a EVGA 01G-P3-N981-TR GeForce 9800 GT 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card, the card is running...
hi,,,
see to it in the BIOS SET up if that card been detect into your motherboard.. the video card must be install through the drivers ..
thanks..
Jan 08, 2010 | Computers & Internet
I have a Toshiba L25 laptop and a D-Lin Air DWL-650 wireless card. I'm not getting the best connection with the wireless card while my other computer has a much stronger signal. I'd like a recommendation...
im assuming its a cardbus adapter right? well that model is a wireless b signal, which isnt very strong, so any wireless g model should have a much stronger signal. it doesnt matter which one it is, as long as its wireless g, which most new cards are. hope this helps, goodluck
Jul 09, 2009 | Toshiba Satellite L25-S119 Notebook
Disable Display ?
You need tp press F2 or Del on startup and enter the bios and look in the peripherals menu, if not there, just look for VGA or onboard graphics and select dissable, but remember there will be a line in the bios to enable the PCI or AGP card as the primary graphics controller, save settings and exit for a restart.
Aug 29, 2008 | PC Chips M789CG (M789CGVIA2000)...
New graphics card seems to be running games slower
hi im wesley waz the games running fine before with the same graphics card or with a different one?
Jul 20, 2008 | Computers & Internet
My compaq presario SR5034X has a graphics rating of 2.2 it has an Intel Graphics Media Accelerator 950 what should I upgrade to to up my graphics score?
im assuming you are using the on board video so a new video card with its own ram built in will improve system prefomance also.
May 22, 2008 | Compaq Computers & Internet
New motherboard and graphics card can only get into bios scrambled graphics any ideas gurus???
when inin safe mode the grapics card will intialize in default mode please reduse the resolution if that doesnt work that means u dont have the orginal driver for the graphics card please find the orginal driver version which is compactable with ur OS versionand ur graphics card
Nov 29, 2007 | EliteGroup P4M800PRO-M Motherboard
Installation troubleshooting with belkin 802.11g
Windows Wireless Network Status window should detect the router; it should broadcast the SSID belkin54g or something similar; you do not need the CD to set it up.
Nov 09, 2007 | Belkin F5D7330 802.11g/b Wireless Adapter
Ethernet not working! Help!
im assuming its not dissabled, if not then go to control panel, network connections and right click on your network card and go to properties then driver and see if there is a code 9 meaning it's faulty or the device is working. if it is faulty then it's part of the motherboard anyway and you will have to buy a pcmcia network card and connect through that instead
Sep 04, 2007 | HP Compaq Presario V2000 Notebook
ASUS Eee 4G Notebook Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
