Question about Sony Cyber-shot DSC-S700 Digital Camera
Flash does not work
Flash stopped working. Camera takes photos without flash. If flash is needed, camera does not work. I have tried turning flash on and off and set to auto. Flash does not work.
  • maryellen597 Dec 26, 2008
    It is a Sony dscs700 camera. I have not seen an error message. When you attempt to take a picture with the auto or on setting, the flash signal dot turns yellow/orange and flashes but the camera does not take the picture. The camera only takes pictures when on settings that do not require or suggest a flash.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Is it DSC-S700 Sony Cybershot and let me know do you see any flash error code in LCD when it fails to flash?
    Upon your reply, will suggest its solution.
  • 10,594 Answers
Ok,
Flash unit is defective and needs to be replaced as per following part number... (if you have camera repair experience then can do it your self because electric shock risk in involve in flash unit handling)
A-1249-950-A ..ST BLOCK ASSY
Above part is available in Part Store.
Posted on Dec 27, 2008
5 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: Casio Exilim S5 camera flash
there are more possibilities...first is that the settings can not be changed cause the flash is dead and the lack of contact make this not be recognized on...
Second it may be a firmware malfunction and in this case you have to download the firmware update and install it in the camera..procedure is explain at download on the support site ..
The last possibility is that the camera is set on a shooting mode that do not allow /require the the flash ...for example bright light ..mode..Check it and put it in normal mode and after that enable the flash ..or ...try to see in the main menu the reset to factory settings and engage it ...This should make all function work if there are no physical damages..
Posted on Jan 03, 2011
oxlena
SOURCE: Samsung S730 camera wont take photos with flash
I have the same problem with the same exact camera. Before the flash stopped working, I was taking pictures and the flash was making noise. Every time it flashed, it'd make a loud snapping sound. It only flashed 3 times before the flash finally kicked the bucket... Now I can't take pictures when the flash is turned on.
I read somewhere to try new batteries because the flash might not be getting enough juice, but I highly doubt that's going to work.
Posted on Aug 13, 2010
jerryg50
  • 1689 Answers
SOURCE: Cannot take a photo in flash mode. when camera is
Did you try another battery?
A weak battery can cause a shutdown.
If it is not the battery, make sure the memory card is not defective.
Beyond this, there is most likely a defect on one of the camera circuit boards. At this level the camera would require service.
Jerry G.
Posted on Jan 06, 2011
ftw1952
  • 10319 Answers
SOURCE: Fuji F30 camera; -Camera takes 35 seconds to
you have a very weak capacitor in the main circuit
Posted on Apr 17, 2011
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
SONY DSC T33 SCREEN STOPPING SHOWING. CLICK SONY DSC T33 SCREEN STOPPING SHOWING. CLICK BUTTON,FLASH WORKS AND IT APPEARS TO TAKE A PHOTO BUT NOTHING SHOWS. ALL ISONY DSC T33 SCREEN STOPPING SHOWING. CLICK...
I just replied your previous question that this problem occurs due to ccd imager chip failure that will be replaced to get live view in camera mode to take fresh pictures.
Local camera repair shop will replace it, let me know if you need part number of ccd imager chip of DSC-T33 camera.
Sep 28, 2010 | Sony Cyber-Shot DSC-T33 Digital Camera
�� When the menu is displayed on the LCD monitor,
pressing the LEFT button makes the cursor shift to
the left tab.
�� When the menu is not displayed on the LCD
monitor, the LEFT button operates as the FLASH
( ) button.
�� Selecting the flash mode
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of
Movie clip mode.
2. Press the Flash button until the desired flash mode indicator displays on the
LCD monitor.
3. A flash mode indicator will be displayed on the LCD monitor.
Use the correct flash to suit the environment.
Jul 23, 2010 | Samsung Digimax S730 Digital Camera
The flash is not working on my Fuji FinePix F402 Digital Camera
If the flash is faulty, it will most likely be to expensive to repair. You can still use the camera, though. Indoor photos will be to dark unless you turn off the flash. Cycle through the flash modes untill you get the Suppressed Flash symbol. Flash mode button is next to the zoom button. Watch out for camera shake when shooting indoor without flash.
Mar 27, 2010 | Fuji FinePix F402 Digital Camera
Nikon S210 flash not working
The flash has been working fine until last night when I tried to take a picture and the flash was set to auto. When I press the button the little red light beside the flash sign lights up, but the camera does not take the photo. When I set it to flash mode, it still won't take a photo. When I turn off the flash, then it does. What could be the problem? Is it in the settings?
Dec 12, 2008 | Nikon Coolpix S210 Digital Camera
My flash has stopped working
Hi
Unfortunately you will either need to replace the flash unit... or if you're unlucky the main PCB. I don't think you will be able to do anything without either of those parts.
I have made my living running a digital camera repair business for several years now, wish I had better news for you about your camera. If we can help with the repair let us know.
Good luck: Darntoothysam com
Thomas
Sep 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Can't take photographs when flash is on
Hi
The powershot s5 IS does in fact have some strange behaviour issues especially on the first rev firmware. For example if you take 15-20 flash photos consecutively without powering down your camera the flash recycle times will increase to about 15sec, so you'll have to wait about 15sec before you can take another flash photo. The work around is to power down the camera and then turn it back ON. Another strange behaviour is manifested by its inability to lock focus after taking a "no-flash" photo, then popping up the flash and trying to take a flash photo. Again the work-around is to power down the camera, pop-up the flash and then power it back up. Confirmed these behaviours in two other cameras of the same model.
Jul 13, 2008 | Canon PowerShot S5 IS Digital Camera
Flash not working
Sounds like a burn out, or a bad lamp.  The flash is subjected to a huge jolt of electricity each time it fires, and breaks easily, especially when hot.   If you are taking many flash photos, you should stop after 15 or so, to let the flash unit cool.
Good luck with Casio, if you are still under warranty.  It will probably mean mailing them the camera for fixing, or replacing.  Sometimes you can take it back to where you bought it for repair.
Nov 28, 2007 | Casio EXILIM EX-Z1000 Digital Camera
Red Flash mark while taking photo
It sounds to me like you are not waiting for the camera to charge the flash when turning the camera on or between shots. It seems you are using 1700mAh batteries and most modern digital cameras are better off using 2500mAh batteries. Your camera was released in September 2006 so it is considered "modern". With 1700mAh batteries, your flash (warm-up) recycle time time will be rather long or the amperage may not be enough to fully charge the flash unit. I highly recommend Duracell 2500mAh rechargeable batteries.
Oct 12, 2007 | Olympus FE-170 Digital Camera
DMC-FX01 Flash Does Not Work
In what mode are you trying to take photos? The flash will not work in certain modes (see the manual), for example the night mode. Or you accidentialy turned on sequential/burst mode (this is mode where camera takes more pictures on one shutter button press). Flash cannot be used in this mode also. I don't have FX01, but on FZ8 the camera will show flash icon in red, but will take the picture anyway without flash being triggered. The second problems seems like enabled power-saving mode, but those 5 seconds are too short for this. But anyway you can check in SETUP menu the settings for power-save. Also maybe the flash is broken and camera noticed it... I don't think this could be a software problem. Either problem with the flash, but more probably just setting of wrong mode.
Jul 24, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
1,226 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
