I have a laptop (compaq presario 2190) i am trying to restore it, i know it had a lot of prblems it was a hand me down. When I turn on the computer it has a screen saying Compaq and then f2 for settings, esc for boot order, and f12 to boot by LAN. If i select f2 or f12 it gets stuck on "entering settings...." , same with LAN option is there any way to fix this problem?
Well try removing all the external devices connected then try booting the computer to the desktop update the BIOS , that should help :)
regards,
Swapnil
Posted on Dec 26, 2008
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
Compaq 2190 will not charge
Buy a new battery, they go bad all the time. I have to replace my Dell battery every 18 months.
Oct 16, 2009 | Compaq Presario 2190US Notebook
Compaq presario v2000 is dead!!!
Well oviously when you dropped it, it had done alot of damage. There is defenently something in there that needs replacement. I can't acctually see the inside of your laptop so i don't know what. Go see a computer pro.
Jun 09, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario C500 cooling fan doesn't turn
I have the same model. Even though the link below is for the Presario C300, the disassembly is identical.
http://vsslfpro.zcce.compaq.com/plmcontent/NACSC/SML/results.htm?SID=3213865&MEID=B2B010DD-9183-475C-9A35-2116DA0AE0D9
just click on fan/heatsink assembly. All the steps that you need to do beforehand are on the left hand side. It's a lot of work, but worth it. Good luck!
Techno Mom
Mar 06, 2009 | Computers & Internet
Wont stay off
sounds like it needs a new power supply.
Feb 04, 2009 | Compaq Presario 2190US Notebook
No voice in laptop presario c 795 tu
try restoring the computer on past restore point
Nov 05, 2008 | Compaq Presario Notebook
Compaq Presario Recovery needed??
If the compaq has not had the hard-drive altered, there is a restore partition. Normally you require recovery disks to start this process, but you can turn the computer on, and press F11 repeatedly to access the partition. I'm not sure what will happen without the recovery disks, but it's worth a try.
I am assuming the Compaq/HP system restore utility in Windows is long gone?
Sep 07, 2008 | Computers & Internet
Restore
Unable to restore computer using restore disk. I am unable to restore computer using restore disk.
Good Luck, Please dont for get to Vote, Thank You.
Dec 16, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 "Doesn't turn ON"
1) Unplug the laptop. 2) Press and hold down the standby switch under the lid in the upper left hand side of the laptop while pressing down the power key. You should have full power startup now. Let me know if it worked..
Jan 27, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
47 people viewed this question
Alun Cox
David Payne
David Payne
