Question about Kenwood KDC-7011
Tuning Radio Have just purchased vehicle with above radio in. Can't for the life of me figure out how to programme radio stations so that they stay in place. Have to rescan each time i turn the darn thing on. No manuals come with, please advise as i no kind of technician.
  • David Ellis Apr 24, 2007
    Dear MrLard
    Thanx for your help here. pse confirm red wire goes direct to battery and yellow to ignition.
    Regards
    Dave Ellis
    Scholar:
  • 94 Answers
Sounds like it's wired up wrong. You need to refit the radio with the memory wire on a permanent live. Check that yellow and red wires aren't connected together, one is main power one is radio memory. Main power should go to the acc on you ignition and like I said the other goes to a permamnet live. The harness should look like this . . . . V
Posted on Apr 24, 2007
  • Philip Rowney
    Philip Rowney Nov 10, 2007
    I'm pretty sure the red is ACC and the yellow is permanent live.
    an easy way to check is to wire up as above, switch on, set a radio station memory up, turn off the ignition an leave for a minute or 5, then turn back on again. If it's wired correctly. It'll still have the radio memory. Otherwise switch the wires over.
    Here's a trick, the ACC wire is often a little thicker.
    I hope I have been helpful.
    Philip
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
Tip
Solution for the stability problem
GE and RCA SR-3 production suffers from an ill-advised change in tuning potentiometer. It causes the tuning to be unstable - the radio is almost unusable due to difficulty in tuning to stations and the radio has difficulty staying on stations.
The value of the pot is a bit unusual - 300k. I have found that a 500k pot, with 470 fixed resistors across each leg (low to middle, middle to high) allows the radio to tune the entire AM and FM bands, although dial calibration is really bad. The tuning voltage high and low pots will need to be adjusted at the very least, and the whole front end will probably need re-alignment.
I have modified at least a half a dozen of these radios this way, Fry's has an appropriate pot but the shaft is aluminum and needs to be machined. The radios are as stable as early production SR-3's, and are fine DX units.
The FM section can also benefit greatly from the narrow ceramic filter modification. I can routinely use the radio for stations over 100 miles away after the modification.
on Jan 14, 2009 | GE Superadio III AM/FM
How Ido tune it l have no manual.Can you please help.many thanks
Radio With Manual Tuning - Alibaba
www.alibaba.com > Automobiles & Motorcycles > radio > radio with
Radio With Manual Tuning, Buy Various High Quality Radio With Manual TuningProducts from Global Radio With Manual Tuning Suppliers and Radio With ...
Help Guide ' Tuning in an FM radio station manually ... - Sony
https://www.sony.co.uk/.../emanual/.../TP0000016777....
Sony CorporationThe headphone cord of headphones is an FM antenna, therefore, connect headphones to the (headphone) jack when listening to the FM radio.
Tuner (radio) - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Tuner_(radio)
WikipediaA tuner is a subsystem that receives radio frequency (RF) transmissions like radio ...Older models would realize manual tuning by means of mechanically ...
[PDF]Tuning into a Radio Station - Onkyo
Dec 16, 2015 | Audio Players & Recorders
How do you assign preselect numbers to radio stations
You can assign radio station presets on your stock VW radio by tuning to the radio station you would like to preset, and then holding down one of the preset number buttons until the radio beeps. You will now be able to access the station by pressing the preset button.
Oct 15, 2013 | Vehicle Parts & Accessories
I have a Phillips under the counter tv/radio. I need to figure out how to reset my preset radio buttons
try tuning into the new station you want then press and hold a pre set button and it should store the new station
May 30, 2011 | Philips Audio Players & Recorders
I knave a teac model ex cd3. Have lost the manual. Can't remember how to reset the radio stations. Can you help?
OK press power on,select tuner button for radio. then select band AM or FM. Then press tuning mode button until you see [manual] in the window. then press the tuning button [arrow left or arrow right buttons] until you get to your desired station.then press program / memory set. a memory number will flash [ say memory 1]. then press program/ memory /set button again to lock in the selection [memory 1] now this is the TRICKY PART. Once the selection is memorized go back to tuning mode Press the tuning mode button until you see manual and i think you can follow the above procedure. If you program AM stations first Then press the BAND button to get FM stations and go back to step one.
Feb 17, 2011 | Teac EX-CD3 CD Shelf System
Radio
Hello george_nutti,
The model number you posted is for a center channel speaker which has no controls, and not knowing the exact model number it's difficult to be specific.
Some Kenwood KDC models allow you to select one of 3 "tuning modes", 1) AUTO1 - Automatic search for stations; 2) AUTO2 - Search Preset stations; 3) MANUAL - Normal manual tuning control. If your Kenwood is one of these models, you need to set the tuning mode to MANUAL. For Kenwood Excelon HD receivers, direct access tuning is done by using the included remote. 1) Press DIRECT button on the remote; 2) Press number buttons to enter desired channel number; 3) Press DIRECT button again to exit direct tuning.
Hope this helps.
Sep 08, 2009 | Kenwood KSC-310CCS Center Channel Speaker...
Need operating manual for Zenith Model Z253W radio
1. Tune the radio to the frequency you want to preset, using the "Tuning/Set" buttons.
2. Press "Time Set" button to enter set mode. Note it says "Preset" below this button, because it is used to set both time set and presets.
3. Select the preset number you want, using the "Preset" buttons.
4. Press "Time Set" button again to exit set mode.
5. Repeat the above process for each preset.
Nov 15, 2008 | Zenith Audio Players & Recorders
Tuning Radio
Users manual is HERE.
The Constant +12 volt wire is the yellow one. Wiring connections begin on page 34.
Best of Luck.
Nov 26, 2007 | Alpine CDA-9857 CD Player
Getting blank radio stations
when you get to the station you want push both seek buttons at the same time the left and the right
Nov 14, 2007 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Kenwood KDC-7011 Logo
112 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
