Question about Panasonic CT-32HX42 32" TV
TV Won't Turn On
We have Panasonic TV model CT-36Hx42F. It was working last night. Now it will not come on. We have unplgged it for 3 hours and checked to see if the outlet was working by plugging in a lamp. The TV, DirectTV receiver, and DVD player were all plugged into the entertainment center's surge protector. The receiver and DVD player both have their power indicator lights on, but not the TV. We have tried to find the TV's reset button, but we have not been able to locate it. Where is the reset button located on this model? What are some other possible ways to fix our TV?
  • teachu97
    teachu97 Dec 31, 2008
    Thanks to all that viewed our problem with our tv set. We ended up calling a Sears repairman to come out to fix it. It was a blown fuse. We had to pay $108. A lot to pay for such a small fuse, but a lot cheaper than a new television set. Thanks again!
  • 647 Answers
There is no reset button - the main fuse has probably blown and needs replacing (6.3A 250 V)
Posted on Sep 20, 2009
Hi My wife was watching our 2002 Panasonic CT36SX12CF model t.v last night, all of a sudden there was a pop noise and the screen went black. The tv would not turn on again. Any ideas what the problem...
hey Al more than likelly it was the fuse that popped if you take the back panel off the fuse is next to the power cord and should take a 6.3 amp 125-250 volt fuse
Oct 31, 2010 | Panasonic CT-36SX12 36" TV
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and...
hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Feb 04, 2010 | Panasonic CT-27SC14 27" TV
Panasonic CT-36HX42F I turn it on and then, turns off
It seems that the electrical relay's, it getting completed is not able to create the high voltage required for proper display. Hence on switching it on, the power LED will immediately light up but since the circuit is not completed it switches to standby and then off. Get the relays replaced and make sure you connect the main power chord to a 15 Ampere rating wiring usually the line meant for A/c and hot water Geyser(called as high power line)..........sodeep
Sep 19, 2009 | Panasonic CT-32HX42 32" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Dead TV Panasonic CT 36HL42CF
have a visitation and bury the next day.
Jul 14, 2009 | Panasonic CT-36HL43 36" TV
Panasonic TV
Good mornig,
Actually, I was helping my son-in-law ... I never got an answer here, and he called a repairman, which fixed the problem, but cost him approximately $300.
Jul 08, 2008 | Panasonic CT-36HL43 36" TV
CT-36HX42F
I had the same problem. Sometimes the processor gets overheated, particularly when dealing with high definition signals. Unplug the television from the power strip or wall outlet and it should reset everything. When you plug it back in it should work. Not a long-term solution, I know, but it will get your TV working again.
May 07, 2008 | Panasonic CT-27SX11 27" TV
TV Has no picture
http://www.bruzziforum.com/vbf/showthread.php?t=79
Panasonic probably uses the same code on your model.
Jan 11, 2008 | Panasonic CT-27HL14 27" TV
3year old Panasonic ct-32sx12f dead?
Sure, Why not? It is worth the effort. If the set is 'dead', it is the easiest to repair.Only 'tampered' sets pose problems. It could be a simple blown Fuse, or the Power Regulator IC. This should not cost you more than $100-150 as Technician charges + 15-20$ for spares. It could also be a defective Horizontal Outut Transistor and short cicuiterd FBT, (tho' it seems remote), but if yes, add another $100. definitely worth calling a professional techie
Aug 22, 2006 | Panasonic CT-32SX12 32" TV
Panasonic CT-32HX42 32" TV Logo
631 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
