Question about Xerox Phaser 7300DN Laser Printer
Xerox 5400 missing letters
I have a used xerox phaser 5400. When I print a document there are letters missing from words, for instance DOCUMENT prints out as " o ument There is no pattern. just missing letters at random.
  • louis1411 Dec 29, 2008
    Tried that. firmware,ps pcls6 still missing letters.thanks though.
    Problem Solver:
  • 8 Answers
Go to the Xerox website go to support and drivers and DL the newest Driver for the Product
Posted on Dec 29, 2008
I have just bought a Xerox Phaser 6500. Prior to this I had a phaser 6125. The problem im having happened with both printers which makes me think somewhere along the line my settings are wrong. If I...
You may have the "separator page" option turned on in your print driver. This option will insert a blank page after each print job to separate one print job from another. Simply uncheck the box by the separator page option and you should be back to normal !
Oct 21, 2013 | Xerox Phaser Office Equipment & Supplies
How do i find info on duplex printing on a canon pixma 4500
This model Canon printer does not have a duplex unit and cannot print double sided printing automatically.
DOUBLY SIDED PRINTING WITHOUT A DUPLEX UNIT
Open your Word document.
Open page 1 - then Print the current page.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will be printedon the other side of the page 1).
Repeat this procedure for the other pages.
May 03, 2012 | Xerox Phaser 4500/B / Phaser 4500/YB Laser...
Xerox Phaser7300dt. After paper jam, the printer keeps printing the same page
That's normal for any printer. It's trying to pick up the printing of the entire document.
If it didn't print the same page again after you clear the jam, you would be missing a page.
Apr 13, 2011 | Xerox Phaser 850DP Thermal Printer
I Have a Xerox Phaser 3100mfp. When I print it is fine. If I print a soduko page for example it is fine. However, if I use either the flatbed or the paper feeder to copy a document a black streak is...
if printing is fine and copying is not then there is something interfering with the mirrors.
if could be nearly anything from dust bunnies to a seal that fell down.
Jan 11, 2011 | Xerox Phaser 3100MFP/S Laser Printer
I am trying to print a document in Word and my Phaser 8560 will print it, but there is a blank section on the page (approximately 4 inches wide running down the middle of the page) where the text did not...
Did the document print in full even though it left blank spaces? I f so the problem is The Page Break Occurred before it actually reached the end of the paper. Check what paper is selected on the printer. I don't mean the tray or paper feeder.
On the LCD screen on the printer go through the menu till you find the paper. Make sure the paper is set to A4 or Letter (whatever you normally use.) and make sure this setting matches with the paper select in the documenent.
Check File ->Print ->Settings or Options .... Find out where the paper is mentioned and select A4 or Letter as the case may be.
Hope this will solve your problem
Good luck
luciana44
Jan 06, 2010 | Xerox Phaser 8560N Laser Printer
Everything prints on left half of page
First, are you using a factory Xerox cartridge and Xerox toner?
As to the document, are you getting the entire document printed or is the document simply cut off as if the printer cartridge is out of position?
Oct 19, 2009 | Xerox Phaser 6180N Laser Printer
Margins and warning window
First i would try to narrow to problem to easier find the issue. Is this happening on all software or only with a particular one? Try with word, outlook, notepad etc. and see how it goes. Try also to set the printer to print only one format (like letter or legal) then setup the software to print only that same size of document... then setup the windows printer to do about the same. Do not forget to change the default print settings in there also. If everything is standard and all paper sizes and types are correct on computer/software printer setup and on the printer itself... then it could be a program/document error. You can aslo try to create a PDF with it and print the PDF to see if it's printing.
Jun 03, 2009 | Xerox Phaser 4500 Printer
Cannot print from Word Perfect 11 or Quattro to Xerox Phaser 85
It is the print setting in WP. As I'm sure you know, Corel products like to take control of everything. If your document is configure to print to an HP printer, for example, it won't print to another printer unless you change it in the Print settings within the document.
Feb 05, 2009 | Xerox Phaser 8560DN Laser Printer
Sending print job from pc to IR5000 prints with missing letters
I doubt it's the copier, sounds more like a application or board problem, my first suggestion would be to re-install the driver. the other would be to target the hard drive or memory/ mother board of the network of the copier
Nov 12, 2008 | Canon imageRUNNER 5000 Copier
Phaser 3200 only printing code, not actual document
Try downloading and installing a PCL language driver from the Xerox.com site for the phaser 3200. It looks like that could be a PostScript issue. Installing the right driver is very important anyway. If that does not help, try and copy paste the document in a new document and save first as the old document could be corrupted. If this does not help either lemme know and I think of something else.
Nov 11, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
708 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
