Question about Fisher and Paykel GWL11 Top Load Washer
Ecosmart gw11 fisher paykel
My washer will not turn on ive check power supply and all that stuff, ive heard there is fuses in the power module but dont know where that is Fisher-Paykel Mod. No. GWL 11 US- Power to unit. No lights on. No water leakage in control module compartment. No rust or water leaking at rear/bottom of machine. Serial number is MAN590844. Was this unit built before July, 2002? Is the roto position sensor need replacing or how do I check it? What about the diverter valve? How do I check it?
  • Floyd Tresler Dec 30, 2008
    I was unable to find any reference to Fisher-Paykel top load washers at site suggested.
  • 10,515 Answers
Try putting the controls into diagnostic mode. The tech sheet inside the control panel explains how to do this but I’ll include an abbreviated procedure here for other grasshoppers who surf into this post.
To enter Diagnostic Mode:
  • Turn power off at the console
  • Press and hold the wash temperature down then press the power button. The machine should give two short beeps.
  • The different levels of information can be extracted by using the spin speed up or the spin speed down buttons.
If the control board won’t enter diagnostic mode, it’s a good bet the control board is fried. Usually, when the control board fails, one of the line voltage components fried and took out the control board, too. Be sure to test the peripheral components before replacing the control board or you could fry a brand new one.
thnx.
Posted on Dec 30, 2008
    President:
  • 2,110 Answers
Check the drain pump. the control board needs a circut through this to power up the W/M on the older type f+p washers , ie: no circut, no go. I dont know the correct resistance ( possibly 1 of my esteemed and very able U.S appliantologist aquaintences could enlighten us both ) but you check it at the board there should be a 5 wire plug on the Lh side of the controller, r.y.bl are the motor wires and the other 2 br + w? are the pump wires.
  • Sibananda Jena
    Sibananda Jena Dec 30, 2008
    With an error code the only way to find to repair this is,
    Try first unplugging the appliance and wait a few minutes then restart it like rebooting your computer when its acting strange!
    If it corrects the problem GREAT!!!
    If not only a trained laundry tech can make the electronic diagnoses.
    Like I used to be able to fix my own cars, but not today they need diagnostic equipment!
    Below I refered you to a great service nation wide!
    If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
    A&E Factory Service
    A&E has schedulers available to take appointments 24/7
    And they do warranty work too, for most manufactures!
    1(800) 905-9505
    You will be fine
    Bless You ngafm1
    PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
  • 100 Answers
Refer the following link under repair top load washer section in the following link for step by step procedure:
www.applianceaid.com
Posted on Dec 26, 2008
Fisher and paykel ecosmart 96193-a wont drain
Fisher and Paykel might be able to supply a repair manual.
May 20, 2014 | Fisher Paykel EcoSmart GWL15
Connecting motor controller in gw11 washer
There is raised print below the socket with the name for the plug that goes in that socket.
Feb 15, 2014 | Fisher and Paykel Washing Machines
Fisher and Paykel EcoSmart GWL15 no power
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens ( or if there was nothing wrong with the breakers/fuses in the first place) sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 22, 2011 | Fisher Paykel EcoSmart GWL15
I have a fisher & paykel ecosmart washer no water
Please make sure that your water supply lines are properly connected and turned on. Also, there are typically small filters at the end of the hoses where they connect to the washer. Check those and clean them if necessary. Since the hoses will be disconnected at that time, flush the lines by running the water into a nearby drain or bucket.
Hope this helps! Rate my solution!
Jan 05, 2010 | Washing Machines
The washer wont drain
Check clear filter //pump
Sep 29, 2009 | Fisher Paykel EcoSmart GWL15
Fisher paykel GW 11, no power to panel.
You will have to check the power from power supply to relay to control panel. You can check for voltage with multi-tester or voltmeter
Jul 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
Hello and welcome. Couple things to check first-
Tip the machine back and look underneath at the water pump, if it is wet or appears crusty/corroded, you probably have a shorted pump that took the machine control out along with it. Sometimes you can just replace the pump but on those models the board can become a casualty. Also look at the control itself and check for water in the pan area underneath it. Sometimes the mixing chamber thermistor leaks and it will short out the machine control. Whenever you replace the control, a new seal should be put on the thermistor. (easy and cheap insurance)
You might want to start with a fisher paykel gwl11 service manual:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=17
Dec 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Power wont go on fisher paykel eco smart GW11
first step is to make sure you do have power to your washing machine.
if you press your power button and you dont get any response,you will find the your electronic have gone.
Its called a power module.
They do have fuses in them.
Jul 31, 2008 | Fisher Paykel EcoSmart GWL15
Ecosmart washer will not stop filling
It needs a new fill valve. These are not expensive and you can easily do this yourself.
Jun 22, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
66 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
