Question about Philips 32PW8608 32" TV
32PW878 don´t replay to the remote control orders
The poblem is in the TV, exceptionally times replay after push any remote control key several times. I check with an oscilloscope the IR receiver and the signal is good until the control board, but in the pin 76 of the SAA5647HL I have some pulses instead of the eceiver signal.
  • Jos? Lo R? Apr 20, 2007
    I changed the remote receiver and it isn´t the solution. According with the uprocesor circuit diagram the pin 76 would be pullup to Vcc until a remote signal appear, but in that pin It is always present a pulsed signal between 1 v y Vcc and, when remote signal appear the change is between 1v and Vss.
    I suspect in a synchronization problem but don´t have any adjustment.
    President:
  • 1,284 Answers
You are checking signals at the micro in the TV set? I would first suspect a noisy remote receiver then before replacing other costly items.
Posted on Apr 20, 2007
My remote won't change from AUX to Tv and all of the buttons don't work on AUX except for the volume and mute, how do I get it back on tv? Thank you
Try to push the TV button that is lit red at top middle of remote for 5 seconds in stead of hitting input. In other words by holding the tv button down it might trigger it to respond better. Thanks Mike
Apr 07, 2013 | Televison & Video
Power is on in standby, but takes several times pushing the power button for the power or tv to actually come on
Very bad for the TV, don't do this!
Got the remote control? Switch on or off (full operation) from Standby with it and just use the main manual switch on the TV for, say, morning ON for the day and evening OFF for the night.
Sep 21, 2011 | Soyo Crystal DYLT032B 32 in. LCD...
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
Don't have remote control how can you get it to
Don't know that fan even thou I sale Fanimation! If it came with a remote & has no pull chains then you can only use the remote feature. You can order a new transmitter, that you would have to match the dip switches in the receiver to. I would need to have model# of fan. www.fanfairceilingfans.com fanman9952@aol.com
Aug 19, 2011 | Fanimation Pedestal in White with Standard...
I have a remote that i have had for a while and it stopped working. I changed the batteries but it still doesn't work. I have the codes for it but i missed placed the instructions on how to set the code....
turn on manually your set (tv), push the code button on your remote control until led light, release the button, the led still ligth. push the tv button one pulse, push the power button several times until tv turn off. when this happen push enter button... try turn on the tv with remote control.
Mar 20, 2010 | RCA Universal Remote Control
Harmony 880 does not change input with Onkyo HT-R520 amplifier
You will either have to use your Onkyo remote to teach the Harmony those functions or try one of the similar model receivers in the Harmony software. I had to chose a similar DVD player in the list in order to get my Harmony to play nice with my DVD player.
Feb 14, 2009 | Logitech Harmony 880 LCD Remote Control
USE MY REPLAY REMOTE FOR AN APEX TV
try 0156. i had the same problem tonight, and found the right code from here:
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
Nov 04, 2008 | RCA 3-Device Universal Remote with...
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
Lost codes for 4 in one used for universal remote control
DRC800 Sanyo TV 0799,0154,0893 Panasonic VCR 0035,0162,1062,0616,0225,1035 press device key for 6 seconds led will blink solid key in code correct code will cause led to blink 3 times press power button to confirm code works. rg
Sep 09, 2007 | Philips 8-Function Universal Learning...
Philips 32PW8608 32" TV Logo
171 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
