Question about Sharp AL 1631 Copier
FEED ROLLER Sharp AL-1631
I have a Sharp AL-1631 and the feed roller is broke. Actually the clutch gear is broke. I can get the parts but need a little help with how to line up but gears so this works right
  • Vladimir Machlis
    Vladimir Machlis May 11, 2010
    Which feed roller? Tray feed or manual bypass feed?
  • 29 Answers
Percision roller phx arizona also have web sight
Posted on Mar 10, 2009
Its a Sharp AL-1631. It'll copy from the auto feed
Check under the scanner, there is a scanner lock that you may have hit removing copies. Its most likely in the locked position and stopping scan.
Jun 03, 2011 | Sharp AL 1631 Copier
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
OUr Sharp Al-1551 copier seems to moan when the paper is feeding. Any idea what it might be? Is there anything I can lubricate? Thanks
Hello sir; Is paper come out with wrinkle, I suggest you need to clean up paper feed roller and pick up roller with alcohal, meanwile check it out the paper path have any thing not suppose to be there.
Nov 06, 2009 | Sharp AL-1551CS Copier
Flashing p and paper will not feed it jams
Clean the paper feed roller under paper tray use izopropilic alcool.
Sep 27, 2009 | Sharp AL 1631 Copier
Paper feed roller continuously rolling
The problem lies in the solenoid and or the frame that hold the solenoid so your feeder roller never stop rolling
Jun 08, 2009 | Sharp AL-1000 Laser Printer
Hello everyone I have a sharp AL-1631 copier and when it starts there is a loud clacking sound coming from the rear drive side of unit can anyone aide me in a resolve?
There could be a few things wrong, but you most likely have a worn out fuser rachet gear, that drives the fusing unit or you may have a worn or broken fuser gear on the upper fixing roller. You can order the parts on line for about $20.00 + shipping. The only hard part is replacing the gears... The one on the Upper fixinfg roller is not that hard, but the rachet gear is kind of tricky... Alot has to come apart and then back togather. It is not hard, but you have to remember where the parts go back too. If you are not very comfortable with taking this apart, it may be a little to much to handel... It, could be just as simple as tighting the fuser screws??? Good Luck..
Apr 18, 2009 | Sharp AL 1631 Copier
Sharp AL-1631
there is severl thing this could be 1. paper feed cluch need cleaned 2-bypayss roller lift arm need removed, 3-or the drum unit need clened out . all thses thing can be dones easilly by a sharp tech about $120 should do it. note this is the only model of copier left that you can refill the toner unit for $6 & drum for $15 ( id keep it )
Mar 10, 2009 | Sharp AL 1631 Copier
Noise when scanning document
Visually check the clutch spring (located on the left side of the pickup roller shaft, just before the gear). If the spring is deformed or broken, replace the entire pickup roller shaft. The part you need to order are shown below. You will also need a small 'C' clip. I do not know if the clip comes ith the shaft or the gear...
PA03360-Y110
Pick shaft
PA03360-Y112
Pick Bearing ‘M’
PA03360-Y107
Clutch
PA03360-Y106
Clutch Spring
PA03360-Y105
Pick Gear
Regards,
Eric F.
Jan 25, 2009 | Fujitsu ScanSnap Manager
Top paper feed jams
if your feeder is jamming you need the roller & pad replaced and usaaly the internal feed roller cleaned this is a repair that should be done by a sharp tech about a $150
Jun 30, 2008 | Sharp AL 1631 Copier
Documents not feeding
There is usually a switch sensor lever in the area where paper is loaded into the document feeder area(near the document feed roller check to see if its not stuck or damaged
Jan 31, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
264 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
