Question about Onkyo TX-SR674 Receiver
The picture via my Onkyo-sr674 has degraded
The picture via my Onkyo tx-sr674 receiver has become pixilated.
When I connect the hdmi cable leading to my Sharp Aquos directly to the back of the satellite receiver, the picture is perfect. But when the TV is connected to the AV receiver, the same picture becomes degraded. It improves after 30 to 60 minutes of viewing but never reaches the same quality as when the receiver is not in line.
Thanks
  • Official Brand Answer
  • 333 Answers
Hello, I am sorry about your issue. It sounds like your receiver may need to be serviced. Please contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you and advise of your options. Thank you, CB
Posted on Jul 11, 2017
5 Suggested Answers
  • 14 Answers
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Posted on Dec 13, 2007
mlapres
  • 757 Answers
SOURCE: Does Onkyo av receiver TX-SR-702 have HDMI
Yes.
Posted on Dec 12, 2009
  • 5 Answers
SOURCE: Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Posted on Feb 12, 2010
bobhifi
  • 635 Answers
SOURCE: I got an Onkyo amp-
If the stand by red light starts blinking after 4 seconds of switching On it indicates an output short circuit. In all probability one of the Amplifiers output stage is defective and to prevent speaker damage the protection circuit is getting activated in 4 seconds. You will need professional help to fix this.
Posted on Sep 11, 2011
HDMI flashing screen on Onkyo TX-SR674 receiver need advice on how to solve this problem
Hi Zach, you can try the following reset as this might be a glitch in the processor.
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings., Thanks, JT
Feb 21, 2015 | Onkyo TX-SR674 Receiver
Cant get new HDMI board for Onkyo TX-SR604
It's usually the hdmi switching IC that goes bad on these. Not something you can really replace without the right equipment and knowledge.
Jul 10, 2013 | Onkyo Tx-sr604 7.1 Channel A/v Receiver...
Onkyo tx-sr674 loss of picture and sound
Change the HMDI cable, might fix the problem, intermittents of this type are very difficult to trouble shoot.
Mar 12, 2012 | Onkyo TX-SR674 Receiver
I have an Onkyo TX-SR605 , I have my ps3 connected via hdmi and from the amp to a 3d tv via hdmi . when i am connecting through the amp the PS3 does not recognise i have a 3d TV and will not play 3d Movies...
No but you may be able to help me. I have the same amp and ps3. I have HDMI leads from both but cannot get sound or picture. I do get the set up menu which means it recognises the HDMI lead. How is yours set up ?
Jan 25, 2011 | Onkyo TX-SR605 Receiver
Onkyo tx-sr875 no sound through hdmi.
Hello, I suggest having your receiver serviced. Thank you, Onkyo USA
Apr 13, 2017 | Onkyo TX-SR875 Receiver
Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Apr 12, 2009 | Onkyo TX-SR705 Receiver
ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Dec 02, 2008 | Onkyo TX-SR606 Receiver
Onkyo TX-SR674 Receiver Logo
54 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
