Question about Maytag SDE2606 Electric Dryer
Dryer wont heat
I have a maytag lse1000 series 10 tested for continuity on all heating related parts including element all test pos for cont i also used a jumper on theses parts and still no heat could the heating element still be the culprit? If so here can we find the best bargain to replace element?
  • 1 more comment
  • landintheval Dec 26, 2008
    Thanks I will try that you want me to disconect the two terminals from the housing and test a high resistance means good or bad? When I used a jumper wire on other heating components that should of given me results of their functionality right?
  • landintheval Dec 27, 2008
    what i did on the other components ex.. fuse and other... is pulled leads connected jumper to leads only turned on to see if heat develops did one by one no heat at any test
  • Thomas F. Schneider May 11, 2010
    The heating element should disconnected for both sides and be tested with a OHM meter and it should read a high resistance. A continuity light will glow even if the element is shorted.
    President:
  • 2,692 Answers
First answer is yes; high resistance is good. I am not sure I understand the second question. The reasion one has to isolate the element is to avoid resistance from other parts. This, I believe , is the most likly problem.
Posted on Dec 27, 2008
Maytag LSE1000 dryer is not heating
Failed heating element or control
Aug 06, 2018 | Maytag Dryers
Why doesn't my Maytag dryer model LDE712 heat. All things related to check have continuity.
Sometimes you have to disconnect elements of the heating system to check continuity ('element's' as in 'parts of').
Can only be 4 things
Element
high limit thermostat
high limit cut out
mainboard/switch
Feb 05, 2016 | Maytag Dryers
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
My maytag neptune dryer doesn't blow any hot air
on top of the heating element on the left side there is a white 2connector part, that is the heater thermal fuse. disconnect the dryer power cord and one wire of the thermal fuse and use a meter to find out if you have continuity to it. if not replace it. also check for burn wires at heating element. also test heating element by disconnecting one wire and using an ohm meter test it at 2 therminals. it shoul measure 10-12 ohms.
Feb 14, 2011 | Maytag Neptune MDE5500AY Electric Dryer
WONT HEAT
Unplug the dryer and the first thing to do is check for the presence of 220 volts at the wall outlet. If you lost one leg of the 220 volts, it is possible for your dryer to run but there will not be any heat. Once you verified there is definitely 220 volts at the wall outlet, remove the rear cover. On the lower right hand side you will see a silver canister which contains the heating element. Remove the lower two wires directly from the heating element and check this for continuity. If it is good, on the left hand side of the same canister they often install a thermal safety which may have tripped. Do the same test as with the heating element. Remove the wires and test the thermal safety for continuity. If this is good, move to the blower housing on the left side of the exhaust vent and look for a white piece of plastic which has two wires on it. Remove these two wires and check this item for continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
Sep 19, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Heat
www.PartSelect.com
Jul 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer wont heat vent clear
www.PartSelect.com
Apr 03, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag dryer is not heat up. I think the heating
Hello, There are a couple of variations of the heating element, depending on the series number of your dryer.
Here's a link to the parts list and line drawing so you can verify the proper element you need.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=SDE4606AYW&productCategoryId=0151200&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00005&componentDescription=REAR%20BLKHD,%20AIR%20DUCT,%20ROLLER&HTR%20(ELE)&documentId=M0510059&blt=06
If you have a Series 14 dryer, the element part number is #37001134, otherwise, there are a couple of other elements that your particular dryer might use, so check the model number and product tag so you can get the right parts.
You might want to check the element first, to make sure it is defective, before you order replacement parts, as it might be a faulty thermal fuse, which is much less expensive to replace than the heating element.
If you have a multimeter, you can check the fuse to see if it's failed. Be sure to turn the power off and unplug the dryer before removing the back access panel and checking the thermal fuse (see drawing in link above)
With the meter set to measure resisitance (Ohms) you can put a test lead on each side of the thermal fuse and if you get a reading showing no continuitity, then the thermal fuse is blown and needs to be replaced.
You can also check the heating element using the same method, again, make sure the dryer is unplugged before testing the continuity of the heating element, if you don't get a continuity reading, then the heating element is bad too.
I hope you find this Very Helpful and best regards!
Nov 13, 2009 | Maytag SDE4606A Electric Dryer
Maytag MDE3757 electric dryer will not heat
If you are testing the heating element your almost there.
There will be several thermostats/thermal cutoffs/etc. in the wiring leading to and from the heating element.
These will have wires plugged onto them.
Remove them and test for continuity between the contacts. They should all have continuity -- if not, that's your bad component.
May 12, 2009 | Maytag Dryers
My Maytag elec dryer does not heat. It is a
You have to use a multimeter to test the heating element for continuity and if that is good, you have to test the other sensors. A wiring schematic is included with your unit, someplace on or in the unit.
May 09, 2009 | Maytag Dryers
Maytag SDE2606 Electric Dryer Logo
311 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
