My Nokia6630 was infected with an unknown virus through blue tooth, since then my phone is getting restarted again and again. As I switch it on and carry on, it unknowingly gets restarted, even if I am online.
Please suggest me a solution or a good antivirus which will remove that virus completely from my cell phone without affecting the data stored in the phone. Please Help Me Out of this Problem.
first you have to format your phone by pressing *#7370#. and then you link to the imserba.com to get a kapersky antivirus for s60 .acturelly i have a installer but don't know how to send it to u can u give me your email adress
Hi, problem can be solved. First, restart the phone see if the blue tooth will come on. Also if the blue tooth doesn't come on,that means blue tooth is corrupted by virus.
Hi,when trying to use a blue tooth and it shows (unable to perform blue tooth operation, Is because the blue tooth is corrupted.
You will need to format phone to restore blue tooth .
Hi, First: better use kasperaskey anti virus. If your desktop pc or laptop has antivirus, have your pc scan your fon memory through bluetooth, or usb cable
OR: If you have Virus On mobile 1 - remove memory card. 2 - dial *#7780# or *#7073* 3 - It format your Phone 4 - Format memory card. and enjoyyyyyyyyyyyyyyyyyyyyyy
OR
FORMATTING PHONE Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone. Read and learn more about flashing and how to flash a phone on this links.
hubpages.com/hub/How-to-Flash-your-cell-phone and unlocktotalk.com/UnlockCodeInstructions.htm),
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
But if it doesn't pair after you've tried the above, that means the blue tooth is corrupted and will need to be flashed to restore bluetooth back. FORMATTING PHONE Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone. Read and learn more about flashing and how to flash a phone on this link.
You can use this link to flash the phone and remove any VIRUS infection on the blue tooth of the phone. The blue tooth is corrupted and will need to be restore by flashing the phone. Read and learn more about flashing and how to flash a phone on this link.
turn off your cellphone, while on off mode,press and hold 3 botton which are call (the green one), asteries ( * ), and number 3. while pressing and holding the 3 botton, turn on the phone. wait for a minute.
note: press and hold the given botton until online mode. select country, date, and time
hey this is happening because there is a virus on your phone..but don't worry connect your phone to a computer (with a good antivirus in it preferably Norton) and scan your phone and delete the infected files.. this generally happens wen you accept a message from an unknown mobile device through blue tooth .. This type of virus also sends sms' to phone contacts. For further assistance feel free to mail me at: [email protected] Cheers Kushal
Turn off ur device. Press 3 buttons, Green (Call), * , and 3
Simultaneously and then Switch on the Device holding the 3 buttons
still. . .dont leave it for 3 mins or so. Without MMC
Ok .. You mobile phone is infected with the virus if you mobile phone is under warrenty claim it or see how to format you mobile phone this will delete all you personal data and your mobile will be back to factory setting . This happens when we recive thing from untrusted source thru blue tooth or it may get infected when you haved added some song from you pc ..
i need an antivirus for my infected nokia 6630
