Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
Zoom Lens (Sony DCR-PC7e) The zoom lens has a life of its own. When you zoom in, it will zoom out again without my touching the switch. When recording, the zoom will suddenly move, again without touching the switch. Thaks for any help! I love this camera.
    Sergeant:
    Champion:
  • 326 Answers
Hello, DCR-PC7E in order to repair this error you should replace the switch block part number: 147383111. Best regards, Arpi
Posted on Apr 19, 2007
  • Arpad Kothai
    Arpad Kothai Apr 20, 2007
    thanks is fine, but please rate this solution.
    Best regards,
    Arpi
SOURCE:
I have sony handy cam model dcr sx43 display showing error e 61 plz reply me.
According to the error code the problem is in lens unit assembly. For your convenience pic is given below.
In this situation camera needs repair by an expert to open the zoom assy and replace the zoom motor.
Thanks.
Oct 26, 2010 | Sony Handycam DCR-DVD201 DVD Camcorder
Camcorder displaying Error 61
this is a lens error code.. In most cases iether the focus or the zoom motor is jammed. Pretty tough to free sometimes . But I useully will try it before ordering one or the other . They may not be available seperately but only as the entire zoom lens unit.
Apr 27, 2010 | Sony Handycam DCR-DVD205 DVD Camcorder
When i turn on the camera, it gives me an error message: the lens cover might be closed - E61:11
The abnormalities in initialization of the focus lens and the abnormalities in initialization of the zoom lens occurred simultaneously (FOCUS OR ZOOM SECTION NOT WORKING PROPERLY)
Mar 29, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony handycam DCR-DVD108 - - error e:61:11
The abnormalities in initialization of the focus lens and the abnormalities in initialization of the zoom lens occurred simultaneously(FOCUS OR ZOOM SECTION NOT WORKING PROPERLY)
Mar 28, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Hi I bought a pro-spec 70-210 lens for my Sony Alpha. When you go to zoom out it doesn't twist. You can pull it straight out...Is this how it should work? The rest of my lenses all twist out
Yes. It's a push pull zoom action.
One touch zooms as used on 35mm film SLRs used to have the same mechanism, the zoom ring twisted as well to achieve focus but now that most lenses are autofocus that's unnecessary. So you have a lens which just retains the push-pull, a far more natural action in my opinion and usually faster than a rotating zoom. Once you get used to it I think that you'll prefer it.
By contrast, most modern zooms have what was considered in 35mm terms to be an old-fashioned twin touch zoom: one ring was turned to zoom the lens and another was turned to focus it. This sometimes meant that after zooming you had to refocus; your push pull zoom will likely have a more technically demanding constant focus zoom action, there will be an additional manual focus control as well, but it's very much a minor secondary control used only when your AF has broken or is switched off.
I hope that my reply has been of use to you, please return the favour by rating my answer.
Mar 03, 2010 | Sigma 70-210/4-5.6 UC II AF Zoom Lens for...
Sony DCR-DVD403 camcorder - picture won't focus. E:61:10 error.
E61:10 is a lens error code. You have a bad lens unit, but sometimes they can be fixed. The focus and zoom motor worm drives on the zoom lens jam when they get dropped. If your really really carfull you can free them up and fix the lens. Thereis a plastic claw that rides along the worm drive shaft that can get jamed. I've fixed thousands of these but i'm a guru. It can be tricky.
Dec 09, 2008 | Sony Handycam DCR-DVD403 DVD Camcorder
Zoom not working E61:10
Zoom motor in camera lens mechanism is stuck due to **** etc. You need to open camera, take out camera lens section and check zoom motor.
Do the above if you know basic electronics and have little experience of camera repair.
If don't, contact Sony Service to fix the camera.
Nov 11, 2008 | Sony DCR-DVD608E DVD Camcorder
Sony dcr trv30 zoom inout problem
Wow, your camcorder is ill... sounds like an issue with the controller chip, This issue can be caused by all kinds of things, like moisture in the enclosure etc... I think this will have to be professionally serviced.
Oct 03, 2007 | Video Cameras
Zoom is stuck
Just check the DC power supply flowing to the Lens block control. Some times the SMD fuse blows off and power may not reach the lens block motor.
Dec 02, 2006 | Sony Handycam DCR-PC105 Mini DV Digital...
Zoom problem
Ive seen this three times and everytime its been something differant. Fist was the rocker switch was jammed. easy fix as dirt was in there. Second was a small serface maounted capacitor in the zoom interface circuit. An third never found the problem as we thought it was a limit switch in the lens itself but the customer never paid for a new lens assy so we didnt order it. Good luck
Jun 21, 2006 | Canon XM1 Mini DV Digital Camcorder
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
158 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
