Question about Xerox XA7-192i 19" LCD Monitor
Xerox XA7 19" 1028x1024 resolution not possible with Nvidia Vista drivers for 8800gs
Though I kind of doubt there is a solution at present, on buying a new PC with Vista was frustrated to find that my monitor was unable to operate at full resolution, no 1028x1024 resolution appears as an option. I have the latest Nvidia driver, and on Nvidia forums others are complaining of the same problem. So far I haven't heard of anyone being able to find a work around. Do you think the problem will be fixed eventually by Nvidia and Xerox? Any idea how long this might take? Anything users can do to make their case known? And basically, should I just throw in the towell, sell my monitor, and buy a different brand that works with Vista and Nvidia? Any suggestions would be greatly appreciated. I knew I'd have compatibilty issues with Vista, but a monitor, give me a break.... Thanks
  • Thanks Babb for trying to help. I've got the latest Xerox driver, and the latest Nvidia driver for my brand new PC with an e6600,2gb ram, a 8800gts and Vista. For some reason the highest resolution listed on the PC display control panel (and the Nvidia control panel)is only 1024 x 768, not 1280 x 1024 which is the display's normal resolution, and which is available with Nvidia driver's and XP. I had hoped to figure out some work around but I've combed the net and nothing, everyone with a XA7 19i monitor is stuck in the same situation. Looks like I'm going to have to wait till Nvidia gets their act together. You'd think Xerox would be up in arms, but when I emailed them all they said was it was a graphics driver fault and had nothing to do with them.
    Novelist:
    Scholar:
  • 104 Answers
Well, if you say you have the latest drivers availble from NVIDIA, have you tried updating the driver for the monitor itself? http://www.xerox-displays.info/driver/XEROX_XA7_DRIVER/XEROX_XA7_DRIVER.zip (the device is in device manager under Monitors i believe) Well aside from that you'll just might have to wait for an updated video card driver! Another question, what is the max resolution that is available on your pc? regards, babb
Posted on May 02, 2007
SOURCE:
Problems with video card driver on VAIO VGN-FZ31M
Vista ... YUK. Try getting the driver from Sony.com Win 7 works well.
Dec 26, 2013 | Sony VAIO Computers & Internet
Video card upgrade Dell Inspiron 530
If anything, it's simply not compatible with your specs. "Vista 32 bit" alone kind of instilled some doubt in me. But who knows, try surfing around Nvidia's site here
You can try their Option 2 to automatically scan your rig and find a "suitable" driver for it, or try the links below on that site "Beta and Older Drivers" and see if any of the other versions work.
Dec 02, 2012 | Dell Inspiron 530 Desktop Computer...
The albatron nvidia ge force fs 500 256 mb compatible with windows 7
A quick check to the nvidia web page (www.nvidia.com) revealed that there are no drivers for this hardware under Win 7. While you could try to install the Windows Vista drivers, I would recommend replacing this card with something more modern. There are many entry-level cards in the under $50 range, (best for casual use or low resolutions) and you can do a bit better in the $75-100 range. Try www.newegg.com or Fry's electronics, avoid Best Buy or Staples, etc.
Feel free to post back if you want specific advice, and describe what game or software you use to help w/ a recommendation.
Please take a moment to rate my solution if I have helped you out.
Thanks and good luck!
Feb 05, 2012 | Albatron nVIDIA GeForce FX5500 (256 MB)...
Display resolution decreases unexpectedly. I find that the resolution is set at max but display settings show multiple monitors. I am only using the laptop display. I can temporarily resolve this issue by...
old compaq Notebooks.
running what OS what windows is there, of the 14 made.
my guess XP on up.? the hp data sheet says VISTA.
is it still running VISTA? still have the HP recovery disks>?
all modern screens and GPU chips have many possible resolutions.
this great benefit allows you to run old APPS that only do low (poor)
resolutions, (i can name some if you ask, some old video players)
the only problem using old laptops is the lack of support after 10 long years, and HP ends that. I';d give on finding HP drivers. this old.
and that Vista support ended this year, HP and at MS.
V1000 to V6000 are now retired. see here for proof
THAT being said, i plunder on and try to find the correct drivers
first I attempt to ID that GPU chip, (i have scanner to make that easy but can do that here can I) so i must google to find the data sheets.
step one is what OS, you never said so the job expands or fails.
Nvidia. GeForce Go 6150 , VISTA
the makers (nvidia )web page is tricky,
ill teach you how to use it , and it is there. link below.
drivers, top box click Gforce
box 2 pick Gforce 6 series
box 3 pick your unstated OS/
box 4 you lang.
box 6 all.
click search and then pick newest WHQL driver.
DL it. run it , use it.
bingo?
https://www.geforce.com/drivers
my wild coin toss , landed me here Vista 32b
https://www.geforce.com/drivers/results/82701
Jul 31, 2017 | Compaq Presario V6310US Notebook
I m using geforce 9400 gt chipset card from zotac. when ver i try to update my driver to a newer version system color scheme will go down to 4bit and it will refuse to change. its working fine with the old...
Hello dimash, you must remove nvidia old drivers before installing latest driver, go to Start> Control Panel > Uninstall a program > Nvidia Drivers Remove, Restart Computer, i found newest drivers for you video card, which operating system did you install on? To Change Resolution Go to Nvidia Control Panel > Display > Change Resolution > Color depth : Highest (32-bit)
Click save driver to your computer, install the driver, don't forget to restart the computer. Here is the links.
Copy and paste link into your browser and press enter.
For Windows XP Professional, Home Edition
1. http://www.nvidia.com/content/DriverDownload-March2009/confirmation.php?url=/Windows/260.99/260.99_desktop_winxp_32bit_english_whql.exe&lang=us&type=GeForce
For Windows 7, Vista 32-Bit=x86
2. http://www.nvidia.com/content/DriverDownload-March2009/confirmation.php?url=/Windows/260.99/260.99_desktop_win7_winvista_32bit_english_whql.exe&lang=us&type=GeForce
For Windows 7, Vista 64-Bit=x64
http://www.nvidia.com/content/DriverDownload-March2009/confirmation.php?url=/Windows/260.99/260.99_desktop_win7_winvista_64bit_english_whql.exe&lang=us&type=GeForce
Good Luck!
Dec 02, 2010 | Jaton NVIDIA GeForce 9400 GT, PCI Express...
The resolution on screen is blurred even though the video card is installed. maybe the card needs an installer and i do not know what kind. can you provide me one?
http://www.nvidia.com/object/winxp_2k_93.71_2.html
this is the most up to date driver they have available for your graphics card at the moment via geforce if for some reason this does not solve your problem it may be as simple as making sure the resolution you have it config for is available on your monitors spec a good idea would be to google prime res settings for your monitor and finding what is suggested if its a more recent problem though hopefully the drivers will fix it for you
Hope I helped
please leave feedback
Thanks
Robb
Apr 02, 2010 | Nvidia GeForce4 MX 440, (64 MB) Graphic...
PC max screen resolution far below optimum of samsung widescreen 2.1" monitor. Can either be adjusted further and how? should it?
I personally doubt you have a 2.1" monitor, since I have only seen 2.1" monitors in cell phones xD. Maybe you were trying to say 21".
Second, try to be more specific. Tell us your OS, graphics card, etc so we might be able to bypass useless questions.
Now to your problem, first of all make sure your graphics card has its latest drivers, if you have ATI or Nvidia card then you should look at their website, or look at your card's manufacturer website. Then, and only then, right click on the desktop and click on preferences (personalize under Vista). Then go to display settings and once there select your resolution. The best setting is usually the biggest resolution that appears on the list, though ONLY if your card got its proper drivers. If not, you will get a bunch of *probably* incompatible resolutions. Hope that helps.
Jun 10, 2009 | Samsung T220 22" Widescreen LCD Monitor
Vista Stetched Screen
It appears that the wrong Nvidia driver has been installed because you cannot change the screen resolution above 1024x768.
o to the Compaq/HP WEB site - support/download page to download the latest Nvidia driver for your version of Windows and model laptop.
Feb 01, 2009 | HP Compaq Presario F750US
Xerox WorkCentre XL2120 Vista Compatable Driver
Here is the answer from Xerox
Windows Vista Note: There are no plans to develop Vista drivers for the Xerox Small Office/Home Office products. Please check with a Xerox Sales Representative for the latest products with Vista support.
Nov 30, 2007 | Xerox WorkCentre XL2120 Laser Printer
Xerox XA7-192i 19" LCD Monitor Logo
611 people viewed this question
Top Xerox Computers & Internet Experts
Aditya Agarwal
saurav777
Level 1 Expert
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
