Question about Kenmore 63942 Dryer
I Have a Kenmore Gas Dryer model #110.74722400 no heat
I checked vents and all are clear. Gas line is open. If it is the ignitor how do you get to it thru the front or the back.
  • ronnyroma Dec 26, 2008
    How do you get to the thermal fuse?
  • 179 Answers
You get to it through the front does your ignitor glow if not check the thermal fuse
Posted on Dec 26, 2008
2 Suggested Answers
  • 1314 Answers
SOURCE: Kenmore Gas Dryer
replace the selonoids
Posted on Dec 30, 2007
My LGB6000KQ1 won't heat up. There isn't a flame at all.
when was the last time you cleaned out the dryer?if the dryer hasn't been pulled apart and cleaned you could have a bad thermal fuse,when you start it and if you listen and don't hear a click most likely you have a bad thermal fuse 3392519.if the dryer runs to hot from no air being moved from a blocked vent line or the lint filter duct is blocked the fuse poops and no power is sent to ignite the flame.if the fuse is good then you have to unplug the dryer and get into the front and read out the ignitor,the gas coils on top of the gas valve and the sensor,there should be a plastic cap on the front panel that pops off so you can look in,does the ignitor blow orange or no glow?if it glows then you have to check the coils and sensor,no glow check the ignitor and the thermal fuse,so check to see if the ignitor glows,if no start it again and listen for a click,no click go for the thermal fuse,unplug the dryer,make sure it's on a flex line so you can pull it out and get at the back,remove the ventline and the back panel,you'll see the metal duct to the left that the lint filter slides into,to the right and down low you'll see a white plastic part,this is the thermal fuse,remove at least one wire and check it with a meter,if you don't have a meter you can connect the wires together,start it and see if it the ignitor starts to glow and then shut it down,make sure the wires don't touch any metal while running it,you should check it with a meter instead of doing this.if it is the fuse you have to clean out the metal duct that the lint filter slides into and if the vent line is long you have to clean that out to with a leaf blower.pull out the lint filter and remove the two phillips screws in front of the filter on the top panel,now remove the other 4 screws that hold the duct in in the back,clean out the duct and vac up any lint in the back,then blow out the vent line with a leaf blower,if you don't do this the fuse will pop again until it's clear.now put it back together but don't put the two screws back on top,also before you blow out the vent line make sure the outside duct isn't blocked with a cover or anything so the lint will blow outside.now go to the front and pop up the top panel,get a screw driver,stick it in between the top and front panel and pop the top,i'll send a video,then you'll see two 5/16 inch screws on the inside a few inches down from the top,one on each side,remove them and the door switch wires,get a small screw driver and stick it into the connector to separate it,and remove the front panel,then remove the belt and drum,if the fuse was good check all the parts in here,ignitor,coils and sensor,clean out the cabinet and blow out the motor,shop vac works best so you can set it up to blow,also blow out the gas tube.you should clean it out at least once a year so your motor will last longer,you won't pop t-stats,your clothes will dry on time but mostly you won't burn down your house watch video.
http://www.youtube.com/watch?v=xGIG8Wo5-N4
hope this helps any other questions let me know.
Nov 12, 2013 | Whirlpool LGB6000KQ Gas Dryer
Whirlpool estate dryer
on the front panel you'll see a plastic cover that you pop off to see if ignitor is glowing,pop it off and start it,also when it starts do you hear a clicking sound,if no click and ignitor isn't glowing you have a bad thermal fuse,when the fuse blows it's from the dryer running to hot,usually from dryer not being cleaned out or crushed or blocked vent line,unplug the dryer,pull it away from the wall,remove vent line from the back,and remove the back panel,your filter is on top so all your thermostats are in the back,look at the left side you'll see the metal duct your lint filter slides into,to the right and down low you'll see a white piece with two wires,this is the thermal fuse,pull at least one wire off and check it with a meter to see if it's bad,while you're back there,remove the four screws that hold the filter duct on and remove the filter and two phillips screws on the top panel,remove the duct and clean it out,if the vent line is a long run go outside and make sure the hood is open,no covers or screen covering the opening,if clear get a leaf blower,stick it into the vent line from where it connects to dryer and blow out the vent line,put in the new thermal fuse,you should also clean out the front cabinet and you should do this at least once a year so you don't have a fire and your clothes will dry on time,if the fuse is good check the ignitor inside the cabinet,if the ignitor glows but doesn't lite check the sensor and gas coils,when the gas coils are bad usually you'll have a flame liting for like the first 15 to 30 minutes then no flame,when the coils heat up they fail,when they cool you'll have a flame again,go here and see parts
http://www.searspartsdirect.com/partsdirect/part-model/Estate-Parts/Dryer-Parts/Model-TGDX640JQ0/3191/0151200?searchedModel=TGDX640JQ&blt=11
go here to take dryr apart
if you need anymore help let me know and if you don't have a meter go buy one,it will be cheaper than changing out parts you don't need,set the meter on say 20k ohms,you'll see a number 1,touch the leeds together and you'll see anything but 1,remove at least one wire from the part you're checking,touch the leeds to both sides of the part,if the 1 stays there the part is bad,any other reading the part is good,it's that simple
May 05, 2013 | Estate TGDX640JQ Gas Dryer
Model 11076832500 runs fine no heat
pop off the cap down on the left side corner of the front panel,start it and look inside,is the ignitor glowing or not?also when was the last time you cleaned out the dryer and the vent line?all the thernostats are in the back of the dryer and inside where the drum is you have gas coils on top of the gas valve,the sensor and the ignitor,if the ignitor isn't glowing unplug the dryer,pull out the dryer,pull out the lint filter and remove the two phillips screws in front of the filter,now go in the back,remove the vent line and the back panel,you'll need a meter to check some parts,you'll see the metal duct that the filter slides into on the left side,next to it to the right and down low you'll see a white plastic part,this is the thermal fuse,pull at least one wire off of any part you're checking,read out the fuse checking for continuity,you can set the meter on 20k ohms,touch the leads together and you should get a reading,now touch the leads to the thermal fuse,if it stays on the 1 and it doesn't move the part is bad,if you get any other reading other than the 1 the part is good,if the thermal fuse is good check the two t-stats on the heater box to the right and the t-stat next to the thermal fuse,and while you have the back off pull off the metal duct and clean it out,you should do this once a year with a gas dryer,there are 4 screws holding the duct on and the two you removed off of the top panel,if the vent line is long i use a leaf blower to blow out the vent line,make sure the outside hood is clear before you blow it,if there's a cage or screen on the hood remove it.if the thermal fuse is bad and you don't clean out the dryer it will pop again until you clear out the blockage.if all the parts are good in the back,put it back together except for the two screws on top,get a screw driver and pop the top panel up,there are two clips one on each side that hold the top panel down,stick the screw driver or putty knife in between the front and top panel and pop it up,disconnect the door switch and you'll find two 5 1/6 inch screws one on each side around 3or 4 inches down on the inside,remove them and then pull up on the front panel one side at a time,read out the ignitor and one of the parts you checked should be the part that's bad,vac out the inside of the cbinet and if you have a shop vac set it up to blow and blow all the lint out of the motor,if the ignitor is glowing but no flame,bad gas coils,sensor or gas valve,the valve doesn't usually go,if the flame lites and then after a while no heat you have bad gas coils,just check the parts with your meter and you'll find the bad part,if you need any more help let me know
Jan 08, 2012 | Dryers
My kenmore 5200 series gas dryer won't heat. My
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Kenmore Dryers
110 74202200 Gas Drier will not heat.Blower works, Drum Turns, Vents all clear. Checked Gas line Gas getting to Drier. Looked at burner: It is clean, no rust, no corrosion, Wires in good shape. It appears...
heatman101
Mar 31, 2011 | Kenmore Dryers
Whirlpool model LGR4634JQ0 Began not heating today. I've checked the timer and have run thru the different cycles. What would you recommend checking to find exact failure of heating.
pop off the cover on the bottom left side of the front panel,look inside with the dryer running,does the ignitor glow?if not unplug it,pull out the filter on top,remove the two phillips screws in front of the filter on top panel,get a screw driver and pop up the top panel,on the sides remove the two 5/16 inch screws,unplug the door switch and lift the front panel off.unplug the ignitor and check it with your meter,if it's good check the sensor to the left of it.if it does glow it will be bad gas coils or the gas valve but most of the time it's the coils,also you can tell if the coils are bad is they will work normally until they heat up and then the fail,so you'll have heat for the first 15 to 30 minutes and then nothing.if all checks good you could have a bad timer or motor but usually it's not that.while you have it apart you should clean it out.with a shop vac vac up all the lint in the cabinet,stick the vac on blow and blow all the lint off the motor and blow off all the gas parts,then go in the back,remove the vent line and the back panel,if the vent line is long blow it out with a leaf blower and go outside and make sure the outside duct is clear.then remove the duct that the lint filter slides into and clean that out.if you do this once a year your dryer will last a long time,your clothes will dry on time and you don't have to worry about a dryer fire.if you need any more help let me know,if you let me know what part you found that was bad i can look it up for you and give you the part number and a price.good luck
Feb 27, 2011 | Whirlpool Dryers
Dryer not geting hot
if there's a bottom panel remove it or if there's a plastic cover on the front panel pop it off with a screw driver so you can see the ignitor,start the dryer,is the ignitor glowing red?if the flame lites for like the first 15 to 30 minutes and then shuts down you have bad gas coils,they fail when they heat up when they are bad or if the ignitor glows but no flame it also is the gas coils or a bad gas valve but most likely the coils,they are located on top of the gas valve,unplug the dryer,remove the two phillips screws that hold the cover on top of the coils,remove the cover and change out the coils. part number for coils 279834.on the larger coil there's a spacer on the post that the coil slides onto,if you don't see the spacer check the hole in the coil and you'll find the spacer,poke it out and slide it back on the post and then slide your coil onto the post,also there are holes in the metal cover that line up with the top of the bumps on the coils if you forget how they go back in.just do one coil at a time so you don't get confused.if the ignitor isn't glowing then you have to find out what part is bad with a meter,it could be the ignitor,sensor that is to the left of the ignitor,or the thermal fuse located on the blower wheel housing.also you could have a bad timer or a bad motor but most of the time it will be the ignitor,sensor or thermal fuse.if you haven't cleaned out the dryer or the vent line in over a year i would go right for the thermal fuse,if the lint filter is on top it will be in the back of the dryer, part number 3392519.if the filter is inside then it is up front,unplug the dryer,if it's in the back look for a white piece with two wires coming off of it to the right of the duct that the lint filter slides into,if it's up front it will be on the right side of the blower wheel housing on top,you have to remove the duct that the filter slides into to get at the fuse, it could be part number 3390719 and it's the one on the left side the other on the right next to it is a thermostat.whenever you check a part with a meter you have to remove at least one wire to get the correct reading.if the fuse was bad you have to clean out the duct that the lint filter slides into,vac out the cabinet where the motor is,if you have a shop vac you can put it on blow and blow off the motor and blow the lint from the back to the front so you don't have to remove the drum and belt.then go outside and check the vent out there to make sure it's clear,go back inside and remove the vent line from the back of the dryer and if it's a long run blow out the vent line with a leaf blower,it will blow out anything that's inside the line to the outside,you should do this anyway even if the fuse is good.if the fuse is good then with a meter check the ignitor and the sensor,you can set the meter,touch the leads together and you should get a reading,then pull at least one of the wires off and check the sensor and the ignitor,when you touch the wires to the part you're checking if it stays on number one the part is bad,if you get any reading then the part is good,change out the bad part,clean out the dryer and you should be all set.it sounds like alot to do but it shouldn't take you no more than an hour to do this,if you clean the dryer once a year your clothes will dry on time,your dryer will last longer and you'll save money on your gas and electric bill and mostly no fires.let me know if you need any more help,good luck and happy new year.you'll save over 200 hundred bucks by going this yourself
Jan 02, 2011 | Whirlpool LGB6300 Gas Dryer
No Heat - Maytag Dryer - Model# SDG3606AWW - Gas Line OK - Clear Vent - Do not see any flame after removing front panel. Igniter glows but then cools down no flame
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 10, 2010 | Dryers
Whirlpool gas dryer model #LGR3624EQ1. Our dryer is not producing heat. Gas line is working and the vent is clear. It has airflow through the lint trap. It also continues to run and won't shut off. ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 24, 2010 | Dryers
Kenmore Elite gas dryer 110.74956300 gets warm but not hot. Air vent is clear.
heatman101
Nov 22, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
297 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
