Question about Vtech Whiz Kid Learning System by
Replacement part fo whiz kid
My son has whiz kid and its pen doesn`t work. i tried to find webside to replace the part but can`t find customer service for uk customers, so for now my son cannot use his game
  • 1 more comment
  • Doms mom Feb 06, 2009
    I have the same problem, only in the U.S. According to the vtech website, the pen is not available any more. It seems that they are discontinuing the product.
  • Anonymous Mar 21, 2009
    need a new pen as well.
  • Anonymous May 15, 2009
    The same problem as aikanyshache's my daughter destroyed the pen while eating a bannana.
Users Manual
Go to www.vtechkids.com. Under customer support, you will see a link there where you can download pdf versions of Manuals for different vtech toys. If you can't find it there, then you need to call VTECH. Contact info can also be found on their website.
Feb 14, 2014 | Vtech Whiz Kid Learning System by
Replacement decals for kid trax c6 corvette
Customer Service i'd contact their customer service
http://www.kidtraxtoys.com/customer-service/
Mar 27, 2012 | Electric Kid Trax C6 Corvette Ride On
Where can I buy a battery for the DX-902 Lil Driver golf cart? My golf cart doesn't work, so the first thing I think might be wrong is that the battery doesn't work. The golf cart sat in our...
Dear kimbroberg2
My husband and I did the exact same thing for our grandson when he was 8 months old. We pulled the car out of the attic last night and the battery did not work. My husband called the manufacturer customer service at 714-256-9888. He was told that the batter was too old and would have to purchase a new one. My husband called around for the item description that they suggested and found a comparable battery at Interstate Battery in our hometown. Good luck. I know we were very disappointed when this happened, but there is hope. Hope this helps.
Jun 28, 2011 | Dexton Kid Racer Battery Operated Ride On...
Hello, When I touch the pen on the pad to play it does not work. Do I need another pen?
Does the sound come at all ? if not then check the speaker inside orr the audio amplifier for failure. However if the sound comes on at start up then the screen should work even with the fingers, if not there is a possiblity of non conduction . Try to remove off the battery and reset. Hope this works. Good day
Aug 16, 2010 | Vtech Whiz Kid Learning System by
Leap frog tag pen won't work any longer.
You can purchase new one from amazon LeapTV Educational Active Video Gaming for Kids. I hope this was helpful. cheers
Mar 03, 2010 | LeapFrog Tag Reading System
Vtech whiz kid learning system has no sound. can use it with the pc, however; takes 15-20 times trying to turn on the unit before the software recognizes it is on. Tried resetting unit...new batteries (3...
My son has a year old Vtech laptop and I can no longer get sound from it. Have replaced batteries but that has not solved the problem. Can anyone help?
Jan 06, 2010 | Vtech Toys
Sharp front panel replacement for 42" LCD t.v. (Black)
I just removed my sticker today, and the sticky adhesive would not come my tv either. I tried alcohol first and to that only worked a little. Then I even tried warm soapy water(thats what sharps customer service told me to do) but that didnt work. So I put a razor scraper inside a rag with soap and water on it and that put little scratches on my new shiny black bezzel which made me very mad. The scratches arent really bad but who wants that on a new tv. FINALLY THE ONLY THING THAT WORKED WAS THE WD-40 NO MESS PEN. YOU RUB THAT ON THE STICKY ADHESIVE THEN WIPE OFF WITH WARM SOAPY WATER, WORKS REALLY WELL ONLY DID IT 2 TIMES. TO BAD I DIDNT DO THAT BEFORE ALL THE SCRATCHES. IF YOU DONT HAVE THE PEN I THINK YOU CAN JUST SPRAY REGULAR WD-40 ONTO A RAG AND WIPE.
Dec 20, 2008 | Sharp LC-42D43U 42 in. LCD HDTV
Im having problems with my sons v tech whiz kid learning system iv installed the cd but i get a balck screen with a notice saying problem with system requirments refer to the v tech manual
Sounds as if your Pc cant handle the requirements of the V-tech kids system,
If you have the box or manual look for System Requirements in index and compare them to your system settings on your pc.
Go to your My computer. And on the left pane their will be a thing that says system information
Check it out and compare notes.
Good luck
Thankyou
Sep 11, 2008 | Video Game Consoles & Games
Computer insists on installing a vaild hardware over and over
uninstall, restart, and when whiz appears choose to install manually. only then insert the CD and install. should work fine now.
Feb 22, 2006 | Sharp FO 2950M Plain Paper Laser Fax
Vtech Whiz Kid Learning System by Logo
206 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
GI Consulting
Are you a Vtech Toy Expert? Answer questions, earn points and help others
