Question about GE 36 in.JGP970 Gas Cooktop
Hello posted this question but family getting antsy without a cooktop. I am installing a 36 inch GE Profile gas cooktop, jgp970, along with a Frigidaire downdraft vent, pl36DD. The gas inlet pipe on the cooktop is over the gear motor cover on the blower requiring the use of a 90 degree elbow. Can I install the elbow between the cooktop and the pressure regulator? The instructions say to connect the regulator directly to the cooktop. There isn't room for an elbow between the regulator and the gear box for an elbow unless I cut off some of the cover. I have installed with the elbow between the regulator and the cooktop, thus the regulator is sideways. and am barely getting any gas flow (only the largest burner lights with a little flame). I installed a 24 inch 5/8 OD flexible line between the regulator and the cutoff valve on the stub. Any thoughts?
    Top Expert:
  • GE Master
  • 53,736 Answers
The reason for the fitting instruction for the regulator to be connected directly is that flex hoses deteriorate and allow a dangerous situation
AS gas is not in the diy domain I recommend that you get in an accredited gas fitter who will make a solid pipe to allow the fitment of the regulator away from the motor
While he is there he can adjust the regulator to get it all working correctly
Posted on Mar 13, 2017
3 Suggested Answers
geemarie
  • 876 Answers
SOURCE: GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Posted on Aug 01, 2008
textonor
  • 130 Answers
SOURCE: Ge Monogram Gas Cooktop - won't boil water - burners seem like they are starved for gas
Bret, lets give this a try. 1st look at the regulator. There is an arrow on it that has to point towards the cooktop. Put is on backwards and very little gas flow. I always advise this first as I have seen people tell me it is correct and when I got out there it was reversed. 2nd was this used as a live demo unit on Propane? If you are on natural gas, this will also happen. The 3rd thing I also check for in something in the gas line on the cooktop side. I had a unit that got some packing in the line and at 5 wc for natural gas, it doesn't take much to restrict. Hope this helps.
Posted on Aug 09, 2008
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    I have a GE 36" Profile Gas Cooktop JGP963 and when i light one of the burners, it trips the GFCI , main breaker and a little fire ball comes from under the knob. what could cause this?
    IT SOUNDS LIKE YOU HAVE A SHORT IN THE IGNITER. YOUR COOKTOP SHOULD BE ON A DEDICATED CIRCUIT AND NOT A GFCI. YOU MIGHT HAVE TWO CIRCUITS TIED INTO THE SAME RUN. POPPING THE GFCI AND THE MAIN BREAKER IS SUSPECT. THE GFCI SHOULD SHUT DOWN THE CIRCUIT WITHOUT POPPING THE MAIN. THIS IS PROBLEM THAT SHOULD BE LOOKED AT BY AND ELECTRITION.
    Apr 04, 2013 | GE 36 in. Profile JGP963 Gas Cooktop
    The flame is too high on my GE Profile gas cooktop
    I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
    Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
    GE 36 inch profile is on but is not heating up. I
    Sounds as tho you are only getting 120 volts versus the 240 you should have. Your breaker needs to be at least 30 amp double pole rating. 240 volt
    Jan 30, 2010 | Cooktops
    I have a GE Profile gas cooktop. The small black pads (feet) under the grates are deteriorating. Where may I purchase new pads?
    Hello. Any store that carries the GE Profile appliances, like Home Depot, can order them for you. Regards, Joe
    Dec 09, 2009 | GE Profile JGP636 Gas Cooktop
    GE Profile Gas cooktop stove- buzzer won't stop
    Unfortunately you have to wait until it dries out. I have tried hairdryer before but most of the time I have had to leave it off overnight. FYI if you dont shut off at the circuit breaker and the sparking continues it will short out and definitely get worse
    Feb 09, 2009 | GE 36 in. Profile JP968 Electric Cooktop
    Poor gas flow to GE cooktop
    Try a bigger inlet pipe sounds like pipe too small for load .
    Apr 11, 2017 | GE 36 in.JGP970 Gas Cooktop
    GE Profile Gas Cooktop, Model JGP975SEKSS
    Buy the Burners for my 36" GE Gas cooktop.
    Jul 09, 2008 | Cooktops
    GE Profile Cooktop JGP933
    you hit the nail on the head remove the knobs and spray wd40 on each area where the valves been removed make sure no flame is present.
    Nov 19, 2007 | GE 36 in. Profile JGP962 Gas Cooktop
    GE 36 in.JGP970 Gas Cooktop Logo
    293 people viewed this question
    Top GE Cooktops Experts
    Marvin
    Marvin
    Steve Allison
    Steve Allison
    Dave Harrison
    Are you a GE Cooktop Expert? Answer questions, earn points and help others
