Question about Canon IXUS III APS Point and Shoot Camera
Canon ixus L-1
The letter h is flashing all the time stopping use of camera in any way
  • 1 more comment
  • yvonne godfrey May 02, 2007
    yes please still need problem fixing
  • rhpositive Jan 30, 2008
    Put in a new roll of Kodak film. The letter "H" started flashing and camera will not function now. Please help. No problems before this.
  • george110 Jan 27, 2009
    Exactly the same problem "H" flashing after loading a new film. Battery seems ok.
5 Suggested Answers
  • 102366 Answers
SOURCE: hi im using a canon digital ixus 9515 camera. can
This camera is designed to store images and videos to a memory card, not to stream them to a computer. It cannot be used as a webcam.
Posted on Jan 15, 2010
  • 11967 Answers
SOURCE: my camera stop working and the lens don´t
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 18, 2010
  • 31 Answers
SOURCE: User Manual for a Canon Ixus 3 Aps Camera
http://www.usa.canon.com/cusa/support/consumer
Posted on Aug 16, 2010
  • 420 Answers
SOURCE: Canon Ixus 900 Ti ~ Lens error Restart camera
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Posted on Sep 11, 2010
How do I set the flash on a canon Ixus 220 HS camera ?
RTM PAGE 85 :>)
IXUS 220 HS - Support - Download drivers, software and ... - Canon UK
https://www.canon.co.uk > Consumer Product Support > Consumer Products Support
Download drivers, software, firmware and manuals for your Canon product and get access to online technical support resources and troubleshooting.
[PDF]IXUS 220 HS
gdlp01.c-wss.com/gds/6/.../01/PSELPH300HS_IXUS220HS_CUG_EN_02.pdf before proceeding with a warranty claim to a Canon Customer Support Help. Desk. For Canon Customer Support contacts, please see the customer support list supplied with your camera. LCD Monitor (Screen). • The LCD monitor is produced with extremely high-precision manufacturing techniques. More than 99.99% of ...
IXUS 220 HS Support - Firmware, Software & Manuals ' Canon Australia
https://www.canon.com.au/cameras/ixus-220-hs/support Download drivers, software, firmware and manuals for your IXUS 220 HS. Online technical support, troubleshooting and how-to's.
http://gdlp01.c-wss.com/gds/1/0300005121/01/IXUS220HS_CUG_EN.pdf
Mar 10, 2018 | Canon Cameras
Can you fit a new flash to a Canon Ixus 980 IS Digital Camera
Canon does not make a separate flash to attach to this camera. The built in flash is only really good for about 6-10 feet away. If the flash that is currently on the camera is not working it may need to be replaced or repaired. The authorized canon facility in New York is Photo Tech www.phototech.com.
Feb 26, 2011 | Canon IXUS 980 IS Digital Camera
Canon ixus 65 - when taking a shot without the flash on, a red camera icon appears on screen and the shot is usually blurry. Why?
When hand-held shooting, shaking will cause blurry. So when the shutter speed below 1 / 60 second the vibration warning will appear, open the flash, up shutter speeds, vibration warning disappeared.
Jan 08, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
I have a Canon PowerShot SD750. I dropped it and the flash not working. can i get a solution for this
Sure: Solution #1. Stop dropping it.;) Solution #2. Send it in for service. Be prepared...it will be expensive.
Oct 27, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon digital ixus 750... problems with flash
Your flash or mainboard are bad, only way to know which is to replace one and see if it starts working.
If you can't find a suitable parts donor camera online please let us know, we can get boards for only about $45.
Thomas D
Owner; Darntoothysam com
Oct 02, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon IXUS 80IS - I can't turn the flash on
When this camera is in "Auto" mode the only flash functions available are Auto or Flash Off - in order to get the option of "Flash On" for all pictures you have to put the camera in "Manual" mode - to do this:
-Set the mode switch to the camera icon
-Press the "Func./Set" button
-Use the left or right arrow keys to set it to Manual mode (its icon looks like half a camera with the letter M beside it)
-Press the "Func./Set" button again to save your mode change.
Now when you press the flash button and cycle through the choices there will also be a "Flash On" option.
Jul 26, 2009 | Canon IXUS 80 IS Digital Camera
Can I recover erased pictures from an Ixus 870?
You can connect camera's memory card to computer, then download this picture recovery program which is outstanding among all picture recovery software.
http://www.001-software.com/picture-recovery/
Jun 17, 2009 | Canon PowerShot S230 / IXUS 179 Digital...
FLASH WONT WORK
non for you to do that is. Canon support may have some advice - if the camera is of any age - then a new camera may be the best bet.
Mar 23, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Animal Eyes
I've seen some of those white eyes photos. Some are down right scary. I'm sure you have encountered red-eye when taking flash photos of people. With some animals, it is not red - but white. .... Try to catch the animal looking away from the camera when you take that flash picture. Have someone distract him/her. ............ Fixing Demonic Pet Eyes http://graphicssoft.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=graphicssoft&zu=http%3A%2F%2Fwww.myjanee.com%2Ftuts%2Fpeteyes%2Fpeteyes.htm http://graphicssoft.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=graphicssoft&zu=http%3A%2F%2Ftlbtlb.com%2Ftlbimages%2Fmax2.html
Aug 31, 2005 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon IXUS III APS Point and Shoot Camera Logo
159 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
