Question about Apple iPod nano
Nano will not play music display is continously shown
I turn my nano on and it will only so my display it will not play music. It appears to to back to the playlist when I try to select a song it will not play the song.
  • Anonymous Jan 28, 2009
    did you ever find a fix for this? i have the same problem.
    Scholar:
  • 96 Answers
Hi All,
You can try this by connecting it to your desktop computer USB port at the rear of you desktop
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step
Posted on Feb 04, 2009
My ipod nano has frozen
  1. Toggle the Hold switch. To do this, slide the switch toHold (an orange bar appears) and then slide it back (orange bar ishidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • Ifthe Apple logo appears on the display, connect the iPod to a computerand verify that it appears in iTunes and can play music. If the iPodappears in iTunes and can play music, no further troubleshooting isneeded.
    • If the Apple logo does not appear or the iPodis not seen in iTunes, connect the iPod to a power source by eitherplugging it into an Apple iPod USB Power Adapter or directly into acomputer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer is not set to sleep, standby, or hibernate.
  4. Afterthe iPod has charged for at least 20 minutes and while it is stillconnected to the power source, toggle the Hold switch again as in step1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, the iPod should be serviced.
Jul 28, 2009 | Apple iPod nano 3rd Generation
The Screen on my 4gb Nano only shows 'white'. Nano will play music, but I have no idea how to select the music I want. Thanks
Just go through with following link and try to play tutorials video http://www.apple.com/itunes/tutorials/
and try to unplug and replug the 4gb nano.
May 05, 2009 | Apple iPod nano
Apple ipod nano wont play the full song
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Jan 05, 2008 | Apple iPod nano
Music will not play, just cycles through songs without playing
I just had the same problem with my 2GB silver nano. I had to restore the factory settings through iTunes and reload all of my music. There was also an update for the nano that I downloaded yesterday (Jan. 29, 2006) and installed when I restored the factory settings. My nano appears to be running fine for the moment,but we'll see if this actually took care of the problem.
Jan 29, 2007 | Apple iPod nano
FRozen !pod
Hi cholo, -Turn the hold switch on and then off. -Hold down the menu and middle button until the Apple logo appears, usually about 6 to 10 seconds. -If that doesn?t work repeat the process and you should be good to go. -If that didn?t work try plugging you Nano into your computer using the USB cable Let us know if you have any more questions and please don?t forget to rate the posting.
Jan 16, 2007 | Apple iPod nano
NaNO 2G Skips music Mp3 Sometimes Stops
In a mater in fact it could be the mp3 the mp3 was copy right protected so it skips and doesn?t let you listen to them.
Nov 02, 2006 | Apple iPod nano
How do I use the stopwatch on iPod nano?
"iPod Software 1.0 for iPod nano introduces a Stopwatch feature. You can use the Stopwatch as you exercise to track your overall time and, if you're running on a track, your lap times too. The Stopwatch menu is located in the Extras menu. To access the Stopwatch from the main menu, select Extras, then Stopwatch, and then Timer (Extras > Stopwatch > Timer) to see its display. Total time of session Current lap time Left button (Start function shown)1 Battery indicator Right button (Clear function shown)1 The left and right buttons' names and functions will change, depending on the current state of the Stopwatch. Using the Stopwatch When you first enter the Stopwatch screen, the left button is labeled Start and the right button is labeled Clear. To use the Stopwatch, select the Start button (use the Click Wheel to highlight the Start button, then press the Center button). The Stopwatch creates a new session, and both the total time of the session and the current lap time begin counting: When these counters begin, the left button changes to Pause and the right button changes to Lap: If you select the Lap button, the current lap time will be recorded in the session's log, then the Stopwatch resets the lap time to zero and begins counting the new lap's time. The total time of the session will freeze for 5 seconds after you select the Lap button so you can quickly view your total time at the end of that lap. After 5 seconds, the total time of the session displays the correct total time and resumes counting. If you select the Pause button, both timers will stop counting and the left and right buttons will change to Resume and Done, respectively. If you select Resume, both timers will begin counting again. If you select Done, the Stopwatch records all the final times and creates statistics for your session in a log. Please note that selecting the Done button does not reset the display. You will see the final times for your total time and lap time displayed: To reset the display, select the Clear button (appears after you click Done and then select Timer again). Stopwatch Behaviors You can play music and use the Stopwatch at the same time. When iPod nano displays the Stopwatch screen, the Play/Pause, Next/Fast-forward, and Previous/Rewind buttons control music playback as usual. If you're playing music, you'll see an icon in the upper-left corner of the Stopwatch screen that indicates the current playback state: A play icon indicates that music is currently playing. A pause icon indicates that a song is currently paused. You can use the Menu button and the Click Wheel to navigate to other menus without interrupting the Stopwatch. Note: The Stopwatch will prevent your iPod from sleeping if it's counting. The Stopwatch will automatically stop if any of these three conditions are met: The total time counter reaches 24 hours iPod goes into hibernation (you can start it again when you wake iPod) You conne
Sep 28, 2005 | Apple iPod nano
Apple iPod nano Logo
32 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
