Question about Reddy Heater RH125T Kerosene Forced Air Heater - 125,000BTU
I need a wiring diagram for a Reddy Kerosene Heater Series 125T
  • 188 Answers
Here is a link to a owner's manual for a RL125T ... http://12.153.20.74/manuals/110429-01C.pdf. You can find a wiring diagram on page 19. I hope this helps you.
Posted on Apr 13, 2009
Need to find pump pressure & nozzle part # for reddy heater 125T
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 05, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a Reddy heater 125T and the transistor for the ignition is burned into, i was wondering if it is possible to solder a new transistor to the board, and if so what would be the part number for the...
Yes, I have done it and got transistor from a electroic story. took old one to them and they match it. When soldering it on use very little heat not meld the other solder tracks. Ken'Repair
Jan 22, 2011 | Reddy HEATER RH125T 125,000-BTU...
Where can I find a manual for a Reddy Heater 125T?
Pretty sure this is the manual as i think DESA make them.
http://www.fncuthbert.com/pdfs/masman1.pdf
Just cut and paste this link
Aug 29, 2010 | Reddy Heater RH125T Kerosene Forced Air...
I have a reddy heater 125t.Is there a parts dealer in the dallas, fortworth area.
Sears or Home Depot sell products and parts ... other than that.. hard to find
Jan 30, 2010 | Reddy HEATER RH125T 125,000-BTU...
IGNITER SWITCH
If you have one of these 125T Models- RH125AT, RHD125AT, RL125AT, RM125AT, RE125AT, M125AT, PKHD125T, TKU125T, UKU125T, RD125T
The web address is:
http://www.reddyparts.com/
There are 3 ways to order your part.
Dec 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Fuel filter
take the side cover of and you will see where the fuel line goes into the tank. typicall the cap turns clockwise to remove and the filter is hooked right to the cap.
Jan 26, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
RH125T won't fire
Not much to check. The element comes out and makes a square loop back to the ceramic portion. This element is extremely brittle and will break if touched or wiped off.
You can check the 2 wires with a voltage tester set on continuity. The needle should swap sides if the ignitor is intact. I don't ever remember an ignitor failing, except for breakage.
View this page. Be sure you get the correct ignitor. 2 different ones have been used on the RH125T.
http://www.reddyparts.com/125T%20ignitors.htm
Dec 28, 2008 | Reddy HEATER RH125T 125,000-BTU...
Won't light
Are the ignitors intact? In other words, does the element make a loop back to the ceramic portion. The purpose of the LED is to notify the user of a defective ignitor. The other possibility is a bad control board.
If the ignitor is intact, but no power coming from the board (ignitor only glows for 5 seconds), then the board is bad or the fuse is blown. You might want to test the photocell while you are at it.
You will need to locate the correct model numbers to order the correct parts. "170T" & "125T" are only part of the correct model designation.
Post back if you have further questions.
Oct 23, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
527 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Superior Maintenance
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
