Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson Sx200- Paper wont feed
Recently purchased an epson sx200, and the paper will not feed and it says 'paper not loaded correctly.' After trying, I have managed to print two pages off but they were creased and i cant even manage to do that now.
  • 1 more comment
  • craftwithus Jan 01, 2009
    Exactly the same problem, all suggestions fail and I am taking mine back for a refund. Where I work we sell these and have had several returns for the same reason.
  • Anonymous Mar 08, 2009
    There is no way of telling whether the paper is in right or not until it prints. Then it is usualy too late
  • Anonymous Mar 12, 2014
    EPSON LQ2180 WONT FEED PAPER FROM REAR
Just a thought,as I had a similar problem.The instructions are abysmal,but it may be worth having a look where you feed the paper in and squeezing the grey plastic gizmo,and moving it to the left to allow the paper to enter the feed properly.
Posted on Dec 28, 2008
You need to squeeze the grey paper feeder and slide it to the left of the paper width.
Posted on Jan 28, 2009
  • 31 Answers
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a19
Posted on May 24, 2009
Cannot install sx200 driver
Hey Silvia WAterhouse,
This link will get you the download for the sx200 driver. When you go to run it however, be sure to right click and "Run as Administrator".
If that doesn't solve the issue, try here
Good Luck
Jul 29, 2012 | Epson NX200/SX200/TX200
How do i print onto acetate using an epson sx200; it doesn't recognise any paper... thanks
Some printers use a light sensor to tell if paper is loaded or not. If printing on clear acetate, try loading a regular sheet of paper under it. It should pull the acetate sheet through and leave the regular paper in tray. Since the Epson sx200 is an inkjet printer be careful not to smudge. I would allow a good 5 to 10 minutes to dry. Good luck!
Mar 01, 2011 | Office Equipment & Supplies
Epson Stylus SX200 Begins to print and then stops!
Sir,
You are suggested to Claim the warranty of your Printer if vaild till now. If not then it would need bit of a service. And sir let me inform you that With new printers the cartridges you get are just Sample and have 1/3 ink then new cartridges.
Oct 15, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson SX200 refuses to recognise compatible cartridges
Hi Howard,
Bottom line, if the printer doesn't accept them, then they are not compatible... I'd recommend returning them for a refund and find a supplier that has tried and tested cartridges.
I'd love to be able to recommend a supplier but as I don't have an SX200 I can't... Others might be able to help if you can indicate where you are in the world as the SX200 is, I believe, zone specific.
Best of luck
May 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Need manual for Epsom stylus sx200
Hello!
Have you tried www.epson.com or if no luck there try my favourite site www.cnet.com if it isn't there there will be a link, Cnet's never failed me.
Press the blue button if satisfied with my Free effort, Thank You!
Paul 'W' U.K.
Feb 05, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Jammed paper
Removed the new paper from feed slot, pressed the on button which allowed the `grabber` to release the jammed paper slightly and then was able to [with the aid of long tweezers] remove the jammed paper through the feed slot.
Regards
Geoff
Feb 04, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Paperfeed on sx200 epson
The rubber grabber has got out of position.
Switch printer off.
Take all paper out of the feeder, put your hand in and you'll feel a rubber semi-circle, rotate (push) it toward the back of the printer until you can feel the rubber part disappear, load paper and switch the printer on and it should reset itself to the correct position.
Sometimes you have to press down slightly on to the paper weight sensor to unlock the grabber.
Try it and see how you get on.
Nige
The INK Store
http://www.the-inkstore.co.uk
Jan 09, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
1,765 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
