Question about LG LH-D6230 System
'Where can I get an LG optical pick-up for the LG LH-D6230 DVD player?
My DVD player is about 4yrs old and I'm just not ready to get rid of this one for my kids. I'm having problems with the player not being able to read any dics. The error will come up as "Disc Error". Then it will open up and do the samething over and over again. Is there any way to fix this?
  • 1 more comment
  • Anonymous Dec 17, 2007
    Suddenly I am facing the same problem of 'Disk Error' while reading the DVDs. It used to read the same DVDs. Is that DVD format issue ?
  • Rajaram Apr 05, 2008
    I am a novice in repairing electronic items. How do I clean laser?
    Thanks a lot.
    Raja
  • Anonymous May 02, 2008
    Hi - my DVD has been in the cupboard for a year as I moved house - finally set up the speakers and plug in - "Disk Error". When I moved it was 100%. Can anyone advise?
    Many thanks.
    Gerard.
    Problem Solver:
  • 17 Answers
Easy and inexpensive to repair. not laser at all. disks are not spinning at the correct speed, clean the round rubber seal that pushes against the disk with 100% alchohol.
Posted on Jun 15, 2008
You only need to clean the laser nad the problem is gone:)
Posted on Feb 20, 2008
This is coming up time and time again... I bet it still reads some of your old disks.. Truth is the industry has changed the DVD format...and refuse to admit that older players have to be replaced.... If they deny this they are lying... DVD formats HAVE changed
Posted on Jul 31, 2007
SOURCE:
Tip
LG LH-D6235 Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | LG LH-D6230 System
LG DVD player LH-D6230 - displays "dvd error" soon
Eprom corruption. Replace eprom, and edit in mode service.
Jan 07, 2011 | LG Audio Players & Recorders
Cannot record t.v. programmes after the changeover on video
I put the recorder channel on AV2 and then recorded it. It worked. Thank you anyway.
Dec 29, 2009 | Samsung SV-DVD55 DVD Player / VCR Combo
Audio playback
1.bad rca jacks
2.could be connected to wrong audio lead rca jack
3.the settings in dvd player donot match the receivers example- dts or ntfs
4.make sure its regioned to your player some audio isnt on the disks
5.pc's usually have new cd formats that came out
cd's and dvd's for some reason in this age isnt being able to play fully in older equipment do to the change in cd/dvd formats which makes you go out and buy new equipment it happened to me not just 2 weeks ago bought a new dvd and found out it wouldnt play in my year old dvd deck had to go out and buy new dvd deck then disk and all my others played fine
May 11, 2008 | LG LH-D6230 System
Resetting the progressive scan mode on an LG lh-d2645 home theatre system
the above is correct but you need to have the dvd player on with no disc in so "no disk" is shown on the front display. then hold down the stop button for 5 secs to reset the display mode back.
Jan 20, 2008 | LG LH-D6230 System
Lg LH-D6230. How to hook up? PLEASE HELP! NO INSTRUCTION MANUAL!!
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
Jan 16, 2008 | LG LH-D6230 System
LG LH-D6230 DVD
I had a similar problem coming from South Africa to Australia and had to change the regional code setting.
Change to multizone format:
1)Ensure no disk in unit
2)Unplug unit from AC supply
3)Plug unit back into ac supply
4)Use remote control for the following commands:
5)Press the power key, the unit will come on
6)Wait until no disk appears on the display
7)Press sequentially the keys: PAUSE;3;1;4;1;5;9
8) "Code" will appear on the display
9)Press 0 (multizone)
10 Press sequentially the keys: PAUSE,POWER
11)The unit will turn off(standby mode), leaving the new regional code programmed. If you do not succeed at the first attempt disconnect the unit and repeat the above steps (1 to 10)
Hop this helps
Susan
Jan 12, 2008 | LG LH-D6230 System
IS POSSIBLE TO UPLOAD DIVX PROGRAM (PATCH) ON IT ??
Try this:
http://www.videohelp.com/dvdhacks?dvdplayer=D6230&hits=50&Search=Search
Apr 18, 2007 | LG LH-D6230 System
LG LH-D6230
The life of LG optical pick-up is Aprox.1000hours if it is more then 1000 hours used then just replace optical pick-up.
Feb 07, 2007 | LG LH-D6230 System
LG LH-D6230 System Logo
659 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
Mike Duncan
Mike Duncan
pankaj rautela
pankaj rautela
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
