Question about Logitech Z-5300 Computer Speakers
Can the cable ends be converted to fit a DVD?
I do not want to hook the system to my computer but would rather have it hooked to my DVD or big screen TV. The ends of the cables are not the correct kind to fit in the DVD or TV. Can I purchase a cable to convert the cable to fit?
  • JoAnn Renshaw Apr 20, 2007
    Thank you for all your input! My TV is a Toshiba Model #57H83. The DVD is a COBY DVD-R1280.
    Is it better to have this hooked up to the DVD player or the TV?
    Thank you again.
    JoAnn
  • 944 Answers
You can certainly purchase a cable or an adaptor to connect the speakers to almost anything - this however is not the issue - z5300 computer speakers have an impedance of 8 ohms, whereas most home theatre systems will be set up to use speakers with an impedance of 4 Ohms or 6 ohms or 8 ohms - using the wrong type in the wrong configuration is very likely to result in damage. Also the speakers contain their own amplifier, and are designed to accept an input that has not been amplified to speaker levels before - most tv/dvd audio output will be amplified, depending on the model, so will almost certainly destroy your speakers unless you have a low amplification output on your tv/dvd. If you post back with the make and model of your tv and dvd player, hopefully i can find the necessary info to describe how you could make the connection if it is possible. Logitech says; "Logitech speakers are powered speakers and are designed to be used with a home computer. However, it is still possible to connect your speakers to many other devices. You can connect any Logitech speaker to any device that has a pre-amp mini-headphone jack. Home amplifiers will normally contain a standard ¼" headphone jack. You'll need to purchase a ¼" to 1/8th" adapter to connect your Logitech speakers to a home amplifier. Note: Under no circumstances should you connect your Logitech speaker system to an amplified output such as the rear outputs of a home amplifier. Doing so may cause damage to your Logitech speakers as well as your home amplifier." Hope this helps - please post back with details :)
Posted on Apr 19, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Apr 20, 2007
    Here is the user manual for your tv;
    http://tacpservice.toshiba.com/ConsumerP...
    check page 15 on the top right - those are the connections for an un-amplified audio output signal - if you get the appropriate adaptor for these RCA plugs then your system should work fine but you will not get true surround sound - each speaker will be giving the same sound.
    In order to get true surround sound, you will need an A/V receiver or amplifier with that function which will probably come with its own speakers
    Unfortunately coby do not have a manual online for your dvd player - contact them direct if you want more info but i suspect that the tv is the best bet as described;
    http://www.cobyusa.com/_en/support_main....
    Hope this helps you out :)
I just want to know how to hook up a hdmi cord to an old big screen hitachi tv
You can't, at least not directly. Older sets don't have any HDMI inputs, only composite video (the yellow RCA jack) and possibly component video (red, green and blue RCA jacks). Converters that take an HDMI input and generate the necessary video outputs are available, but they aren't cheap. And don't fall for the adapter cables you might find advertised with an HDMI plug on one end and RCA plugs on the other that supposedly convert the signal for you. HDMI can only be converted with some active electronics; a simple cable just won't work. If you want to hook and HDMI-only device to your old Hitachi, you'll need the converter.
Dec 28, 2010 | Computers & Internet
The converter box is hooked On the TV and working. I have the TV with the rabbit ears and only video n audio in the front (yellow n white). I recently purchase a DVD player n I am trying to hook it on the...
you have to change the input on the tv to AV. there should be an input button on the remote, but if your remote doesnt work you might not be able to change the input. you can try to use the channel up and down on the tv and once you get to the end of the numbers, some tvs will change inputs before restarting the number list. make sure you hook the yellow cable to the yellow plugs on the dvd and the tv and either of the red or white ones to the white one on the tv. red and white are left and right audio and the yellow one is the video
Dec 24, 2010 | Insignia Digital-to-Analog Converter for...
Hook up
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
I have an older TV with only an antenna hook-up, a VCR, a DVD recorder and a converter box that I would like to hook all together. I can get the VCR to work, but don't really know how to hook the DVD...
Try this. You will need 2 RF cables and a RCA cable that has a red, black, and yellow plug on each end.
  1. Plug the antenna signal into the converter box.
  2. Connect the RF output (TV out) of the converter box to the RF input on the VCR
  3. Connect the RF output (TV out) on the VCR to the TV
  4. Finally, plug the DVD recorder into the converter box also, but use the 3 RCA cables that came with it (audio left, right and video).
Apr 13, 2010 | iLO DVDR05 DVD Recorder
How do i connect my xbox 360 to a big screen tv like the box ones,with a rf modulator?
Hello there:
You will need the red/yellow/white video cables and just hook up the yelow and white up to the xbox and the other end yellow and white to the tv than turn the tv to channel 3 and this should work
best regards mike
Jul 30, 2009 | Dynex RF Modulator AV Signal Converter
I cant get the router hooked up.
Sounds like your PC does not have a PCI Network card. You can purchase one from NewEgg for <$20, or for a little more your local Walmart/BestBuy etc will have them.
Example of what you are looking for:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2052810027+1128209687+1162810711&QksAutoSuggestion=&Configurator=&Subcategory=27&description=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
Once purchased they are easy to install.
Jun 16, 2009 | Linksys WRT160N Wireless Router
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
How to hook up a subwoofer to my computer?
i to have that sub and i hook it up to my dell 1501 i use a mini steroe plug it has two input so you can hook up two device get two y cables on one end it will have a plug like your headphone plug on the other end has two male the ones you hook up at the back of your steroe the other cable is a y cable as well this one has two female end and steroe end to hook up to the sub connect both wires to become one male to female one end goes to the computer the other end the sub you cant do it wrong there is only one plug that will fit hope this helps .
Jan 12, 2009 | Jensen JW250 Main / Stereo Speaker
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Is it possible to hook this system to my DVD
If you have RCA outputs on the Logitech Z-5300 then just plug the rca leads into your video or tv's audio out's
Apr 18, 2007 | Logitech Z-5300 Computer Speakers
Logitech Z-5300 Computer Speakers Logo
301 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
