Question about Jenn-Air 24 in. DW861 Built-in Dishwasher
DW86OUQB Jenn Aire dishwasher not getting any water when turned o
Turn the dishwasher on and sounds like it is running, but no water and dial does not move.
  • wuranl Feb 06, 2009
    same as described
SOURCE: GE roll around dishwasher
check to see if water is in basin. If so remove with dry rag until dry. Then run. If water is in basin, float will trip to stop inflow (flood precaution)
Posted on Feb 15, 2008
SOURCE: GE Nautilus Dishwasher No water when i turn it on
You need to prime the dishwasher by placing two large cups of water into the bottom.
Posted on Jun 18, 2008
SOURCE: Jenn-air Dishwasher won't drain water from base
This happened to me after installation. they had installed a one way valve backwards in the drain line and had to reverse it.
Posted on Jan 03, 2009
GM Elec
  • 1000 Answers
SOURCE: no water coming into dishwasher
There are a couple of things to check. First we will start with the water level float. Open the door and on the floor of the washer, left side, front you will see what looks like a large cap. This is the water level float that tells the dishwasher how much water is in the bottom of the unit.
Check and see if you can push it down closer to the floor. If it is stuck in the up position, the washer "think" it is full of water and will not allow any more in. If it seems to be all the way down, pull it up and out to make sure the stem is not broken or it looks damaged in any way. Check the float chamber for debris or anything that looks like it doesn't belong.
Clean the assembly and chamber as necessary.
Let me know.
Regards,
Posted on Jul 21, 2009
  • 464 Answers
SOURCE: Jenn Aire dishwasher will not empty at end of
you may have something stuck in the drain pump or in the filter. you will have to do further investigating. could be a piece of broken glass or food debris not allowing the water to drain out properly. try this first and see how you make out.
Posted on Oct 24, 2009
My jenn aire dishwasher sounds like it is chewing up rocks
You might have something in the drain pump. To check you need to pull it out from the counter and remove the hoses from the pump to see. First turn off power to it, and make sure you have enough slack in the water line to pull out
Mar 23, 2011 | Jenn-Air JDB6510 Built-in Dishwasher
I have a Jenn aire jdb8910aww dishwasher and after every type of treatment and cleanser I still cannot get the powdery residue to go away. The only thing that works is white vinegar, but i have to use it...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Oct 15, 2010 | Jenn-Air 24 in. JDB8910 Built-in...
2002 Jenn Aire used to wash and rinse beautiful, now doesn't rinse properly leaving detergent film on everything. Using Cascade Liquid which always worked fine before. Glasses are new so it isn't mineral...
Reduce detergent quantity. Check the rinse aid dispenser and fill if required..
Finally check your inlet water free flow to the machine. If the strainer is blocked clean the part.
May 21, 2010 | Jenn-Air 24 in. JDB1080AWS Built-in...
I have a 15 year old jenn aire dishwasher that won't turn on.I t worked fine yesterday and i've had no problems with it,just won't turn on today. Checked fuse,door blockage,etc
yes you have to take the front panel off on the bottom and you also need to have a mutimeter to check for power if you are not accustomed to working with electricity please call a technician
Apr 29, 2010 | Dishwashers
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Nov 18, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Jenn Aire dishwasher will not empty at end of cycle
Oct 24, 2009 | Jenn-Air 24 in. DW731 Built-in Dishwasher
Our Nautilus dishwasher won't turn on. I can hear a buzzing noise, but nothing is happening. Does anyone now what I should do?
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Feb 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Does not advance to drain cycle
I would bet that it is the timer switch assy.
Motor runs ? yes
washes? yes
drain tube clear ? yes
If there is no drain valve to deal with, the problem must be the contacts during the timer cycle, since the main obviously works or you wouldn't be able to wash anything.
you need a new timer switch assy.
Oct 05, 2006 | Jenn-Air JDB6510 Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top Jenn-Air Dishwashers Experts
Marvin
Marvin
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
