Question about Tools & Hardware - Others
Looking for a manuel for a makita belt sander model #9401
Looking for a user manuel for a makita belt sander model #9401.
need to know how to replace the belt.
  • hillgirth Apr 13, 2009
    I can not hold back the front roller so I can install the sanding belt
There is a black metal ******** one side that is actually a lever and with the tip of a screw driver or the like, pops out and releases the front roller.
Posted on Nov 24, 2009
I have just purchased a Makita 9401 belt sander however, have no manual and it is unclear how to change the belt. Any help would be appreciated.
Thanks
Joe
Posted on Mar 15, 2009
  • 2,176 Answers
Go to Makitatools.com and in their search block type in your model number and you can either look at a breakdown or the operators manual. Hope this helps. Dave
Posted on Dec 26, 2008
Hi I want to replace the bearings on my makita 9401 belt sander Are they easy to change
This separator tool is neccesary to get the bearings from the armature the other parts have needle bearings and sinterbronze bearings , with a grinding machine its much more work to get them off And more chance of damage.
Feb 05, 2017 | Makita Tools & Hardware - Others
I have a Makita belt sander,just replaced belt tensioner system including springs and roller but belt drive roller still keeps stopping on relatively light load even though the motor is running
very good trade tool
how quickly is it getting hot
slowing motor could be the cause
motor bushes and bearings can be replaced
did the motor drive belt under the cover get replaced
Jun 02, 2016 | Makita 9911 Compact Lightweight 3" X 18"...
How to install drive roller on my makita 9401 belt sander
DONT forget to order and replace also allways the sinter bearingbus on the machine because to protect you from a dissapointment because otherwise the belt will turns off and cant be (good) controlled again , replace the drive roller allways and clean the front roller axle if its only dirt on the front roller use a little sillicon grease film on the front behind can use a little bit more sillicon grease between the axle rings and new bearing bus. remove the dry grease in the driving gear space and renew the lubricant in it with a multipurpose grease .
Sep 04, 2014 | Makita 9404 4'' x 24'' Belt Sander
What are the dimensions of the plain bearings on the back roller of a makita 9401 belt sander?
Go online to images. Type the sander model etc and there are parts diagrams shown. Just order the bearings from a Makita agent and save time and trouble.
Aug 15, 2014 | Tools & Hardware - Others
Parts for makita palm sander BO5010
Replacement parts can be found easily on amazon, click here Amazon com makita palm sander parts and take a look. Best of luck. Fred
Aug 26, 2012 | Makita Tools & Hardware - Others
My makita 4"X24" sander makes
http://www.ereplacementparts.com/makita-9404-belt-sander-parts-c-97_103_535.html
I would say you have a bearing going out ether on the motor this web address will take you to a good break down of the housing I would say you need a motor bearing it will also give you a parts # but if you have a bearing supplier somewhere ( I look in yellow pages for electrical motor repair) you might find the bearing for a cheaper price just remember to take the old one with you so you are sure to get the same size. I have found bearing and belts for my table saws are the same as for some clothes washers for about 1/2 the price as ordering from sears
good luck
Pat
Oct 29, 2010 | Makita 9404 4'' x 24'' Belt Sander
Brushes on my sander are wearing out within 10mins
the armature could be the problem, when you replace them do you notice a lot of arcing around the commutator, it might be bad or just need to have the surface cleaned. let me know.
Jan 22, 2010 | Makita 9404 4'' x 24'' Belt Sander
HOW TO CHANGE THE BELT ON A BELT SANDER
There is a lever on the side of the unit, flip the lever and then slid the belt off.
Jun 13, 2009 | Makita 9404 4'' x 24'' Belt Sander
The belts on my Makita 9304 belt sander are wearing unevenly
check the wear plate on the bottom and also check the front roller for being out of round is where I would start. Let me know if doesnt help
Feb 17, 2009 | Makita 9404 4'' x 24'' Belt Sander
Tools & Hardware - Others Logo
881 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
