Question about Vivitar 283 Flash
Won't turn on.
Unit doesn't turn on. Have cleaned contacts as well as I can, and checked batteries. Any suggestions for better contact cleaning...or other advice?
  • Anonymous May 06, 2009
    I have same problem Will the WD40 treament
Soak the internal contacts of the battery holder with WD40 electrical spray and leave for a while say an hour it will not harm the electronics but wipe suplus off after giving further cleaning with fibre tipped pen available from most electronic firms the contacts have to be very clean as I found with my flash gun Vivitar 283 and I nearly give it up for lost after the above it is now working fine
Posted on Feb 01, 2009
  • vairnut62 Dec 20, 2010
    Ah..Yes! I just came across this answer. I just noticed little greenish deposits on internal contacts inside the battery holder. I am glad I didn't throw my good faithful flash unit away! Thanks! Steven
Bose remote RC-25 won't work anymore
Check the remote control for its infrared emission. Check it with fresh batteries. Check it battery contacts, inside its battery compartment for any rust or dust accumulated, which prevents the electrical contacts. If all are found OK, you remote control need cleaning. To clean it, you have to open it. If you wish to know more details about how to clean and check a remote control, check this link.
Feb 17, 2013 | Bose RC-25A Remote Control for Lifestyle...
Westinghouse tv remote doesn't work
1) replace new batteries with the same tipe alkaline
2) see the polarities are wrong
3) clean the contacts batteries with c. cleaner
4) retight the spring contacts batteries with l plier for better contacts
5)open the r. control clean the keypads from dirty, corrosion, oxide and bad contacts.
6) reset the code
7) try again, if the problem persist go to the repair shop TV for fix it.
God bless you
Oct 15, 2012 | Westinghouse Used Original UW40TC1W Remote...
W-72 remote won't work
1) change by new batteries alkaline
2) clean the contacts batteries with isopropyl alcohol
3) tight the springs contacts for better contacts with pliers
4) open the remote control, and clean the keypads switch from dirty, oxide, corrosion.bad contacts, or open contacts. This will NOT trasmitt the infrared signal to the receiver.
5) Otherwise you must go to the repair shop TV for fix it
see the block diagram
Jul 26, 2012 | Casablanca Fan Versa Touch2 W-72 Remote...
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
I have a Nikon N65 and put new batteries into the machine. I can't seem to find a thing wrong with it but the screen won't turn on. Any suggestions?
If there's a battery check button, try that to see if you're getting power elsewhere, or see if the functions inside the viewfinder are working. Check to see if the battery contacts are dirty or corroded. If so, use the eraser of a pencil to clean them. If that doesn't help, there's either a dead circuit, or a loose contact and you'll need to contact a repair tech.
You can either contact Nikon directly, find a local reputable shop if you have one in your area, or if you have to go through an online dealer I'd recommend KEH Camera (KEH.com)
Sep 03, 2011 | Nikon N65 35mm SLR Camera
Remote does not work unless I am in the garage. Outside the door it will not work.
hello emar... check to be sure that the little wire antenna is hanging down from the back of the garage door opener motor. Then check it. If it still won't work from outside, install new batteries.
If that doesn't do it, remove the new batteries and use the eraser end of a common pencil to clean the battery contacts inside the remote. then reinstall the new batteries and try it again.
May 04, 2011 | liftmaster 83lm Billion Code 3-button...
I zoom, shuts off!
Before you arrange a repair try these steps: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 28, 2010 | Kodak EASYSHARE M1063 Digital Camera
I have Kodak EasyShere V1223 It won,t Turn on, Go
Here are the steps for V1223 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 17, 2010 | Kodak EasyShare One Digital Camera
My cellphone keeps turning itself off and then back on again when i try to connect to the internet
THis is all I have found so far... bear in mind that the phone will probably use more power when on the intenet
The battery doesn’t charge properly or the
phone sometimes turns itself off
• Wipe the charging contacts both on the phone
and on the battery with a clean soft cloth.
I suggest you try a WHITE pencil eraser to clean battery contacts and then clean again with alcohol, ethanol, methylated spirit etc then air dry before turning off
Jul 01, 2008 | Samsung Cell Phones
Vivitar 283 Flash Logo
286 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
