Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Crisper Drawer Freezing Food in Kitchen Aid KBF042FX00
My refrigerator is 14 months old and has started to freeze food in the two crisper drawers on left side.  I have tried adjusting temperature in fridge but that does not help.  This is a 42" with freezer on lower half.  The drawers are above the ice making section in the freezer.  Any suggestions?
Sea Breeze
  • 4655 Answers
SOURCE: kitchen aid refrigerator freezing in refrigerator
Could you look inside the door near bottom outside frame of fresh food side and get the model numbers for me to assist you better. Also if you have a way to check the temperature as you change settings on the thermostat for the fresh food section. We need to see how the thermostat responds to changes in settings. If no changes then we need to focus on the thermostat. Also there is duct that comes from freezer that can have a damper opened or close to different settings. Let me know the model and I will pull up the drawings for your model. Thanks Sea Breeze
Posted on Mar 20, 2009
erpaalai
  • 999 Answers
SOURCE: my kitchen aid Superba 48 the meat drawer is
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KSCS25INBL01&productCategoryId=0165000&brandId=0593&modelName=COUNTER-DEPTH-REFRIGERATOR&diagramPageId=00003&componentDescription=REFRIGERATOR%20SHELF%20PARTS&documentId=W0606038&blt=06
Eric
Posted on Nov 21, 2009
woodchuck789
  • 4070 Answers
SOURCE: food freezing in fridge compartment in my side by side
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Jan 26, 2010
ZJLimited
  • 17970 Answers
SOURCE: Problem with our KitchenAid Superba
I heard about this problem in LG models, I know that isn't the brand but could helpfull like clues; apparently the problem is the main control board (in LG models). According to the technician that came out to fix, there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer.
I had done a fair bit of research before calling your technician service, and came to the conclusion that this was a common problem. If you have underwarranty, called.
The service tech also told they that all refridgerators made after 2001 are required (by law), to have an electronic mother board which in all likely hood will fail at some point prior to when you are ready to buy a new fridge.
Hope helps.
Posted on Mar 31, 2011
ginko
  • 19396 Answers
SOURCE: water is collecting at the
Hi.
There is a drain hole inside the fridge. The drain hole brings water out toward the evaporator. The drain hole is plugged, probably because of iced water inside the thin drain duct.
Check inside the fridge and locate the drain hole at the back. Usually the hole can be unclogged performing a complete defrost. A faster way is using an hairdryer. In that case the operation needs attention. Hairdryer on cold settings does not defrost in deep inside the hole. On hot you risk to damage the fridge panels. Better removing the food and performing defrost.
If defrost is not enough the drain hole must be unblocked using a thin flexible shaft or a copper wire.
If you have an US or Canada model you can find exploded view using the link below.
Parts sellers.
Posted on May 18, 2011
Kitchenaid 25 cu. ft. side by side is freezing food in the refrigerator side(meat drawer and crisper)
Have you checked the temperature setting for the fridge? It may be set too low. There also may be an adjustment on the drawer for the crisper that can be adjusted (typically a slide adjustment.
Dec 05, 2014 | KitchenAid Refrigerators
Crisper drawers freezing
probably defrost problem.
Oct 14, 2013 | Refrigerators
Food in crisper drawers freezing
HI. UMMM I WOULD DEFROST ALL FIRST.24/48 HOURS.AND TRY.MIGHT BE PARTIALY BLOCKED WITH ICE IMPAIRING CIRCULATION.GOOD LUCK.ALI
Jul 05, 2012 | GE (GTS16BBS) Top Freezer Refrigerator
The food in the refrigerator drawers (crisper and meat) are freezing and the waterline froze. What is causing this and is it worth repairing?
I have Ge GSS25XSQA SS side by side and the food in the refrigerator drawers (crisper and meat) are freezing. Also the ice dispenser is frozen closed. The water dispenser still works.
Want can I do to fix it. Would dirty coils have anything to do with this?
Terry
Nov 10, 2010 | GE GSS25SGPSS Side by Side Refrigerator
Fridge is freezing food
Make sure nothing fell below your crisper, deli drawer section. There are some air return vents below them and if they get partially obstructed would allow cold air to pool in the bottom of the fridge.
Make sure your freezer control did not get turned up too high.
Also you may want to check with the manufacturer as they did have some issues with some of the bottom mount models exhibiting this problem and they developed a repair kit for them.
Jun 11, 2010 | Amana ABB1927DE Bottom Freezer...
Freezing in left crisper drawer.
If you have had a DOE upgrade the fix is availiable from LG
Here is the service buliten # CREF20090877.
Contact LG @ 1 800 243-0000 for repair.
In the mean time remove crisper dware and look on the back wall of the ref. you will see a dime sized hole on the center tower. Cover the hole with tape and reinstall crisper.
Jan 19, 2010 | LG LFX25960 Bottom Freezer French Door...
Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Dec 04, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Refrigerator freezing food on rear of shelves, deli drawer
have your thermostat setting in the right setting otherwise it will happen again and again. have someone to check it like authorize repair shop or technician
Sep 21, 2017 | KitchenAid Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
303 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
