SD Cruzer mini will not work with Vista
Hi...
I put a bunch of my files from Win 98 SE on a SD Cruzer mini, and they say that I am missing a exe. file to open it on Vista. Sandisk Customer Service said to use another machine.
Thanks for some better advice, I hope
Bob
    President:
  • 2,692 Answers
Transfer the files using another computer onto a CD or DVD as data ,the put them onto yournew computer. Your disk is Mini USB 1.1 and likely the new computer is a 2.0 and it ashould be backward compatable but from what they told you they know that it is not. .
Posted on Dec 26, 2008
My Sandisk 'Wake up your phone' adapter & the micro one won't let me add music or anything else. It says that the disk is write-protected. Help?!
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 10, 2011 | SanDisk 2GB microSD Memory Card
I have a 2GB micro sd card,but when i check it into my cellphone,my memory card is error.What is the problem of my memory?
All you have to do is:
Step One:
Step Two:
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
Oct 07, 2011 | SanDisk 2GB microSD Memory Card
When I enter my memord card in nokia 311 it say the operation is failed and the memory card is not formatted.how to remove virus from my memory card and replace my music and Image.
Step One (save data)
When do the data recovery process, you can find the cause of damage to the micro SD.
Cause of the damage the virus infected (solutions: see method 1)
When saving data, be careful, do not recover the virus file. You must choose the proper file for the recovery.
Cause of the damage bad sectors (solutions: see method 2)
Damage to the partition table (solutions: see method 1)
Micro SD write protect. Characteristics: (solutions: see method 3)
1. Micro SD can be opened, the data can not copy and paste (from the micro SD into a computer, or from computer to the micro SD). When the format, the message "Removable media write protect".
2. Micro SD can not be opened, and when the format of the message "Removable media write protect".
Step two (repair micro SD)
Method
Method 2
Method 3
Oct 02, 2011 | SanDisk 2GB microSD Memory Card
Hi I bought a SankDisk Cruzer Edge 4GB and I tried to run it but I can't. It says that I must install RunSanDiskSecureAccess-Win.exe, but it doesn't let me do that because it immediately opens a...
The Cruzer drive comes with its own enabling software (the program name you mentioned). You should be able to view that drive using Windows Explorer (to view the files). Then right-click on the RunSanDiskSecureAccess-Win.exe file and select "Run as Administrator". This should execute the program and allow you to utilize the drive after it installs completely.
Sep 22, 2017 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
How to make a sandisk Cruzer to operate with windows 98
This Cruzer driver package for the SanDisk Cruzer Micro is needed only for Windows 98. Windows Me, 2000 and XP already have the driver (if you are having trouble using the drive on these systems, then it is likely to be a conflict or problem in Windows - see the Windows Device Manager and Windows Help file for details).
After you download the Cruzer driver file, unzip the contents and click setup.exe to begin. Importantly, you should restart Windows 98 so the new Cruzer drivers can properly load into your system. Next, plug in the Cruzer drive and Windows will finish the installation. Restart your computer if needed.
Nov 07, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Hi sir i need the Frontech Drivers Setup Jil 2218 freedownlod because i lost it sir please help me to get it so that i can use the cam plz
OK, checked around and it seems that support from Frontech doesn't exist anymore for this camera. But there is help. Click here. This will take you to Rapidshare, a file hosting company.
Click on 'Free User' and wait the alloted time to download the file.
Click on download and save your file, remembering where you saved it too (the desktop is always a good place). Double click the file and extract the setup.exe to the desktop and double click the setup.exe and then follow the on-screen instructions.
Supported operating systems:
Win 98, Win 98SE, Win ME, Win NT 3.51, Win 2000 Server, Win XP Home, Win XP Pro, Win 2003 Server, Win Vista
( I did check for this driver on Driverguide.com and it uses Rapidshare as a mirror for its file thats where the link come from). Also I have checked this file for viruses and the like and none exist. But feel free to check it yourself. Remember, it's always good practice to scan any files that you download from the internet for viruses (don't take someones word for it).
It this was useful, click YES below
Jun 30, 2009 | GE EasyCam Webcam
Ran a search and destroy program and it deleted system files
WoW, stay away from that program, which was it?
To correct this, you can do one of two things:
first, can you get to you desktop ok? And do you have you XP cd handy? (if you cannot get to your desktop, start with the second thing)
If the answer is yes to both questions, put your XP cd into the CDROM, then go to start >run> type in sfc /scannow in the run box. This will attempt to fix and replace the missing files.
Second thing, if the above does not work do the following:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just re-installs the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 08, 2008 | Compaq Presario 5000 PC Desktop
Please help with panasonic PV-GS31 !!
The driver for Win 200 will work fine under XP. Vista of course is another monster all together.
What I would suggest under Vista is the following.
Use the same Win2000 Drivers...
  1. Extract the drivers to a folder.
  2. Plug the camera into the USB port and Vista will detect it. At this point (if you are really lucky) Vista will have drivers in it's catalogue and install them.
  3. If it does not have them it will pop up a box and ask what you want to do.
  4. Choose select the driver from a list.
  5. When the window pops up, choose Have Disk and browse to the folder you extracted the files into.
  6. Pick the right INF file and then select OK.
  7. It will then begin to try and install the drivers.
  8. Follow any other prompts you see, and make sure to read each one clearly.
Hope that helps =)
Apr 11, 2008 | Panasonic PV-GS31 Mini DV Digital...
Win 98 se file trouble
get hold of a win 98 boot disc (search the net) as it will have the files you are looking for, i am sure. copy them to your hard disc c:\windows or c:\windows\system
put them in both as i cant remember what one they go in. (it will not hurt in both).
good luck
Terry
Mar 26, 2008 | Computers & Internet
For 98 driver
well a drive for that would be located at the SanDisk Website.
anyways heres the driver.
http://www.sandisk.com/assets/file/downloads/oem/oem-ufd-98-driver.exe
Hope it helps, Maxicube
Feb 07, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
