Question about Sony STR-DE605 Receiver
Protector Displays on my Sony STR DE605 Reciever
I have never had this problem. I hooked up the TV to the input side of the receiver. Started playing WII and the unit went to "protector". I have disconnected it and it still doesn't solve the problem. I can get it to turn off if I power down but as soon as I try to turn the volume up it goes back to "protector" display.
  • NicRegan Jan 17, 2009
    Same problem, but I can't get the protector status to go away
  • floman Feb 28, 2009
    I have the same basic "Protector" problem" I have disconnected all inputs and outputs but problem persists.
thesoundman
  • 41 Answers
SOURCE: Sony GX800ES protector
Make sure none of the speaker wires are touching each other. If they are, it will short out the stereo which triggers protection mode and cuts out all of the sound.
Posted on Sep 22, 2007
SOURCE: STR DE435 PROTECTOR STR DE435
I have the same problemwith mine. the protector sign is on- I do not know why- and do not know what to do about it. Let meknow if you do or if you get assistance and I will do the same. My e-mail address is 1971CJS@Bellsouth.net
Posted on Feb 28, 2008
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Posted on Mar 13, 2008
SOURCE: protector fan
i have the same problem , help me umbertknot@hotmail.it
Posted on Jun 28, 2008
renosean
  • 492 Answers
SOURCE: receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Posted on Jan 04, 2009
Sony receiver str-De605 protector flashing
try a reset on unit but unit may have a faulty pa stage
Nov 09, 2014 | Sony STR-DE605 Receiver
I have a Sony STR-DE605 and all of the right side channels are distorted and have to be turned up 1/4 before you can hear any ot the distortion but if i turn if off switch to the left sounds perfect.Center...
Sorry for a dump question ,
have you changed the distorted Right speakers to LEFT to verify if speaker is OK ?
First try with just STEREO ,not on Surround and please contact me for further solution possibility..
Take care..
Jun 27, 2011 | Sony STR-DE605 Receiver
I have an HD PVR (Explorer 8300) and have connected to my Samsung TV using HDMI cable. My question is can I connect my SONY STR DE605 receiver or do I need a new one?
Depending on your tv output, you shpuld be able to hook your TV to receiver via audio output. Running your video components through your receiver will not give you the best performance anyway. Run your HD DVR to TV the way you have it then, if it's possible to run audio out from TV, via, RCA, digital optical, etc., to your receiver. The sound will be transfered through the TV. You may also be able to utilize component out from your HD DVR and a separate audio cable.
May 22, 2011 | Sony STR-DE605 Receiver
Suddenly, for the first time in all the years I've had this Sony receiver, a messege pops up on the front of the receiver saying "protector". What is this??? I have NO idea and don't know what to do. ...
Internal problem probably needs output transistors and a dual emmiter resistor (could a couple other parts too). Parts and labor should be about $100 to $125.
Jan 10, 2010 | Sony STR-DE605 Receiver
My sony str de605 am/fm reciever flashes "Protector", is there something I need to replace internally?
Hiya, not sure if i remember correctly but try reset it. First disconnect the speakers (make sure error isnt there)
When it is ON, press and hold the power button for about 4 seconds. It should then ask reset, clear or something and press enter. When its finished, try it again. If ok, reconnect speakers. If it happens with speakers, there is a problem. If it doesnt work and goes straight back to protect, then there is an internal fault (if i have the reset procedure correct)
Best of luck
Jul 16, 2009 | Sony STR-D700SS Shelf System
Sony receiver sound
what is hooked up to the input of the tv/sat inputs?
it may be the recievers input has a component problem or the output device hooked up to the reciever
Nov 06, 2008 | Sony STR-DG800 Receiver
No audio
Audio amplifiers IC´s damaged you need to change it
Nov 01, 2008 | Sony STR-DB870 Receiver
Optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Feb 05, 2008 | Sony STR-DE595 Receiver
126 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
