Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Maytag Wide by Side model # MZD2766GEO
This past Thanksgiving, we noticed that the fridge was not cooling properly. We took eveything out of the the freezer side and took off the panel which covers the evaporator coil. It was frozen over with ice. We defrosted it with a hair dryer and replaced the panel, and the fridge started dropping degrees immediately. Now, of course, just in time for Christmas, we began having the same problem again. Just an hour ago, we went through the same process again, but this time it looks like the degrees in the fridge aren't dropping below 55. Wondering if we should call a repair person.
  • ernie16 Feb 14, 2009
    My maytag wide by side model mzd2766ge keeps getting water in the bottom of the freezer. I see that the back wall has bulged out and at times water runs down the back (inside to sit in the bottom). The interior of the freezer door is also frozen solid. And during warm weather will drip out the screw holes in the bottom. Also, the fridge has never been very cold, it has been set on the highest setting. Some spots in the drawers will freeze at times though....please help
  • bkmshopping Apr 03, 2009
    About a month ago we notice that our fridge was getting warmer and that prompted us to look inside the freezer and notice that the freezer was frozen over at the coils, ice maker quit working and food not solid frozen like before. We defrosted the freezer and put everything back together. The fridge, freezer, icemaker and everything worked fine and now the freezer coils and wall are frozen again. We can't defrost everymonth. The only thing we have done recently is change the filter, but that was months aga. Sometimes the fridge makes noise up near the top where the light is, not sure if that would have anything to do with the ice up issue. Help!
We had this same problem. Called a repairman. There was a plug to the motor that was not shielded by the manufacturer. Ice built up and pushed the plug out. The repairman melted the ice and plugged it back in. He also shielded the plug to keep it from happening again. The plug was in a position that you couldn't get it unless you knew what you were doing. The whole repair cost $78.00 including the $54.00 for the service call.
Posted on Jan 31, 2009
    Scholar:
  • 132 Answers
You probably have a defective adaptive defrost timer causing ice to block air flow . It might still be frozen between the freezer and fridge.
Posted on Dec 26, 2008
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Aug 19, 2009 | Maytag MZD2766GES Side by Side...
Maytag side by side not getting cold enough
look in the back should have a fan in the bottom probably very dusty if it is it cant cool fridge clean it and it should work unplug it to clean
Jun 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag Fridge (Model # MZD2766GEW) not cooling
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag wide by side not cooling. just prior to this frost build up on top of freezer. Compressor not running.
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. My coil was solid ice.
Apr 05, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Wide by side fridge not cooling
ok sounds you have a bad defrost timer if you give me the model number ill tell you whaere it is its about a 25.00 part and you can do it your self get the model number off the serial plate in the fridge section
Jul 14, 2008 | Maytag Refrigerators
5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Feb 13, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag refrigerator Model MZD2766GEW
Check the evaporator fan motor located abocve teh cooling coils in the freezer side.
Jun 05, 2007 | Maytag MZD2766GES Side by Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
236 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
