Question about Gem Sound GemSound PA-585 2-Channel Amplifier
Boost volume of computer
I want to increase the volume of my speaker output on my computer.
If you have a solution, please let me know
Thank You . . . Greg
    Genius:
  • 1,175 Answers
HI...
Connect the "line-out" of the sound card to the "Line-in" of the GEM amp
Posted on Jan 09, 2009
How do I increase the volume on the speaker?
Search Results
    How to improve sound quality and increase volume on ...
    https://www.androidpit.com/improve-the-sound-and-volume-quality-on-...
    Dec 4, 2015 - Not all smartphones are blessed with speaker quality or volume levels to make your stereo envious. ... How do you improve sound quality on your phone? ....I've seen a 'little' cellphone case, foam padded with a zipper, that ...
    How to increse speaker volume on android smartphone
    www.instructables.com/.../How-to-increse-speaker-volume-o...
    InstructablesRequirements:You will need a phone with Mediatek chipset. ... is a quick turtorial on how to increase the volume of front-facing speakers on android smartphone.
    Increase your Android Phone's Audio Output with Speaker ...
    www.techverse.net/increase-android-phone-volume-output-speaker-boost/
Jan 27, 2016 | Cell Phones
Beringer PMH 660M has very low power output to speakers and when the volume in increased the output pops in the speakers and goes completely dead, everything else works ok and the lights stay on
could possibly be the volume switch, try changing the switch with one that you hardly use to eliminate the problem. any further probs just let me know. hope this helps
Feb 16, 2012 | Behringer Music
How do I increase the sound volume of myToshiba Satellite L755 laptop
By the clock at bottom right there is a speaker icon that can increase volume. right click on it and click sounds, click playback tab at top, Right click on speakers and select properties, should be an enhancment tab for bass boost and loudness.
Feb 12, 2012 | Computers & Internet
Rear speakers' volume of X-540 is too low. Maybe 20-30% of the front speakers. I'd like to increase the volume but it's already at max. I'd like to get the same output from the rear speakers as front...
In order to do this, your computer must be able to support 5.1 systems! Seeing as how a person wouldn't buy this particular set of speakers without knowing that information, I'm guessing you have a bit of knowledge under your belt. You need to go into your audio device settings on your computer and you should have the ability to tweak the settings of the rear speakers from your audio controller panel. I myself have the EAX which allows access to adjusting the speakers volumes based on distance from the listener!
Apr 13, 2011 | Logitech X-540 Computer Speakers
My built in speakers don't work ..but any headphone works ..please help
The output of the speaker jack is not very high, mostly 5 volts DC. This is not enough to power speakers. Most add on speakers have their own power supply (a plug in or Batteries) to boost the volume or signal. If you plug the speakers in without the additional power requirements, they won't work.
It is a good test to plug your headphones in, that determines that your speaker jack is working.
Sep 26, 2010 | HP Compaq Computer Speakers
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
Volume problem
try reducing the output volume from the pc, maybe to about half or even a quarter of full volume. now increase the volume on speakers.
Mar 21, 2010 | Logitech X-540 Computer Speakers
Volume is messed up
i just changed the sound card but thanks anyway
May 12, 2009 | Dell A525 Computer Speakers
VOLUME TOO LOW ON COMPUTER, HOW DO I SET VOLUME , SO THEY ARE LIGHER
On Vista 64bit version goto control panel>>Hardware and Sound.. under sound click on Manage Audio Devices>> then select your speakers by double clicking on them. In the new box that comes up goto Levels and there are slider bars for all settings - top one is Audio output. Slide this to the right. Mine was set at virtually zero when I plugged my speakers in yesterday.
Mar 29, 2009 | ViewSonic NeoSat SP2104 Computer Speakers
Using headphones with Logitech X-230 speakers
I really don't know, because some of the newer gadgets come with fixed volume control due to law suits, ect. Try to see if you can bring you TV menu up and see what the sound setting is.
Dec 25, 2007 | Logitech X-230 Computer Speakers
Gem Sound GemSound PA-585 2-Channel Amplifier Logo
454 people viewed this question
Top Gem Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Sinbad
Rob Sinbad
Are you a Gem Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
