Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
The flame starts to fluter after 5 to 10 minuets and it trips the
I have a 15 year old propane 130,00 btu Coleman forced air, model #BGU13020, and after five to ten minuets the flame starts to shuter and it blows the heat sensor mounted on the cover to access the burner. My authorized repair person is telling me that either my heat exchanger, or the baffles in the housing are bad and that the furnace needs to be replaced. I have removed the burner and have inspected the inside of the exchanger and everthing in there seems to be solid and in tact. I have not looked any further, but after bypassing the sensor and letting it shutter for sometime it seems to me that the gas valve is the problem. The teck told me he checked the gas valve and all is well. My question is, where are the baffles located on my furnace and can they be causing the problem I am having, and how likly is the gas valve to be causing the problem, and how do I do a home test on it myself, also how difficult is it to inspect the baffles and how to go about it.Thank YouMyron Heitzman
  • businessfirs Dec 26, 2008
    Can you email my response to myron@thelivingroomfurniture.com, for some reason your system did not like the address, so I used my alternative one.
    Thank You
    Myron
  • msgshtgn May 11, 2010
    If you have a high eff. furnace your technician is probably right, the main heat exchaner would look fine but the secondary is where your problem lies... look for soot in your condensate trap, or remove the combustion blower and look inside the condensate chamber at the baffels for blockage... if your unit has no condensate trap(doesnt drain water) then you have a mid eff.. and the only way to check forsure is to run the blower and use a match around the welds on the heat exchanger... if the flame blows out then you have a cracked heat exchanger and the unit needs to be replaced...( gas off while your doing this..)
    Scholar:
    New Friend:
  • 70 Answers
I'm guesing this is in a mobile home.this furnace is hard to see the baffles.you really can't check baffles unless you get on the roof and pull cap and look down with flash light but that still doesnt tell much. have you checked to see if you have combustion air coming in to that room. if this is in a mobile home should be a flex pipe in ceiling or some times it comes from underneath make sure you have air from out side coming through. If this is a mobile home if you have alot of snow on roof this will cause the same problem you are having. i would check the flue and intake air first before i took furnace apart. Gas valve doesn't usually cause this problem. the repair guy is probally right but i would check the two thing i told you about first.
Posted on Jan 22, 2009
I have an older Coleman in wall propane furnace, Model 2343.
compressed air or take apart and blow out also check gas pressure
Jun 28, 2012 | Coleman Propane Forced Air Heater...
Light blinks three times, when trying to start heater. it is only four seasons old. what is the fix for this.
check out the pressure switch some times you can jump them out and they light , only to find fault check flame senser is clean and check connection to board
Nov 03, 2010 | Coleman Propane Forced Air Heater...
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Feb 05, 2010 | Coleman Propane Forced Air Heater...
Propane heater goes out after heat cycle
I've seen excessive draft draw the pilot flame away from the thermo couple when the burners light so when the burners shut down so does the pilot.
Feb 08, 2009 | Coleman Propane Forced Air Heater...
Need replacement glass for pilot cover of Coleman Presidential II
the glass is there as a service tool to veiw pilot and flame or relite just get a peice of sheet metal and cover hole with it ,it will work short term or long term
Feb 05, 2009 | Coleman Propane Forced Air Heater...
I have a 15 year old Coleman Propane 130,000 Btu force air furnace, Model #BGU13020 forced air furnace. Afer the unit runs for 5 to 10 minuets, the flame will start to shuter and then it will trip the heat...
DO NOT attempt to repair this yourself. LP gas is a very unforgiving gas. Sounds like your heat exchanger is plugged. Yes it can be removed and checked, BUT it is not recommended. Trust your local repair tech. Any heater 15+ years old should be discarded.
Dec 26, 2008 | Coleman Propane Forced Air Heater...
Cleaning
If the unit isn't too old it doesn't need a tune up. Only thing make sure you change the filter often based on how dirty it is when you change it. say you change it every 2 months and it is filthy go to 6 weeks maybe 30 days would be good. Now if you use a Air Bear filter they last 6 months they say but depends on how dirty it is. you have a flame proving device located at the last burner in line say you have 4 burners it looks like a piece of 10 gauge wire sticking down right next to the flame it does need cleaned maybe every other year with a piece of steel wool very lightly rub the sensor to take the carbon off. It only takes few strokes to clean. And do not even get close to the hot surface igniter it is very fragile and will shatter if you even bumb it.
Oct 02, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
132 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Paul
Paul
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
