Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Old homelite chainsaw, wont pull fuel
I rebuilt carb new fuel line new intank filter. runs great on starting fluid
  • 181 Answers
Most of the time there is a air leak in one of the two crank shaft seals.to get to them you need to pull off the flywheel and the clutch assy.look for wet areas. that will be where the seal is letting out the oil and air.If you keep putting starting fluid in the carburator you will burn the rings,the piston and the cylinder up
Posted on Jan 07, 2009
Help husqvarna 372 chainsaw will not run
check with a husq.dealer,they had some crummy carbs that may need replaced not rebuilt
Mar 06, 2014 | Husqvarna Garden
Zama carb pulls gas when not running
throw the carb out and buy a new one. there is an internal issue that can not be fixed
Mar 20, 2013 | Homelite Garden
My Homelite chainsaw is hard to start and stops running after 5 to 10 seconds.
Could be the filter in the tank or the cap. The tank needs to be vented to allow fuel past the filter.
Jul 03, 2012 | Homelite Garden
My homelite starts good,when warm wont run when pull throotle on
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vaccum to where there is fuel forced in the carb to rum,also the gas will evoporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replaceing gaskets or fuel line if necessory.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where thay want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow untail machine runs also you need to check for spark by removing plug and grounding aginst engine to chech spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ~~
Feb 03, 2012 | Homelite Mighty Lite Lawn Trimmer
Homelite 16" 33cc chainsaw. Sarts but win't keep
Hello rick.... Get an aerosol can of starter fluid at your local autoparts store. Also get an assistant. Remove the air filter and start it up. Have your helper squirt some starter fluid into the air intake to keep it running for a couple minutes until the partial blockage in the carburater clears. Joe
Thanks for choosing Fixya!
Mar 12, 2011 | Homelite Garden
My chain saw 14" homelite
primers pull fuel from the carb and dumps it back into the tank, so if the bulb will not prime the chances are the fuel filter in the tank is blocked, pull the fuel hose through the filer hole and replace the filter on the end.
Jan 27, 2011 | Garden
33cc 14 inch homelite chainsaw, wont rev up to high speed, will start and idle fine, but when you try to rev it up it just dies. I have changed the plug, cleaned the muffler, changed the fuel, rebuilt the...
Morning William:
Acceleration is the "L" needle, try 1/8 turn CCW. No better 3/16 CW.
Please install a new filter on the fuel line, you will be beat to death with carburetor overhauls if you do not.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 27, 2010 | Homelite Garden
Will not start - new fuel 50-1 mixture, checked filter- ok, spark plug sparks, cylinder has compression, finger test, 45cc, aprx 5 month old.
Will it start if you pull the plug and spray starting fluid in the chamber? if so then I'll bet you have a blown diaphragm in the carb or a plugged fuel filter or a bad gas line. hope this helps. Jeepfxr
Oct 08, 2009 | Homelite ZR10926 16" Chain Saw
I have poulan 2075oc that floods out as soon as u pull started rope.you pull it one time and spark plugs is real wet with gas.Saw set for long time with gas in tank and i had to replace all the fuel lines...
you need to open the carb up and take the old fuel line out of the carb filter.....if it is left.the needle is probaly stuck in the open possition letting to much fuel to go to cylinder
Jan 23, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
288 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
