Question about Bernina Sewing Machines
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
My faithful 730 Bernina is currently breaking the bobbin thread. Can you help Roz
  • Bernina Master
  • 7,365 Answers
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Posted on Sep 18, 2012
  • Bernina Master
  • 12,731 Answers
First, clean and oil your machine, especially in the bobbin area.
For your model, the bobbin should be placed in the bobbin case so the bobbin spins clockwise in the case. Make sure the bobbin thread is slipped into the bobbin case properly. After you've loaded the bobbin thread in the bobbin case, can you easily pull the thread or is it hanging up?
Are you using thicker-than-usual thread, or is the thread old?
Posted on Feb 23, 2015
SOURCE:
chrismyers67
  • 53 Answers
SOURCE: top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
Posted on Jun 07, 2010
RickE1
  • 202 Answers
SOURCE: Bernina 180 - winding thread onto bobbin spool
Also it is quite possible that the small circuit board (P-print) just below the bobbinwinder that the motor plugs into has gone bad.
Posted on Nov 27, 2008
mohammed387
  • 1952 Answers
SOURCE: bobbin thread keeps breaking and bunching up
check ur bobbin holder
Posted on Dec 11, 2008
SOURCE: Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Posted on Mar 29, 2009
Mongo32
  • 111 Answers
SOURCE: I have a Bernina Activa 130. The bottom threads
bunching threads bunching means that upper tension or threading is wrong
Posted on Jul 08, 2009
I am doing some machine embroidery on my Bernina Artista 730 and the upper thread keeps breaking. I have changed the needle and rethreaded many, many times!
use a bigger eye in the needle and loosen of the needle thread tension a bit
needles are all the same length but come with various size eyes to accommodate thicker or thinner threads
use scrap material until you get a good combination
Jan 04, 2017 | Bernina Sewing Machines
Thread bernina embroidery bobbin
The thread sensor eye is probably dirty.
Dec 26, 2017 | Bernina Sewing Machines
The bobbin thread keeps balling up when trying to use my 730 on quilt motion system
try changing the needle
try turning the bobbin the opposite direction in the case
make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
if these suggestion don't help then the machine needs to be checked
Mar 06, 2013 | Bernina Sewing Machines
BOBBIN THREADING ON BERNINA 1090S IS NOT WORKING
Make sure bobbin is pushed all the way to the right to lock in place for winding. You say thread cuts...Do you mean bobbin in bobbin case and you are trying to sew, but thread is breaking? If so, a whole different issue. That means there is jam and it can happen if thread not going into tension discs top of machine. Keep presser foot in up position when you thread your machine. Clean the bobbin case and feed dog area out with a brush. Always turn handwheel toasted you or you can cause imbalance of timing. Slow down. Start over after you check basics. Make sure presser foot up when you insert new needle and thread front to back--flat side needle back, more rounded side facing you, use emery cloth to carefully, gently smooth out any burrs or scratches on your bobbin case (that threaded bobbin fits into), and make sure bobbin you place into bobbin case has thread EVENLY distributed on it. Good luck! Jimmy
Apr 03, 2012 | Bernina Sewing Machines
My Bernina 1090 keeps breeaking the bottom thread. It sews about 10 inches and breaks. I take out the bobbin and rethread and it sews a while but still breaks. I have had it in for service 3 times and...
Assuming your bobbin tension is not too high, make sure the bobbin case is clean on the inside - use a cotton bud to clean it out. Are you using good quality Bernina bobbins - if not you're on a hiding to nothing ! It is possible that the bobbin case is deformed, but most likely your service man has set up the tensions too high ... look for someone else !
Jan 21, 2012 | Bernina Sewing Machines
Viewer states problem - but cannot correct.
Hi, if you look in the bobbincase you will see a round spring. Sometimes this gets moved and it blocks the hole the sensor reads through. Clean inside the bobbincase with a q-tip. Also clean the sensor lens on the door with a q-tip. Also try rewinding a bobbin but don't start with the thread through a hole in the bobbin.
Hope this helps.
Rick
Oct 07, 2009 | Bernina Sewing Machines
I have a Bernina Artista 730. Very few inches of
I know this is a long-overdue response, but maybe it will help someone else. I had the same problem, and it turned out that the cause was that my bobbins had oxidized. Rubbing them with a bit of steel wool or fine-grain sandpaper did the trick, and I was up and running again.
Bernina 180 thread breaking and tension problems
First make sure that you are using a new needle in the proper size. A needle with burrs on it will cause the bird's nest problem. Also, is the thread you are using old? My repair guy told me to keep my filled bobbins in the freezer to maintain their humidity, and that has made a world of difference in my stitching. Finally, how long has it been since you had the machine cleaned and serviced, and was it by an authorized Bernina repair shop? Bernina machines have special screws that only Bernina authorized repair people have - I discovered that when I took my machine in to someone who was not authorized only to have the timing go off in a matter of weeks. The authorized repair guy found clumps of thread that had been air blasted into the inner works of the machine and those clumps were getting caught up in the new stitching and causing the same problems you described. Good luck!
Feb 06, 2009 | Bernina Artista 180
Sewing Machines Logo
427 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Wayne Buss
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
