Question about Microwave Ovens
Microwave GE SpacemakerXL JVM 1450
How do you replace the magnetron tube. My microwave runs but does not heat up. I suspect that the magnetron tube is gone bad. I have read some forum posts and my microwave has some of the same problems related to the tube. Thanks Andrew Exactly how do you change the magnetron tube?  I have a GE Spacemaker model JVM 1430WD002?  Was there a recall on this?
    Top Expert:
  • Microwave Ovens Master
  • 28,695 Answers
If you need to ask how to do this task, you may have no idea of the extremely high voltages that exist under the cover, even when unplugged. I would advise a competent person changes it for you.
Posted on Aug 26, 2017
3 Suggested Answers
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
  • 93 Answers
SOURCE: how to remove ge spacemaker 1400?
make sure you check the diode first its cheaper and maybe worth the fix if its a magnatron throw microwave away
Posted on Nov 15, 2011
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE microwave, model JVM 3670 BF03. It is an above the range unit. The unit still has power, the clock, turnstyle and fan work fine, but it no longer heats food.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Aug 18, 2009 | Microwave Ovens
Ge jvm 1653 won't heat
You've got a problem in the microwave circuit, which could be one or more of the following components -
1) HV diode
2) HV Capacitor
3) HV transformer
4) Magnetron
I am leaning to the diode, but it would take further investigation to determine for sure. Diodes are cheap, as if the capacitor, and replacing those first would not necessarily be in vain if it turns out to be the transformer or magnetron. And I would be most inclined to say it's the magnetron before I would think transformer.
Reply back what you find or if you have more questions.
Feb 04, 2009 | GE Microwave Ovens
Microwave does not heat
un plug remove cover find red lead to magnetron with thick long plastic round blob this contains a long glass metal ended fuse that has probably blown due to running when empty long fuse is necessary to stop hi voltage flashing over airgap when fuse blows when fuse blown no output from magnetron as hi volts missing steve t
Dec 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM 1443 - Unit makes a deeper noise and will not heat
Hello mrobinert,
The sound you may be hearing could be the filament transformer breaking down or the magnetron tube failing ..they will arc and eventually fail. If you aren't getting any microwave energy ( to heat material in the cooking compartment) then in all probability it is either the transformer, magnetron or high voltage capacitor.. None of which are something you want to repair yourself... My advice is that if the cost to repair exceeds teh cost to replace then just buy a replacement model. If yours is under 1 year old, then you may be able to negotiate and get a replacement from the store where you purchased it.. If it is older than a year, it's probably cost effective to just buy a new model.
Regards,
Rick
Nov 23, 2008 | GE Microwave Ovens
GE Spacesaver JVM 1651 Not heating, making burning smell
Fisrt, check to be sure your missing cat it not inside the unit. IF the interior is dirty (splatters, grease, etc.) , it may inhibit the unit from working properly.
Nov 22, 2008 | GE JVM1651 Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Microwave part
GE JVM 1660 Microwave. Everything is working fine except it will not heat.
Apr 13, 2008 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
539 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
