Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
NEW UPDATE HOW DO I CHANGE NAT SETTINGS?
WITH THE NEW UPDATE THING I CANT SEEM TO CHANGE THE NAT SETTING TO OPEN AND IT IS STRICT AT THE MOMENT.
IT DOESNT LET ME WHEN I TEST THE CONNECTION TO XBOX LIVE COZ THE CONNECTIONS WORKIN BUT I NEED TO CHANGE THE SETTINGS TO OPEN SO I CAN PLAY FRIENDS ONLINE
HELPPP ANYONE?
ITS REALLY STARTINGGG TO P**S MEE OFF :@
  • 1 more comment
  • zirrah Dec 29, 2008
    Wondering how to make the change or at least see what the settings are in the new Xbox Live interface as well. It used to be so simple in the old interface, now we seem to be locked out of making that change. :)
  • jveltman Dec 31, 2008
    same problem please help
  • Anonymous May 06, 2009
    This sucks i want this fixed, before the update was way better
Go to
configure>gateway>lan>dhcp leases
now find your xbox 360 ip address and edit it so it bypasses the firewall. once you do that you can enable that ip address is dmz gaming. if you have any questions, my gamertag is wanderjahr and i'll help you
Posted on Jan 24, 2009
NAT IS STRICT
STEPS TO CHANGE NAT SETTINGS TO "OPEN":
1- Using your Browser, Log on to your router (by normally typing in the 192.168.1.1 address check your router's manual to see what the default gateway address)
2- If you already know how to log in to your router, then skip this step. If you have never logged on to your router then more than likely you still have the default initial log in credentials (username: admin - Password:1234 ..... Again check your router's manual to be sure). The minute you log in you need to change that password immediately, most network-savvy folks know that 90% of the people out there never reset their router's initial password and they can log on and make any changes to suit their needs, including locking you out of your own router.
3- Once you are logged in, you should be able to find two advance settings (One if for NAT - and the other is for Upnp)
4- Let's start with the NAT setting changes, and we will move on the Upnp at the end. I have personally tried the NAT setting changes and it didn't fix anything, I still had a "Strict" NAT setting on my xbox360, Only when I checked for the Upnp "allow authorized incoming traffic" options when the NAT settings on my XBOX finally came back as "Open" and not "Strict". But I will still explain what I did anyways with the NAT table cause I know it may work for some other routers.
5- So what I did with the NAT setting is this. I located the NAT advanced setting on my router, I click on the NAT (Edit List setting) or whichever link/button you have on your router advanced NAT settings to access the table needed to open certain ports (TCP and UDP - 88 & 3074) .
6- You will need to find out what the static/dynamic (preferably Static) IP address you xbox360 has. To do so, go to the Dashboard, go to the Console settings page, and click on the network settings to see the IP address (should be something like 192.168.1.x). You will need that IP address to enter into your NAT table on your router.
7- Once you got your XBOX's IP address enter it in the NAT Port Forwarding table (From - To - IP address: those are the 3 fields you should have on the table if you are using SUA NAT)
8 - In the first line enter 88 under both "From" and To" fields, then enter the IP address of the xbox in the field where you are to enter an IP address. (this is for UDP port)
9 - Repeat the same step for port TCP (which is 3074)
10- If these changes do not help open your NAT settings, then try the Upnp option. Click on your Upnp Advances settings and click on the "Allow Traffic" option, this is mostly secure because you are only accepting the incoming traffic that matches your outgoing traffic.
Mar 02, 2011 | Belkin Basic Wireless Router
My nat settings for my xbox 360 is set to strict, I am connected to xbox live from my laptop, my laptop is connected to my linksys router, how do i change my nat settings to open if my connection is set up...
You'll need to log into the linksys router and find the setting for UPNP. Please make sure this is enabled. That should allow your NAT setting to at least Moderate, if not Open.
Mar 12, 2010 | Microsoft Xbox 360 Console
I have a playstion 3 and my nat setting is on strict how do i change that to open
Go into your router and change the settings to open nat. For specific instructions, you'll have to post the make and model number of your router.
Feb 14, 2010 | Video Game Consoles & Games
How do i change my xbox nat settings from strict to open
Those are actually the settings in the router, not the 360. You need to open the ports for the 360 on the router itself. Look at the router manufacturers website for more info on how to accomplish this
Dec 30, 2009 | Microsoft Xbox 360 Console
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
Dec 30, 2009 | Microsoft Xbox 360 Arcade
Ok my nat type is strict and i am trying to change to open
You want the NAT open for X-box ?
For X-box you will need to open some ports on the router.
Also you will need to reduce down the MTU on the router to 1365.
That will work.
for this you will need to open the router set up.
Click here for more info about x-box and router settings
Dec 09, 2009 | Actiontec Computers & Internet
Bt home hub change my nat from strict to open
you will need to change some settings on the router.
reduce the MTU. If the MTU settings is1500 then change 1365.
also you will need to open the some ports on the router.
Click Here for more info
Nov 22, 2009 | Computers & Internet
I need to change my nat type from strict to open
This router does not have the typical "strict or open" NAT types. Looking at the manual, it looks like what you want is NAT enabled and SUA only enabled.
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060420161739,420060816160116,420080815092146,420090427144843
Page 133 has the details.
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
Nov 18, 2009 | Zyxel P660HW-D1 Router
Change NAT to open
Go to portforward.com and then set your xbox to conenct using the DMZ option on your router.
Jan 20, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Ps3 is on nat setting 3 strict
You need to forward a port for gaming. Call Sony and ask them what port should you open. Or go to www.portforward.com if you wanna know what port would you like to open
May 15, 2008 | Computers & Internet
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
486 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Jerry
Jerry
Greg Ulan
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
