Question about Toshiba 42HP83 42 in. HD-Ready Plasma Television
Red dots on my plasma screen tv
Red dots on the dark colored areas
Red and green dots on screen
Posted on Feb 22, 2009
Each pixel if u look at it closely has your three primary colours red, green and blue if u are only seeing red then chances are that those tiny bulbs that are filled with xenon gas have blown leaving u with dead pixels i have worked closely with the manufacturers of plasma and lcd tvs, they will give u time frames like in the first year if it blows 10 or more pixels it may be fixed or replaced under warranty... after a certain amount of time they will not repair as they class this as a consumable product to a certain extent and therefore in the fine print they dont have to completely honour such warranty... like a bulb in a projector they will not cover that under warranty.... they only have 3000-4000 hours and the plasmas average around 10 000 - 15 000 hours... hope this was helpful
Posted on May 19, 2009
Red dots means dead pixels if you can return it or sell it because it can sometimes spread out, but you can get it fixed for about 140 dollars at minium at a place that fixes the panels and that of tv's if you can tho return it ASAP
Posted on Feb 07, 2009
2 Suggested Answers
  • 65 Answers
SOURCE: Red Dots
This is know as diffusion. You will need to locate the Vs adjustment inside the TV and vary it up and down by NO MORE THAN 10 volts. If this does not correct the problem then you will need to replace the Plasma panel.
Posted on Aug 14, 2009
VIZIO Tv E422VA picture showing red or green color on dark areas of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
Red dots on Samsung 51 inch plasma
Usually either the main board or the power board--if set is 6 months old---no warranty?
Mar 18, 2012 | Televison & Video
I occasionally get flickering red dots on areas of the screen. Normally when the screen goes from bright to dark colours. Model: Samsung: PS50B451B2WXXU
sorry to tell u but u may have a bad panel , also u can try to replace the Y-sub board , this board is located on the left side of ur tv , left side when u look the tv from the back not from the front
Nov 02, 2010 | Samsung PS42P2S 42 in. Plasma Television
Red dots show up on the black portion of the screen. Any ideas? Thanks, Steve
I had the same red dots in the dark areas and it was driving me nuts. I also have a toshiba 50hp66. Luckily I found out that it's an easy fix. Open up the back of your tv and on the left side you will see two adjustment pots labelled Vsc and Vy. I first marked with a sharpie where the factory defaults were. Then I adjusted down (to the left) the Vy a little and the red spots were gone! My TV looks like new. Hope this helps.
Aug 08, 2010 | Toshiba 50HP66 50 in. Plasma Television
I get red dots in the black areas during dark sceens
http://www.retrevo.com/support/Maxent-MX-42HPM20-TVs-manual/id/278ag118/t/2/
www.scribd.com/doc/.../LG-TV-Plasma-Training-Manual
www.scribd.com/.../SONY-KDL42XBR950-TV-Plasma-Training-Manual
Use these links, user manual and two training manuals, these should help you isolate your problem
May 21, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Hello, why does my plasma tv have thousands of red and green flashing dots all over the dark parts of screen after it has been on for roughly half an hour? if i turn tv off for a while then turn back on...
I had a similar problem but mine was just red specks that showed up in dark scenes. I opened up my plasma and found the adjustment pots that are labeled Vsc, Vy. I then marked the factory default with a sharpie first. Then I lowered the Vy a little and my red specks disappeared. Now my tv looks awsome again like it was new.
May 10, 2010 | Samsung DLP HL-P5663W 56" TV
Red Dots
Aug 14, 2009 | Samsung LN-T4665F 46 in. LCD Television
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
When tv warms up i get red dots in darker areas of screen
what you can do is take off the back pannel and there is a cord on the top of the board that looks like a computer board, there are many boards in the TV but the one I am talking about is twords the bottom where the video jacks plug in to the TV. Ok once you have located the pannel there is a cord on the top kinda tword the right side, it is many wires inside a black covering. What you need to do is just simply unplug it and plug it back in, do this as many times to try to get it to fix the problem.
Dec 29, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Toshiba 42HP83 42 in. HD-Ready Plasma Television Logo
1,892 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
