Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
I have a monitor 2200 that is reading ee 13. what does that mean?
  • Anonymous Dec 28, 2008
    The manual says that it is a burner thermistor failure? the solution it says is to consult your dealer. Mine just did this today? let me know if you figure it out please.
  • 61 Answers
The technical data I have on the Monitor 2200 lists the following for an error code 13:
Failure of ignitor, solenoid pump or circuit board.
Incorrect wiring or flame rod touches to burner parts.
Air pressure switch or overheat open.
I would test the ignitor first, as that's likely the easiest, cheapest thing.
Then work to the pump, flame rod etc.
If you're not familar with the insides of one of these units, i'd recomend having the unit serviced by a qualified technician.
Helping Hands Services
Fairbanks, Alaska
Posted on Oct 27, 2009
    Novelist:
  • 126 Answers
EE13 on a Monitor is one thing. The same code on a Toyostove is completely different. A Monitor EE13 means there was no flame at ignition. On a toyostove EE13 is the burner thermistor.
On the Monitor I would check my fuel tank. On the Toyo you may have to have the dealer help you, as it could be something easy like a very cold day or more complicated as a main circuit board.
Tom Hawkins
Bethel, Alaska
Posted on Jan 06, 2009
  • 4 Answers
EE13 on a monitor heater means the flame rod couldn't detect fire during it's 300 second cycle. I'd start by cleaning the flame rod and making sure there are no obstructions in the exhaust flue. Also, the 2200 is known for clogging the 1/2 mm oil line that runs between the oil pump and the burner pot.
Posted on Dec 30, 2010
What does EE mean under the Systolic reading on a Marshall tm91 Oscillometric ??
This is an error state.. Probably too noisy kortoff sounds to register if too high for cheap home units.. Probably need to test with cuff and stethoscope.
Sep 20, 2014 | Health & Beauty
Error 13 monitor 2200
Check the pump pressure & purge the pump
Dec 17, 2013 | Heating & Cooling
An "E" Readin
E is cuff not applied correctly
EE is cuff not inflated properly
E
E
over each other is too much inflation if inflated manually
See page 25 of the manual.
You both need to sit down and read the instruction manual :>)
instruction manual - Omron
https://omronhealthcare.com.au/pdf/SEM-1_Instruction_manual.pdfThe SEM-1 Automatic Blood Pressure Monitor is intended for home use. SAVE THESE ... If the battery fluid should get in your eyes, immediately rinse with plenty of .... These situations could lead to higher blood pressure reading due to strain or the arm cuff ... If an error symbol "E" or "EE" appears, measurement was not.
Nov 06, 2017 | Walgreens Blood Pressure And Pulse Monitor
What does EE mean?
EE means one of 3 things:
1. Cuff has been placed incorrectly. Solution: Wrap the cuff properly so that it is positioned correctly.
2. Did you talk or move during measurement? Solution: Measure again. Keep wrist steady during measurement.
3. Shaking of the wrist with the cuff on. Solution: Same as # 2.
Jan 25, 2011 | Walgreens By HoMedics Automatic Wrist...
What does it mean when you get a reading then 3 consecutive readings say EE
What is the pattern of the EE? If the two E's are on the same line, then you didn't inflate the cuff to a sufficient pressure. (Wait 2-3 minutes before trying again and then inflate the cuff to 40 mmHg higher than the previous attempt.)
If the Es are arranged vertically, then you overinflated the cuff. Any [ressure above 300 mmHg is beyond the range that this bp monitor can handle. If you reached this point by getting several underinflation alerts, ask your medical professional to test your bp and recommend the starting inflation level that you need.
Make sure that you have the cuff on properly. You may need to consider a different bp pressure cuff size to get an accurate reading.
I hope this.
Sep 09, 2010 | Omron Model HEM 432C Manual Inflation...
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
Reading EE
The cuff sensor must be placed directly over the vain. This takes practice.
Feb 01, 2009 | Homedics Deluxe Automatic Arm Blood...
Homedics wrist blood pressure monitor. All I get for a reading is 'EE'
That means you are moving, or you are inflating the cuff to soon after This is what happens with mine.
Jan 18, 2009 | Health & Beauty
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
671 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
