Question about Proscan PS36123 TV
Service menu Hi; I need a working service menu sequence for a 1996 proscan ps36123 tv, chassis ctc169ej5. Got this set some time ago from a friend who got fed up with it's intermittant problems. Have solved major faults and been using set for a while now but finally decided to fix last trouble which I have worked around with vcr tuner. Had to make more fixes to tv tuner, and although problem is solved (hi freq air channels would quit), I need to retune them. Have tried various sequences including : hold menu, push power, then vol> (only works on 27 in chassis'); simultaneously press menu, vol<, ch< for 15secs (doing this with menu,+ gives green light but no hv/pic)!!; hold vol<, ch< and wait for green power light. Looks like there is a dif sequence for this earlier set since the control buttons are ; -,+,menu,ch<,ch>,vol<,vol>,power Help or I'll have to fiddle with coils!!
  • Paul Aeberli Apr 23, 2007
    Thanks to all, but if there is no service menu, how is the tuner adjusted after installation ?
    Scholar:
  • 119 Answers
Ctc169 tv's do not have a service menu, they are too old. sorry.
Posted on Apr 23, 2007
  • kevin letteney Apr 24, 2007
    any adjustments or test points would be on the main board near the tuner. Typically i find no problem with these parts & adjustments. usually will find bad solder connections in the tuner itself, if not i replace the tuner.
    good lick.
    Novelist:
    Champion:
  • 236 Answers
Have you tried replacing the EEPROM? It may have lost it's programming for that set. Stargazer
  • Simpson Neal Apr 23, 2007
    I don't think the CTC 169 has a service menu.
    AT least I've never seen one.
    Stargazer
SOURCE:
Proscan PA31122 TV audio amp
my regservo need to active plz help me for activation code
Dec 29, 2013 | Proscan Used Original PS31122 SIMPLE...
Proscan RCA 36" Manufactured by Thomson Consumer Electronics Model PS36123 36 Diagonal The problem is that the picture shrinks down to a horezental line across the center of the screen.If I tap the TV hard...
HELLO
In the UK I'm not familiar with this American set, but what I can tell you is there is a number of dry solder joints on or around the field output IC causing what is known as FIELD COLLAPSE.
To find bad joints I use a long, thin and round piece of wood (remember wood does not conduct) I just tap around the board until I hit the right part and you know when you have by the results on the screen then you can switch off and resolder.
If you are going to attempt the job yourself - BE CAREFUL - high voltages are generated inside TV sets and pay attention to the panel fitted to the tube base this will give you one hell of a kick if you touch it!
BUT.....if you are not confident of doing this yourself and have any doubts then don't do it yourself and get a TV engineer in sort it out.
GOOD LUCK (:-)
Oct 09, 2009 | Proscan PS36123 TV
Proscan ctc169ej5 no picher
There is no brightness control inside the set. You control the brightness and other picture adjustments with the remote control. If the brightness level is already at its normal setting, the problem is in the TV's video stage and is caused by some component failure. It's not possible to suggest any specific parts to check, and you should see about having the set serviced by a professional who would have the service information and tools to diagnose and repair the trouble.
Apr 27, 2009 | Proscan PS36109 36" TV
Distorted picture on my 32" Proscan TV...(about 15 years old)
The RCA GE sets have a problem with bad solder connections in the tuner unit which also causes numerous symptoms including poor regulation, no vertical deflection, low audio or dead set.
Pulling in from the sides is either poor regulation or a bad eeprom/solder join issue
Mar 13, 2009 | Proscan PS36123 TV
Proscan ps35653 chassis ctc169 picture to wide for screen
press the menu button on the front of the tv and then scroll down using the channel buttons to picture format, next change the format from widescreen to standard.
Jan 19, 2009 | Proscan PS36123 TV
What is your customer service number
Hello amy123478,
Proscan is owned by RCA, but they have very little support for that product any more. RCA created another company to deal with the product it is http://www.oncorpus.com/ They may have support for your TV set.
The chassis number is CTC169CG5 (This may help you find service data) since this same chassis is used in RCA models.
Any shop servicing RCAs should be able to find this chassis number and provide service to you, if RCA or Thomson Electronics is non-responsive to you.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 05, 2009 | Proscan PS27123 TV
27" proscan tv
This is a sign that there are either bad caps in the vertical circuit or bad connections at the vertical IC. CAn you solder? If so, resolder the pins on the vertical IC first and post the results here. The vertical IC will be a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar.
Keep us posted.
Dan
Sep 24, 2008 | Proscan PS36123 TV
Service manual for Proscan PS52690
I believe your model is a PTK188 can you look for the chassis number off the tag on the back, and I may be able to help you locate a manual, but the older RCA / Proscan / GE need the chassis number
Jun 14, 2008 | Televison & Video
Convergance setting
Convergence procedure for Proscan chassis CTC188 is: 1) press and hold menu- press power- press vol.+.(P00 and V00 will be displayed 2) release menu- press vol+ and adjust until V80 appears. 3) press ch.+ and navigate using directional buttons on remote and tv button to save/exit. Hope this helps. If not e-mail me.
Apr 19, 2008 | Proscan PS60690 60" Rear Projection...
ProScan rear projection
Proscans are manufactured in conjunction with RCA what is the chassis number of your set? I can help you out if you can provide the chassis number. Should be located on the back cover of your set.
Mar 02, 2008 | RCA P61960 61" Rear Projection Television
Televison & Video Logo
156 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
