Question about Panasonic PanaFax UF-8000 Laser Fax
Replacing fuser assembly
Can I have instructions on how to replace it?
  • Anonymous Feb 18, 2009
    what do you have to remove before you replace fuser unit?
    Genius:
  • 2,120 Answers
Even the manual won't be enough to do this job.
Take off ALL covers and the Document Feeder, then write back to me for further disassembly instructions.
The fuser comes out through the top of the machine.
Posted on Sep 08, 2008
  • 944 Answers
Here is the operators manual for your fax if you need it; http://service.us.panasonic.com/OPERMANPDF/UF7000AU.PDF Instructions for changing the fuser assy will be available only in the service manual which is not available online but can be purchased at; 800-833-9626 or http://service.us.panasonic.com/Feedback/default.aspx Hope this helps :)
Posted on Apr 19, 2007
Fully agree with TECH 435 plus do not forget to reset the fuser in service mode when changed.
Posted on Oct 15, 2008
    Sergeant:
  • 284 Answers
One the fuser does not come out though the top of the machine but the rear. but you do have to rip it down to the bare bones almost to get it out. but if you do try this your self be very care full of the ribbon cables near the fuser . if you damage those its take along time to fix them.
if you want to try it i can help, but i will asume no responsibility if something goes wrong.
good luck
Posted on Sep 10, 2008
Part of printed copy is washed out ricoh aficio sp c210sf
Seems its fuser assembly fault.
Fuser assembly is a part to fix toner image permenentely with the help of hot rollers on media. The temparature varie depends on model, in case the temparature not reachess specified level you may get image fixation problem, the same what you are facing. Replace fuser assembly.
Oct 02, 2014 | Ricoh Aficio SP-C210SF Printer
Hp laserjet 4350 print problems
Two reasons: 1. cartridge 2. Trflon sleeve.
A.Check with another cartridgeB.Remove fuser assembly, check teflon sleeve surface,if its dirty or toner deposited on it replace it if you can or replace entire fuser assembly. Replacing the fuser assembly is user friendly.How to remove fusser: browse this youtube video link:
http://www.youtube.com/watch?v=j0Pi-eHgoSA
Nov 27, 2012 | HP LaserJet 4350n Printer
I replaced a black toner after that the is only displaying printing cool down mode and not printing help to know the problem
if the problem started only after replacing the toner, u can look if there is something went into the printer while replacing the toner. open the door & look carefully for any object/dust inside the printer.
may be there may be damage done during replacing the toner. try to replace a new toner & watch the results. printing cool down mode indicates that fuser assembly which is inside of printer is hot & will take time to cool down. there may be a problem in that fuser assembly.
Sep 13, 2011 | HP LaserJet CP1518 Printer
My printer is displaying the following message - 122.03 Service Fuser Error. Can you tell me what this means?
This means the fuser unit is defective and needs to be replaced.
Depending on your location you need one of the following parts
40X5437 Fuser assembly, 115 V
40X5438 Fuser assembly, 230 V
40X5439 Fuser assembly 100 V
Replacing the fuser is not very difficult but you will have to follow certain steps.
1. Remove the right cover assembly.
2. Remove the left cover.
3. Disconnect the two-wire fuser cable from the LVPS.
4. Position the fuser cable so that it can be pulled through from the front of the printer, and guide the cable through to the front.
Warning: Be careful not to damage the cable by pulling too hard or cutting the cable insulation.
5. Remove the screw and grounding washer (1) on the right side of the frame.
Note: Be careful not to lose the grounding washer.
6. Disconnect the thermistor cables (2).
7. Remove the exit deflector and bin full sensor flag
8. Remove the bin full sensor
9. Unhook the springs (3 and 4) from both sides of the fuser.
Jan 03, 2011 | Lexmark C543dn 26B0000 Workgroup Up to 21...
Fuser error 50.9 came up when we turned the printer on what does that mean??
normally this error means you have a bad fuser assembly. These items are normally a customer replaceable part. If replacing the fuser assembly does not correct the error code you may have a bad power supply board.
Sep 30, 2010 | HP LaserJet 4700 Printer
Replacing upper fuser roller
there really is no need to remove the cleaning web when replaceing the upper fixing roller.... it stays in place and will not present a problem apon replacement
Jun 04, 2010 | Canon imageRUNNER 5000 Copier
Fusher eror 924
924 Fuser Error - Open circuit detected in thermistor circuit. The thermistor provides feedback on the temperature of the fuser roller and when it fails, the fuser normally does not heat up.
It means either disassembling the fuser and replacing the thermistor ( if you can find one) or replacing the fuser assembly.
so i would suggest that take it to nearest service centre of lexmark. best of luck
Oct 27, 2009 | Lexmark T430 Laser Printer
How to replaced fuser on the Canon ImageClass 780
the steps are posted on the reference guide found in the link below from Canon
http://gdlp01.c-wss.com/gds/0300000515/imageCLASS_D780_D760_D761_Reference_Guide_EN.pdf
Sep 09, 2009 | Canon imageCLASS D780 All-In-One Laser...
XEROX WORKCENTER XD100 NOISE
Most likely the fuser gear is worn. The noise is prominant in the right side toward the back I am assuming.
You can replace the heat roll drive gear itself, but honestly I would recommend replacing the entire fuser assembly. It is probably very very tight and would wear another gear out quickly.
You want to get that replaced before the drive gear on the main motor assembly wears out. It would not rewuire replacing that entire main drive assembly, But it is a real difficult part to replace.
Go onto google and do a search for The Parts Drop. It will be the first item to come up. CLick it on and call and talk to Britt.
He will have what you need for a reasonable price.
if you go that route and need instructions to replace that part. let me know. Its not very difficult.
Jul 16, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Paper jam problem in laser printer 4100
if this happens every time you need to replace the fuser. but there is a possibility it could be the main gear drive assembly, 9 times out of 10 it's the fuser. a gear on the fuser usually breaks a few teeth. the fuser is very easy to replace and is a part that will eventually need replacing on all printers.
Jan 07, 2008 | HP LaserJet 4100 Printer
Panasonic PanaFax UF-8000 Laser Fax Logo
975 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
