Question about Samsung HL-P5063W 50" Rear Projection HDTV
My Samsung DLP TV is making a noise that sounds like a bad fan.
The noise comes and goes.  It will only happen after we've watched TV and turn of the TV then back on within a short period of time.  When the TV does come on without the noise it is fine as long as it stays on.
    Novelist:
  • 159 Answers
This high pitch noise comes from the color wheel. Now is unbalanced and the noise is going to be even hardest with the time. send it to change now. this part is inside the light engine
Posted on Apr 08, 2009
SAMSUNG DLP HL-R4667
It sounds like a bad color wheel (see photo) which will give a fan like or high pitched sound.
Very common on these sets and can be a do it yourself repair.
You Tube has complete video instructions for replacement for most of these models.
The wheel turns at over 12,000 rpm (very small part) and the bearings in the motor fail causing a fan like or whine noise.
If it fails all the way and shatters (it can) set will not even make it on---set is monitoring the wheel and if not at right speed or stops almost instant shutdown will happen.
see the photo and let me know if questions--replaced a lot of them and your description is classic.
Mar 19, 2012 | Samsung DLP HL-P5663W 56" TV
Samsung hlr5078wx DLP tv. rumbling noise and shaky picture
This is a color wheel problem.
I would recommend to use professional help because you can make more damage to the optical engine. Not to mention index delay have to be re-adjusted in special service menu after repair is complete.
Regards.
Russ.
Jul 23, 2010 | Samsung HL-R5078W 50" HDTV
Samsung dlp hls6186w, picture has darkened, could it be the lamp or is it the colour wheel??... tv is making sounds...I thought it was the fan, the fan looks okay??? It also shuts down once and a while...
The lamp is the only thing that will cause the picture to go darker. According to the model you have the lamp part number is BP96-01472A. The noise you hear could possibly be the color wheel itself. The way to tell is when you turn off the TV the lamp stays on for about 10 seconds longer. Once the lamp shuts off if that noise goes away then it is a bad color wheel. Any noises past that would be a fan. Please take a moment to rate my answer. Thanks...
Dec 02, 2009 | Samsung HLS6186W 61 in. Plasma HDTV
I have a 42" Samsung DLP that makes noise that sounds like it's coming from the fan. The sound starts after the TV has been on for 20-30 minutes; it's a winding type sound and continues until after the TV...
These models usually suffer from a bad color wheel. You will know that the color wheel is at fault if the sounds goes away right when the lamp shuts off. Look at the back of the set and watch for the lamp to shut down. The color wheel is not a consumer replaceable item.
Aug 15, 2009 | Samsung DLP HL-P5663W 56" TV
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HDTV wide screen
Sounds like the colorwheel (used in DLP projection sets with a single DLP panel) is going bad, either the wheel itself or the bearings on the motor driving the wheel are starting to fail. I would recommend getting a professional to service the TV set.
Jan 11, 2008 | Televison & Video
Bightness Change
It sounds like your lamp is going bad. The lamp part number is listed as "lamp code" on a sticker located on the left side of the set. Use this number to grab a replacement off ebay.
Dec 20, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung DLP loud vibrating noise
The color wheel is the most common problem in DLPs that cause noise. To determine the cause: Turn the set off. If the noise goes away after about five seconds, then, the problem is the color wheel. If the noise goes away one to two minutes after shut off, then, the problem is a fan. You can find an Authorized Servicer in your area that can tell you the price of repair, by clicking on the Samsung link: http://www.samsung.com/Support/ServiceLocations/index.htm
Apr 22, 2007 | Samsung DLP HL-P5663W 56" TV
HDTV Rear Projection
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Apr 01, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
324 people viewed this question
Jerry Greenberg
Jerry Greenberg
