Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice in bottom of freezer
Hi there... You posted this question on the FixYa website:
"There is water build up then ice in the bottom of the freezer. Aboutonce a day there is overflow out of the bottom of the freezer door ontothe floor."
I am having exactly the same problem with my side-by-side Kitchenaid. Did you ever find out how to fix it?
    Top Expert:
  • Frigidaire Master
  • 3,911 Answers
Most likely a clogged defrost drain
Posted on Nov 10, 2017
  • 3 Answers
Add a 3/4" x 1" or so clear piece of tubing slid over the existing fill tube. (available at any big box hardware store) I had the same issue until I installed this. You just want it long enough to pass the top lip of the ice tray. Mine was too short and water would run down the inside of the freezer and was a mess. I would also recommend cutting the bottom end at a 40 or so degree angel as it makes getting the ice maker module out a tad easier if you need to remove it.
Don't push too hard sliding the clear tubing over the existing tube,. Mine wasn't mounted very well inside the freezer cavity and you could actually push it further in.
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Ice forming in bottom of freezer
Rita, your drain hole is frozen over and when your refer goes into defrost the water is running out into the cabinet instead of down the drain hole. Remove the evaporator cover and poor some boiling water in the evaporator drip pan. This should melt the ice and clear the drain hole....Catriver...post back.
Posted on Aug 17, 2006
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
larryyb
  • 291 Answers
SOURCE: Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
Posted on Nov 25, 2008
SOURCE: Ice Build Up in Freezer of FRS26ZSH
I had this problem. You need to clean out the drain under the freezer. The tech that came out used a squeezie bulb similar to what you use for a baby to clean their nose when clogged. You have to remove all the shelf's and the back plate. You need to use warm water to defrost the frozen ice and remove. use water and squeeze into the hole and **** out.. takes 10 minutes.. finally it will drain.. no parts are necessary. good `luck
Posted on Aug 02, 2009
Ice sheets build up on the bottom of the freezer. Water also seems to be dripping into the refrigerator from the freezer. Not sure what the problem is and looking for help!
Hi and welcome to FixYa, I am Kelly.
First off if you have an ice maker this sheeting of ice is most often caused by the ice maker inlet water valve bypassing water when it supposed to be shut off. You can check for ice in the rubber tube that fills the ice maker. If it is frozen hard with ice most likely you have an inlet water valve failure. The valve is not repairable. The only remedy is to replace it.
Second reason for ice build up on the bottom of the freezer is a clogged evaporator drain. If you see ice for sure under the evaporator coils then the drain is clogged. You clear the drain by unplugging the unit.. removing the freezer contents and directing an external fan into the freezer compartment for just over 2 hours. While this is happening... open the back of the unit by removing the fiberboard cover and cleaning out both the drip pan and the END of the compartment drain tube. I use a wet or dry Vacuum for this task. When the 2 hours of manual defrosting is completed.. use the exhaust of the vacuum on the very end of the compartment drain tube. This will float out any debris that was in the evaporator drain funnel and make sure that the compartment drain tube is clear. Make sure to clean the condenser coils and fan in the bottom of the unit while your cleaning the drip pan.
After all of the above reassemble the rear fiberboard cover, wipe up any water mess in the freezer compartment and return the unit to normal use.
Since you did not include a model number I am unable to provide you with an exact reference source for the inlet water valve. You can however use the following sites and enter your model number for parts information:
http://www.searspartsdirect.com
http://www.appliancepartspros.com
http://www.repairclinic.com
Thanks for choosing FixYa,
Kelly
Jun 27, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice build up in freezer compartment
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 12, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Not making ice error code 1f
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | LG LFX23961SW Bottom Freezer French Door...
Ice builds up on bottom of freezer and water runs out onto floor.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
heatman101
May 31, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
Ice build up on bottom freezer
Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Ice build up on freezer floor.
Hi, If ice is building in the freezer, you have a defrost drain hole plugged. Unplug the Fridge and then remove the rear panel off the freezer. There you will find ice built up in rain. Remove the ice (hair dryer works best). Once the ice is gone, you need to make sure the drain hole is open all the way. A baisting serringe with hot water works really well.
I hope this helps. Please let me know if I can assist you further. Please rate my answer so I know how I am doing.
Thanks
Vic
May 22, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
54 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
