Question about V.Smile V Smile Console
V.smile console - picture jumping up and down on 37" LCD screen
I found this with ours and I bought a new system and the AC adapter to go with the new system batteries were getting crazy anyhow the kids hooked up the old one to the vsmile adapter and it stopped. So from experience you need fresh batteries or only the vsmile 9v adapter, other brand adapters also caused the jumping!
Posted on Jan 28, 2009
LINES ACROSS TV AND PICTURE JUMPS UP AND DOWN HOW TO FIX
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 05, 2014 | Televison & Video
My Insignia NS LCD 37 will power up but the screen is gray and there is an even lighter gray bar going up and down but no picture
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | Insignia NS-LCD37 37 in. LCD TV
I have a 37" JVC LCD TV Model # T370HW02 and the left half of the picture if filled with vertical colored lines for approximately 30 minutes after the set is turned on then the picture clears up and s
The problem with your TV is the screen tabs this is where the electronics bond to the screen a technician may be able to fix it with compression pads otherwise it a new screen
Apr 11, 2017 | JVC Jlc37bc3000 37 Lcd Tv 1080p
Flashing picture
I had the same problem with my 237V, I had to replace the power supply to fix the problem. I believe when it would work the output voltage of the power supply was around 19.2v. When the screen started to strobe the voltage had jumped up to 21.5V. A new power supply fixed it for me but now I think my main board is on the fritz.
Sep 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Philips 52" LCD TV
I think what you're talking about is the feature of the TV that auto-adjusts the screen for different pictures. What is does is tries to auto-fill the screen in case there are black bars on top (because of widescreen content) or on the side (regular tv content). It does it mistakenly if it notices too much black anywhere... happens a lot to me when credits are rolling. You can turn this off in your TV settings... I think you just set it to a specific type (widescreen, etc) instead of "auto".
Aug 21, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Broken screen on a 37 inch hd lcd
That may have been an expensive tantrum - I doubt if it will be repaired as a warranty item and the typical cost of replacement makes it a costly lesson.
I doubt if the LCD panel is priced under $6-700.
Jul 01, 2008 | Olevia LT32HVM 32 in. LCD Television
Screen Jumping
Try and adjust your screen frequency in the wii system settings.
Mar 26, 2008 | Nintendo Wii Console
LCD RCA quality issue with V.Smile
No picture or sound on TV with V-Smile. Could the wires be replaced on the V-Smile?
Dec 10, 2007 | Televison & Video
V.Smile V Smile Console Logo
251 people viewed this question
Top V.Smile Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a V.Smile Toy Expert? Answer questions, earn points and help others
